Washer will not operate replaced ccu, Operated foe about 2 mins, same as before will not respond to any setting
HELP!!!
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number?
Posted on Oct 28, 2012
  • jim dobson Oct 28, 2012
    WHIRLPOOL DUET WFW9400SW02 FRONT LOADER
Got washer whirlpool coin operated and All the LED light from panel are on!! What can be happen?
coin mechanism is melfunctioning . Not an easy prob to assertain without being there
Jan 29, 2015 | Whirlpool CAM2752RQ Coin Operated...
Washer gives code F22. I replaced the door lock mechanism but it still will not start.
Hi, F-22 means that the CCU /touch pad/LED assembly unable to transmit/receive
data to/from the CCU central control unit
Possible causes/procedure:
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit (CCU).
Your model's tech sheet gives error codes and remedys.
Jun 17, 2011 | Kenmore Elite HE5t Washer
Flashes F-01
Sorry to read about your problem, I hope this helps you out.
F/01 is an EEPROM error on the CCU. A power glitch may cause this error; unplug washer or disconnect power for two minutes. then you'll need a new CCU-- not a rare event on this washer.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
First machine would come on, do nothing, then go off. Now it does nothing and the door will not even open. Any ideas?
1. Check that the unit is plugged into a working outlet and for blown fuses. 2. Check for power going to Central Control Unit (CCU) by listening for a click in the CCU when unit is plugged in. If no click, replace CCU. 3. Unplug washer or disconnect power. 4. Check continuity of line cord and line filter. 5. Check harness connections to CCU. 6. Plug in washer or reconnect power. 7. Check the touch-pad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touch-pad/LED is responding.
Nov 28, 2010 | Kenmore HE2 Plus Front Load Washer
The washing machine is flashing f21; we have checked the drains; front and back. The pumps are running fine. WHat could be the problem?
HI. This error occurs if the touchpad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
Possible Causes / Procedure
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding.
3. Check wire harness connections to the touchpad/LED assembly and Central Control Unit (CCU).
Replace failed component.(Which will be the actual CCU, if the wiriness harness is ok, and the touch pad is responding and connected properly)
Dec 21, 2009 | Kenmore Elite 45986 Front Load Washer
My kEnmore front load he2 plus washer is flashing f-28 does anyone know what this means?
F-28 refers to Communication Error.
Possible Causes/Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
- Check connections of the CCU board within the housing.
- Make sure all grounding switches are engaged.
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic Test
or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing
the MCU connectors.
Note - The cost of CCU and MCU is more than $200 each. You cannot replace a part of CCU and MCU. The complete Set needs to be changed. If the Washer is more than 4 years ( which i assume, as this Error is usually after 4-5 Years ), it is better to Invest in new one than Repair.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 06, 2009 | Washing Machines
The washer is flashing f 21, what does that mean?
F22
CCU/Touchpad/LED assembly error
This error occurs if the touchpad/DED assembly is not able to transmit/receive data to/from the central control unit (CCU)
3. Check Wire Harness connectors to the touchpad/LED assembly and Central Control Unit (CCU)
Replace failed component.(In most cases, the CCU(Central Control Unit), will need to be replaced).
Jul 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F-11
FIRST COMMENT
F11 Serial communication error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
2. Check wire harness connections to the MCU, the motor, and Central Control Unit (CCU).
5. Verify CCU operation by running a Diagnostic test or any cycle.
8. Check that the serial harness at the MCU is not mounted upside down. The wires should be to the left when facing the MCU connectors.
Jun 15, 2008 | KitchenAid KHWS01PMT Front Load Washer
Front Load washer won't start
according to site an f-01 relates to a CCU issue, remove power for 2 min and try to reset, if not check wiring to CCU(central control uint) all in tact?? replace CCU
Mar 03, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
