Question about Comfort Zone CZ-530 Compact Heater
No heat but I do have power - Comfort Zone CZ-530 Compact Heater
  • Comfort Zone Master
  • 8,220 Answers
You mean no fan ? Probably needs some oil on the motor. Use non-flammable Zoomspout oil from ace hardware.
Posted on Oct 28, 2012
Color code for theromstat
Wiring Examples and Instructions
How-To-Wire-It.com
Basic or Common Connection Points
Terminal Colour Signal-Type Description C Black 24 Vac Common Common side of 24 Vac Transformer See Diagram below R or V red 24 Vac Transformer Power Power side of 24 Vac Transformer See diagram below RH or 4 red 24 Vac for heat 24 Vac power before heat switch see diagram below Rc Red 24 Vac for cool 24 Vac power before cool switch see diagram below Y Yellow switched power (cooling) Signal to turn on cooling system see diagram below W White Switched power (heating) Signal to turn on heating system see diagram below G Green Switched power for fan Signal to turn on fan (forced air) see diagram below
Heat Pumps/Multi-Stage Units
Terminal Colour Signal-type Description Y2 Can vary Switched power (2nd stage cooling) 2nd stage cooling signal to compressor W2 Can vary Switched power (2nd stage heating) 2nd stage heating/ sometimes used as emergency heat E Can vary Emergency heat enable Dedicated emergency heat 0 Orange Reversing value Reversing dynamics of the heat pump ----
Nov 22, 2015 | Honeywell Digital Round Thermostat,...
The unit dosn't heat
Check heater element has power. And also setting temp must be minimum 3 degree + than room temp, with heat mode. If RV system, check power to RV. If not PCB problem. If power to heating element, still no heat, replace heating element. Thanks.
Jan 27, 2011 | Fedders AEY18F7G Y Chassis Heat/Cool Room...
My heater just stop working by himself. HWhat can I do to fix it ?
Check temp setting, mode and then power to heat. Please follow the tips:
To get proper heat, keep your temp setting at +5 degree than your temp and also mode in "heat "position. If still noheat, check your heating sensor for closed circuit by an OHMs metre.It it'swith RV, check power to RV.Ifit's with heating element check power to element. If power is there but stillno heat means element defective. Replace new heating element. And also check heat temp sensor. Thanks.Helpful?
Jan 20, 2011 | DeLonghi Heating & Cooling
Not blowing hot air
To get proper heat, keep your temp setting at 30+ degreeand also mode in "heat "position. If still no heat, check your heating sensorfor closed circuit by an OHMs metre.It it's with RV, check power to RV.Ifit's with heating element check power to element. If power is there but stillno heat means element defective. Replace new heating element. Thanks.
Jan 14, 2011 | Amana PTC123B50AJ Air Conditioner
No heat from the unit just blowing cold air.
Jan 14, 2011 | Carrier 52CE215 Cool Electric Heat Air...
Kenmore model 58072187300 a/c and heat window unit. When I Set on heat , i barely feel the air get warm.
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heating element check power toelement. If power is there but still no heat means element defective. Replacenew heating element. Thanks
Jan 10, 2011 | Maytag M7Y15F2A Air Conditioner
No heat only cold air
Check your unit whether it has heat model or not.
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Jan 04, 2011 | Heating & Cooling
Carrier 52CE set on high heat; blows cool air
Jan 04, 2011 | Carrier 52CE-309 Cool Electric Heat Air...
Heat pump, no energ, in heat mode
Jan 03, 2011 | Heating & Cooling
The heater don't get hot
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RVIf it's heating element Check power to that. If power is there, no heat, replace heating element.
Dec 31, 2010 | Heating & Cooling
Comfort Zone CZ-530 Compact Heater Logo
124 people viewed this question
Top Comfort Zone Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
