Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer leaks but not every load
The washer leaks occasionlly. 0ne load in ten.Its is on extented warranty service guy came but it did not leak for him. it is about 5-7 years old
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Pull the kick panel under the door and when it leaks, you will be able to tell where from. Hopefully not the tub.
Posted on Oct 28, 2012
jsrock516
  • 5911 Answers
SOURCE: Error code F09/Whirlpool Duet front loading washer
"F09" is an Overflow Condition error. This is usually attributed to a malfunctioning pressure switch, loose or broken connector between the Pressure Switch, Drain Pump and Central Control Unit (CCU), or...a drain pump or drain line that has become clogged.
Since this problem occurs periodically during the wash cycle, I would check your drain pump filter for obstructions first. It could be that you have debris lodged in the pump causing it not to drain properly. To access the pump:
1. Unplug the washer.
2. Remove the lower kick panel under the door by removing the screws under the bottom edge. HINT: Placing a couple of blocks of wood under the front feet of the washer will make access much easier.
3. The drain pump is located under the wash tub in the center. HINT: If you own a shop vac, remove the drain line from the standpipe at the wall and pull a vacuum through the drain line. This will remove all residual water from the washer and make clean up later a lot less messy. Now, remove the cover on the drain pump and remove. Clean out the pump filter and check the pump impeller for obstructions.
If you do not own a shop vac, place a bunch of towels around the drain pump BEFORE you open it. There's about a gallon or so of water in the tub, drain line and pump.
Try this first, and let me know if this corrects your problem. If not, you may need to check the pressure switch and wiring. I hope this helps you.
Posted on Apr 14, 2008
  • 32 Answers
SOURCE: Whirlpool Duet washer leaking during clean washer cycle
the highest water fill cycle for your waher is the clean cycle.it will fill up with 2x the normal amount of water in this cycle than any other.look for a cut or wrinkle in your door boot(grey rubber outer ring that seals between door and boot)if you find one,only fix would be to replace door boot.also clean inner door glass that comes in contact with door boot ring,any hard water build up or sediment(dog,cat or human hair)will break the seal and allow it to leak.good luck
Posted on Sep 26, 2008
SOURCE: Whirlpool Duet Washer Leaking
For those wondering about replacing the water inlet valve - this is a very simple undertaking.  You can find the part online for around 40 bucks.  All you have to do is unplug the washer, detach the hot and cold supply hoses, remove the lid (3 torx bits on my model) unhook the water line from the old inlet valve (conveniently accessible at the top right of the unit from the rear), unhook the electrical connections (be sure to label these for later re-attachment), unscrew the 1 screw holding the valve in place, and reverse the process with the new valve.  I'm hoping this will stop water accumulating in the drum - I'll update later if it does not.
Posted on Apr 11, 2009
jsrock516
  • 5911 Answers
SOURCE: whirlpool duet washer leaking water
If the washer is leaking around the door area, more than likely the bellow (rubber seal) is ripped or torn. If you pull back the rubber folds in the bellow and inspect, you may find a rip or tear causing your leak.
Another cause can be the rear bellow clamp (clamp that is affixed to the front of the wash tub) can come loose causing a leak between the bellow and tub. All you may have to do is tighten the clamp if this is the case.
The dispenser tube on the left hand side of the door, if not seated through the rubber correctly, can also leak during the fill or rinse cycles. The tube should be inserted through the rubber in the bellow to the flange on the tube. If not, water can fill behind the rubber and drip into the bottom washer casing.
The following link explains how to access and/or replace the the door bellow on a Whirpool Duet:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com and repairclinic.com carry the bellow. All these sites offer competitive pricing, so shop all of them for the best deal.
If you have any questions, or require addtional assistance, please let me know. I hope this helps you. NOTE: The bellow can also become mishapened over time after frequent use. This can also cause leaks around the door. Look to make sure the bellow is sealing around the door glass. If not, it should also be repalced.
Posted on Jul 30, 2009
  • 410 Answers
SOURCE: Whirlpool duet Sport wfw8300sw02, is a piece of
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you
go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Dec 04, 2009
Washer is leaking large amt. of H2O from the door, how can I stop it?
This is usually a blocked pump etc.
http://www.ehow.com/how_4915242_troubleshoot-whirlpool-washer.html
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Service and repair manual above, use to fix it.
Apr 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The drum seems to have become detached from the inside and has been scrapping against some plastic
The support bracket on your inner tub has probably broken. It involves replacement of the inner tub (drum) and probably the outer tub depending on the extent of the scraping. The parts will have a 5 year warranty, but the labor/service charge is your responsibility. Labor can be a bit pricey because of the extensive labor involved.
Feb 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer rocks and will not stay put. Perfectly level
check to see if the shocks are broken, 4 of them. A service guy fixed mine with new ones
Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Not enough water in a front load washer.
Water levels adjust automatically to the size of the load - no guesswork and this conserves water. If this is really a problem she should see if her warranty is still in effect and contact a service tech to check it out. She can also check with Whirlpool customer service - http://whirlpool.custhelp.com/app/answers/list
Jul 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer not spinning
It's not really a solution but I checked my paper work from when I purchased the washer and found out that I got the extended warranty, so I have called in a service call.
Jun 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet squeaks
you can call whirlpool at 800-253-1301 and they will set up and recommend a service company that is authorized to repair your unit. just let them know its less then a year old and they will get you taken care of.
squeaks are hard to find, but you need to get it set up before your warranty runs out.
Jan 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The door on my Whirlpool duet sport won't close / lock ..
its best if you call whirlpool to set up service call. tampering with your washer could void the warranty
Dec 16, 2008 | Whirlpool GHW9400 Duet Washer
Whirlpool duet frontload washer leak
a quart of water over the course of a cycle is pretty significant, other then trying to remove the fabric softener section looking for a blockage in the dispensor(which is basic and should be real evident ) theres not much more for you the consumer to look for.(or should you have to for that matter its why you bought a NEW appliance). As for the service , you've purchased a Whirlpool product, therefore you can call any whirlpool authorized Company out to service you dont need to wait for Sears!!!!!!!
Mar 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer leaking from bottom back..
sounds like you need to check your back drain could be the drain is clogged.Fill with water and see if it comes from the drain
Nov 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
121 people viewed this question
Dan Webster
Dan Webster
Sal De
