Question about Refrigerators
GE TPG 24 PRDB BB: how to adjust wheels for leveling?
2 Suggested Answers
hiltonjug
  • 612 Answers
SOURCE: we cannot find the drain in our GE side by side
Pull unit away from wall, take panel off the back so that you can see the compressor. You will find a pan close to the compressor. The drain drains into this pan. You can take a turkey baster, fill it with water. Blow the water into the drain. This will unclog the drain.
Note.
If ice is building up on the inside lower back wall of the freezer, you have a defrost problem. If so it most likely will be the heaters behind the inside lower back panel. They are easy to replace. You can find them at www.partselect.com . You will need to enter your model number (without the spaces and also without the BB at the end) this will bring up a break down of your unit. You will not only be able to order the part, you will also be able to see where they are located inside the unit.
Posted on Oct 13, 2009
Testimonial: "Great ! just what I needed. Thank you very much. kind regards Cyndie"
My ge profile kitchen range's timer is not loud enough to hear across room.does anyone know how to adjust it? also,how do adjust from 24 hr.clock to a 12 hr.clock?brenda
I don't think the sound level can be adjusted. I suggest looking up the owners manual and it should give you direction on the clock. The manual will also list if you can adjust volume. good luck
May 18, 2016 | GE Kitchen Ranges
HOW TO ADJUST BOTTOM BLADE OF MY GE PROFILE DISHWASER
What do you mean "bottom blade"? Do you mean the lower wash arm? There is no "adjustment" built into the dishwasher, but if it's hitting the heater element (or its supports), you might be able to bend it slightly. If it's hitting the lower rack, make sure your rack has all of its wheels attached, and that it's not bend down.
Sep 25, 2014 | GE 24 in. Profile PDW7800 Built-in...
Should my dishwasher drain completely after its done washing
Yes it should if it doesn't make sure the dishwasher is sitting level if not adjust the little legs under it to make it level
Jul 28, 2013 | GE Nautilus 24" Built-in Dishwasher
How do i lower the front of the refriderator so that the door doesn't swing closed while I have it open. It has wheels....do I screw the wheels in more?
There will be adjustments under the refer that can be adjusted
Just be sure to keep the whole unit level
Yes yours may be adjustable on the wheels
Apr 01, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
We cannot find the drain in our GE side by side fridge freezer. Their is ice accummulating on the floor of the freezer side and although we think this may be due to a blocked drain - we cannot find it !!...
Note.
Oct 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25LGMF BB refrigerator freezing everything. Refrigerator is set on 1, still freezing.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 01, 2009 | GE GSS25LGM Side by Side Refrigerator
I have a ge nautilus built in dishwasher and do not know the model number it is 7 years old and came with house. need to replace and am unsure of dimensions for correct sizing on new purchase
You can find them on a label on the tub wall just inside the door. However 99% of all DW are a standard size and the difference is made up by adjustments of the threaded leveling /adjustment legs.
Standard size is 24" x 32-36"...you can take a tape measure and measure from the floor to the bottom of the countertop it is to be installed under...and then measure across the front of the DW. you should find my measurements to be within this range unless it is a custom unit.
Hope this helps. ...good luck and good day...The Fang
Mar 18, 2009 | GE Nautilus 24" Built-in Dishwasher
Refrigerators Logo
101 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
