Question about Breadman TR2500BC Bread Maker
I can't get the paddle out of the pan. What is the paddle removal key
How do I get the kneeding blade out of the bread machine?
soak the paddle in soapy water overnight with enough water to keep the paddle submerged. The next day wiggle it back and forth while holding the litte ears underneathe the pan. Move it up and down too. If it still doesn't break free go to you tube and type "how to remove a stuck bread machine paddle" have your husband do that move, but don' use more than one jug of water because the TBR15 pan is thin and can bend. Be sure your husband uses hot pads to hold the pan edges so he doesn't hurt his fingers. If that method doesn't work you will have to live with a stuck paddle or order a new pan assembly and paddle and then always remember to remove to soak your paddle after baking and remove it from
the stem, clean, and store. Daryl,,, from breadmachineshelp.com
Feb 26, 2013 | Toastmaster TBR15 Bread Maker
I can't remove the paddle from the pan to clean . Is there a tool to pull the paddle/blade out ? I can't get a good enough hold of it.
If a paddle is left on a machine after baking, and is stored that way then the paddle can be almost impossible to remove if not impossible. If it is not stuck too badly then the method showed on youtube might work. Go to you tube and type in "How to remove a stuck bread machine paddle" But again if it is badly stuck even that method may not work. Let me know if it works or not.
Jan 08, 2013 | Oster Deluxe 2-pound Bread & Dough By...
My bread pan doesn't sit correctly so the paddle doesn't move around well, especially when it kneads faster
First pull the springy steel clips out so they bend some and stick out a little further this will hold your pan in better. Before putting your pan in make sure the little ears on the underneath side of the pan are lined of roughly opposite of the pan ears in the bottom of the oven that push the paddle around. If that doesn't make sense contact me.
Oct 01, 2011 | Cuisinart CBK-200 Bread Maker
Re Black & Decker Bread Maker: Most of the time the paddles remains stuck in the pan and the bread sticks to the paddles. As a result, loaves usually have large chunks torn out of them. There are...
Hi, Take the paddle out of the machine at the end of the last kneading cycle and before final rise.. Use pause or take pan out of machine to remove paddle. OR... spray the shaft with a small amount of olive oil. This should allow paddle to come out when bread is done. You will have to fish the paddle out of the bread in this step. Hank
Oct 31, 2010 | Black & Decker B2000 Bread Maker
Drive shaft no longer turns kneading blade on model k6725
Either the paddle is frozen in the bread pan ( take pan & paddle out of machine and see if you can turn it by hand), or the belt has fallen off or has snapped. (Keep the bread pan out of the machine & run a knead cycle, look through the lid window and see if the motor shaft spins. Hank
Mar 05, 2010 | Regal Ware Kitchen Appliances - Others
Can the kneading paddle be removed before baking?
Yes you can remove the paddle before baking. The cuizinart has a buzzer that sounds when to take the paddle out
If you want to take the paddle out you should make sure your machine has a pause feature so you don't lose any rising time.
Take pan out of machine, empty dough into a bowl, remove paddle, squirt the shaft in the bread pan lightly with veg oil (prevents sticking) then return the dough after final kneading time and before final rise.
Hank
Aug 26, 2009 | Kitchen Appliances - Others
Removing finished bread from pan
Before the baking cycle begins,remove the bread pan ,shake out the batter onto a piece of waxed paper,remove the paddle from the bread pan,place batter back into the pan,close lid.This way you only have a small hole in the finished loaf. I prefer the 1.5 pound rye bread,and set a kitchen timer for 2 hours 5 minutes-when the "shape" cycle finishes,we remove the paddle.
This is listed in my manual on page 76,item # 7;heading is METHOD.
Front of the manual lists the times for the cycles,just add them up.
(When you dump the batter back into the pan,try to pat down the rough edges,it looks better).
Nov 04, 2007 | Breadman TR2500BC Bread Maker
Blades stuck inside bread
Unfortunately trying to stick the paddles in the pan just tends to leave half the loaf in the bottom with them. The best method i have found is to cut the crust around the outside of the paddles, carefully avoiding the bit where the actual paddle blade is, then you insert a rod into the centre of the paddle and tilt it towards the blade. They normally come free pretty easily. Another method you can use if you are around the machine when it is making bread, is to remove the paddles at the end of the mixing/kneading cycle, just before the baking cycle starts. Most machines have a small pause allowing you to do this - sometimes with a "beep" or screen message to tell you that you can do this. Sorry i couldn't find the exact info for your model, it will vary for different baking programs also. If you check the cycle to determine at which stage it starts actually baking, then you can do this quite safely so long as you are careful of the machine heating up while you are removing the paddles - usually you would have around 20 minutes at least to remove the paddles before baking. Hope this helps :)
Apr 11, 2007 | Black & Decker B2000 Bread Maker
Breadman TR2500BC Bread Maker Logo
62 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
