Question about Lavelle Industries Korky& Universal Toilet Repair Kit
My new Korky keeps hissing, just like the old one.
Everything is new,flapper etc. water level is set as required,but still hear water running and a hissing sound.
3 Suggested Answers
  • 129 Answers
SOURCE: Korky anti-siphon. Tank water slowly
either the fill valve is running and water is draining into the bowl via the overflow tube in the tank or the flapper is bad (or foreign matter) and it is allowing water to escape into the bowl slowly...causing the fill valve to run every few minutes or so. hope this helps but if you need anything else just text me here:)
Posted on Jul 29, 2011
I put the korky fill valve in and it was hissing and water was flowing slowly into the bowl. I had put a new korky flap on as well. So I bought a fluidmasted perfor MAX flapper and installed it and it solved the problem!
Posted on Oct 13, 2015
Toilet Flapper drops too soon and causes incomplete flush. Replaced with new red Korky, and adjusted chain tighter AND looser.
Try adjusting the water level in the tank. Most flappers close as the water in the tank flows out to a certain level. Try allowing more water to come in to the tank. I doubt the weight of the chain has any effect on it closing too early.
Nov 03, 2016 | Home
I have a hissing toilet. My kohler 4708 fills up, and once this happens, the left side of the tank has a constant hissing sound. When I turn off the water it stops.
Your valve inside the tank has worn down and not allowing the water to stop running. Does the water run over the top of the overflow. If so, then adjust your inlet water to a lower level so it will cut off. If that is ok, then likely the flapper is worn out and needs to be replaced.
Feb 19, 2013 | Kohler Home
How to fix a dripping toilet
if the fluidmaster,itself is leaking, there is a rubber disk in the base of fluidmaster, replace disk. however, i can almost promise you the dripping you hear is from a bad flapper. replace with KORKY brand flapper. buy the basic black one, with no water saving gadgets on it.you will see cheaper black ones, but get the KORKY
Dec 20, 2012 | Fluidmaster S2DBL Dual Flush Toil System
Korky anti-siphon. Tank water slowly drops, accompanied by a hissing sound. Then, after dropping about 1/2 inch, it refills. Wha?
Jul 29, 2011 | Lavelle Industries Korky& Universal Toilet...
My Crane toilet is slowly leaking into the bowl. It is not the flapper (which I replaced) and doesn't seem to be from high water pressure. Could it be the seal?
Check your over flow pipe in the tank to see if you need to lower the water level amount in the tank. If thats not it, it could be the seal thats under your flapper between the tank and base. Simple fix just alittle time consuming
Sep 24, 2010 | Crane Plumbing 3755 Toilet-To-Go Metro...
I just bought a new kohler cimmaron biscuit 2 peice tiolet. it is installed correctly. every so often i hear the water running for a few seconds then it shuts off like its losing water and refilling. i...
check fill tube from the fill valve to the flush valve, if the end of the hose is close to the watr level it will back syphon.... recommend also putting in better inner components.. fluild master 400 a fill valve and a nice red korky flapper
Sep 02, 2010 | Kohler Cimarron 2-PC Elongated Toilet with...
We can hear the faint sound of water running - sounds more like a hiss - but can't see where to make an adjustment.
The PROBLEM is not an adjustment. There is a water hiss because there is a leak. It sounds like the flapper is slowly leaking water into the bowl. Drop some food coloring into the tank, wait a while and see if there comes color in the bowl. If so you need to replace the flapper (simple to do).
Oct 28, 2009 | Home
Kohler two peice toilet the water just circles and will not flush.there is plenty of water in holding tank that run through
These models need to have a flush valve flapper that has a styrofoam float on the lift chaninof the flapper. Go to hardware store or home improvement store and get a 'Korky brand toilet tank flapper with float 'ball". Cut the rubber ring piece away from the flapper and you don't need it (see cut here marks on flapper). Install flapper and adjust the float fairly close to the flapper.
When the water level drops in the tank and reaches the level of the float on the opne flapper, the flapper quickly closes causing the toilet to have a "surge" of siphon action which forces the water in the bowl to be drawn out.
Jun 29, 2009 | Kohler K-3422 - Wellworth Elongated...
Toto 1.6 gpf won't stop running
1-check water level make sure it doesnt fill over flush valve.2-check handle make sure its not sticking and chain isnt catching on anything when flushed.3-replace flapper i like KORKY flappers. the red ones. like 6$
Jun 20, 2009 | Washing Machines
Lavelle Industries Korky& Universal Toilet Repair Kit  Logo
43 people viewed this question
Top Lavelle Industries Home Experts
Donni Steen
Tom Chichester
Are you a Lavelle Industries Home Expert? Answer questions, earn points and help others
