Question about Canon PIXMA MP960 Printer
Mp960 clogged head - Canon PIXMA MP960 Printer
Nozzle head blocked been through all the procedures to try and unblock
The nozzles are block, this is cause be periods on non use. The print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 18, 2011 | Canon PIXMA MP960 All-In-One InkJet...
Tip
Drivers and Manuals for PIXMA MP960 Windows and MAC OS
Here I will show you where to find drivers and manuals for the Canon Pixma MP960 photo all in one printer.
Drivers for this printer are available for Windows 98, windows ME, windows Xp, Windows Vista, windows vista 64bit editions, windows 7 and windows 7 64bit editions.
On the Mac side drivers are available for Mac OS X 10.2/10.3/10.4/10.5/10.6
A full on screen manual, quick start guide and other instructions are also available.
To download these drivers and or documentation for your printer please visit
THIS PAGE
Note that the picture below reads mp730 but the actual page linked will be for MP960
1. Click on Drivers & downloads
2. Select your OS ( Operating system, windows, mac etc )
3. All available drivers, documents etc will be available below.
For some of the documents a PDF reader may be required to open and read / print them.
To obtain a PDF reader, read this page
PDF Documents. Pdf reader(s)
Thank you for reading and I hope your printer is up and running again.
-Ekse
on Mar 11, 2010 | Canon PIXMA MP960 All-In-One InkJet...
Mp960 color prints ok but black and white not printing
When was the last time you printed in color? New ink printers are built so with a "use it or lose it" theme. The print heads are now built into the machines and are not generally replaceable. Yours luckily is, but I don't know how easily. The link below is to the replacement which costs $130 + shipping. Sometimes it can be just as worth it to buy a new machine, in this case I would probably prefer to repair the damaged machine as the new printer cartridges cost more and have less ink.
Feb 16, 2010 | Canon PIXMA MP960 Printer
Error code 6A00 print head not moving. Sometimes
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Nov 18, 2009 | Canon PIXMA MP960 Printer
Language change
You can change the language by using the control panel on the top. Go to Settings/Device Settings/ Language.
Apr 19, 2009 | Canon PIXMA MP960 All-In-One InkJet...
Incorrect color matching
probably its print head, it is you that changes its like the ink cartridge .
Dec 21, 2008 | Canon PIXMA MP960 All-In-One InkJet...
U052 error
UO52 error is either a print head temp sensor error or faulty EEPROM data from the print head. You need to re-set the print head. If that fails then a new print head is required.
http://www.tradebit.com/filedetail.php/4588590-canon-pixma-mp960-printer-service-manual
Complete Pixma MP960 service manual from Canon
Sep 24, 2008 | Canon PIXMA MP960 All-In-One InkJet...
Canon PIXMA MP960 Printer Logo
23 people viewed this question
old marine
old marine
