Question about Radio Communications
Schematic for altai eme7600 power echo base mic
Need schematic
3 Suggested Answers
tparsenault
  • 170 Answers
SOURCE: Diesel #8-32 echo power mics
cobra 4 pin is pin1= shield, pin2= mic audio (usually the shield is wrapped around the mic audio wire).pin 3= transmit or push to talk usually red or white whichever isnt wrapped with the shield, and pin4 = receive or speaker complete
5 pin cobra=1-Audio 2- Shield 3-Receive 4-Switching Wire 5-Transmit, you can jump pins 4 and two
Posted on Dec 28, 2008
highspeedsan
  • 61 Answers
SOURCE: how to wire a power echo mic up theres 5 wires and 4 oins
I suggest buying a 5 pin to 4 pin adapter. Ebay has them for $6. I would go chopping wires on the mic. Cobra 29 ltd is a nice radio. Have one myself.
Posted on Apr 25, 2009
I need wire colors for CB microphone its a TRC
ALTAI PWR MIC - black/braid= earth, red=RX, white=TX, Yellow=MODASTATIC - blue/braid=earth, black=RX, red=TX, white=MOD, Yellow=Spare
SIRTEL ECHO MIC CBE 2002 - black/braid=earth, blue=TX, white=RX, red=MOD007 POWER MIC - brown/braid=earth, green=RX, white=TX, blue=MODSADELTA EC 980 - braid=earth, green=RX, brn=TX, white=MOD
or braid=earth, black=RX, blue=TX, white=MOD
Oct 30, 2016 | Radio Communications
I need a schematic for a LT2 echo board to install in my president grant PC-409AB
break audio line. J2 input goes to mic pin J1output to radio.
(leave the shielded ground wires disconnected. on audio)
Power use a 1k ohm resistor from 12v dc on pwr switch.
Ground run the ground wire to board ground
test and set echo level.
this will work for any radio. if the echo needs 12v instead of 8v remove the 1k resistor and just use a 1n4001 diode on the power wires . some models require 12v some are 5-8volts.
Jan 18, 2015 | Radio Communications
Superstar dm 452 mic wiring
The 19style radios use Electric condenser mic elements. just be aware if audio is low its the input impedance ....
1 shield
2 audio
3 TX
4 RX
Feb 09, 2014 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Echo wires diagram
why waste your money on an echo board .you should buy an echo chamber . They operate on the outside of the radio so people that don't know how to wire one in can still have one.the echo board should have come with schematics,if it didn't you may have to google it to get the schematic you need.
Jan 16, 2014 | Cobra 148 GTL 120-Channels Base CB Radio
Is the wiring for mic same on superstar 121 as galaxy echo base
As I see it they are the same .The schematic for both radios show the same contact points in the radios so I would assume that the one mic would fit both radios .
Jan 16, 2014 | Radio Communications
Feedback problems with astatic echo boards
This is a classic indication of a lost shield or ground connection in the mic circuitry. Double check these connections for good contact in the mic *and* the plug at the other end of the cable.
Check the grounding and SWR or "match"of the antenna system, too. A poor SWR (greater than 1.5:1 or 2.0:1) can cause the reflection of RF back to the radio. Modifications can increase sensitivity of the mic to this unwanted RF.
Sep 29, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Would like info on wiring dm 452 echo mic on icom 400 pro
There is a users group on yahoo that you could join and ask your question. I am not too familiar with this radio and this is the best I could do...
Jun 23, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Cobra 200
Hello Jim. These radios do not work well with any power mic including the power echo mics because they have good modulation boards in them. But if you still want to try then check http://www.cbtricks.com/radios/cobra/200gtl_dx/index.htm
Mar 26, 2008 | Cobra 200 GTL DX 4-Channels Base CB Radio
We need a wiring Diaghram for a Realistic TRC 495 Echo Mic.
You can download it at CBtricks.com ....hope this helps....
Dec 08, 2007 | Radio Communications
Radio Communications Logo
74 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
