Question about Dacor DCM24 Convection/Microwave Oven
Dacor dcm 24s one broken safety door latch- door open button not
Back plastic (one) safety door latch is broken- found piece-now door cannot be opened as door open button is not operational- it is not engaging. Furthermore this microwave sits atop open in an extremely snug fit- I attempted to pull it out without nuch success. I also attempted to find an L shaped slim non-scratching tool which I could slide up to attempt to disengage the second safety latch. I made sure that the lock was set to off. No success.I do not want to do further damage- Do I need a service call?Is there a simple way to get the door open and then repair the latch and probably open button attachment- ? spring or whatever. Help
Thank You
  • kevin luces Jan 04, 2009
    will likely call for repair-unfortunately I do not like to reveal my credit card info on the net like this,if there is another method to pay please let me know.
    Thank You
  • Anonymous Feb 09, 2009
    Have door open, but unclear how to take frame of door apart?
  • Dacor Master
  • 9,086 Answers
Sorry, but you will need to remove the oven from the wall or mount, then the outer cover will need to be removed.
We have the full service / repair manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
In Canada, you can find Dacor parts at these distributors:
Reliable Parts, Ltd
85 North Bend Street
Coquitlam, BC V3K 6N1
604-941-1355
Eatek Services
312 Benjamin - Hudon
St. Laurent, Quebec H4N 1J4
514-332-0007
If those don't work for you, you may find others via this page.
Posted on Jan 03, 2009
  • William Miller
    William Miller Jan 04, 2009
    If anyone asked for your credit card information, it was not me. So I'm not sure what you mean.
    I also listed the phone numbers of the parts distributors so you could call them.
    Oh, I also meant to show you this info on getting the door apart,
    besides what's found in the service manual I linked for you above:
    DOOR DISASSEMBLY
    You have to separate the door panels (as shown in the attached photo)
    and then you'll see the previously hidden screws you need to remove.
    Or you can watch a YouTube video (not a video I
    made) that demonstrates how it's done.
    We're
How to repair kitchen aid door springs
proceed according and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Nov 01, 2013 | KitchenAid Microwave Ovens
H5460NO/01 door lock is not working
test this steps and fix it. God bless you
Oct 27, 2013 | Microwave Ovens
I'm unable to open the microwave door on model Sanyo EM-S8586W as it appears the spring is broken. How do I remove the cover so I can replace the spring please?
make this steps and fix it. God bless you
Oct 26, 2013 | Sanyo Microwave Ovens
How do you open the door
see this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#11#ixzz2YvqJdpSm
Jul 13, 2013 | Siemens HF17055GB Microwave Oven
The door doesn't open
please follow the instruction and fix it. God bless you
May 28, 2013 | Cuisinart Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
I have an Oster DLC-7 food processor. It has always been very hard to close requiring force. The last time I used it, a white plastic part popped off from the back. I don't know whether anything is...
You have a broken the door latch.Most people have the habit of slamming the door shut ( the same way some people hit the enter button on the computer ).With age the plastic becomes brittle and the slamming accelerates its demise. Now connected to this latch is a safety feature which shuts down the Microwave when the door is opened during cooking. So till you replace this latch the microwave will not work. Disconnect the microwave from the power outlet and remove the top cover ( 4 to 5 screws at the back ) , look near the bottom close to the DOOR OPEN button.You will see the rest of the latch with a spring attached to it.Do not attempt to glue the broken piece because the force exerted on the latch is very high and will not hold. You challenge is getting a replacement. Best would be to contact the seller or locate a authorized service center from where you might be able to procure it. It should cost you about 5$.
Aug 22, 2011 | Microwave Ovens
DCM 24S Dacor microwave. Clock, fan and timer work, but the turntable does not turn and food is NOT heated.
That would be a problem with the secondary interlock (bottom door switch) or its mount.
See our help file: http://031d26d.namesecurehost.com/mwd/doorsw.txt
We have the service manual and have uploaded it to our site here to help you.
Jun 06, 2011 | Dacor DCM24 Convection/Microwave Oven
If the broken part is in the door, you will not have to pull the oven out of its place.
If the broken part is in the door open button area, you will have to remove the oven and take off the outer cover. Chances are it will be a broken "door open lever".
Assuming it's a door latch, you can use a thin strip of plastic to open the door.
It has to be somewhat firm but very flexible because it will have to bend at a right angle.
I have a flexible ruler I use for this.
You have to first shove the plastic strip into the crack between the door and the control panel frame about halfway up the door.
Then the strip will need to be maneuvered so it will bend to the left. Do this by pushing the rear end of the strip down as you continue to push it forward.
It may take a few tries.
Once you have it between the back of the door and the front seal of the cooking cavity, pull the strip straight and firmly up and it will lift the upper door latch and the door will open.
(If the upper latch is the one that's open, you have to start with the strip at the bottom edge of the door instead of the middle).
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly and troubleshooting tips, and the parts list is here.
Most computers will open these documents automatically, but you may need the free Adobe Reader.
You can order parts
here.
Once you have the door open, you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Jun 03, 2009 | Dacor DCM24 Convection/Microwave Oven
Dacor DMO24 microwave oven door stuck
What usually breaks is the door open lever.
On an over-the-range model, only the control panel needs to be removed. Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
Dacors are made by Sharp, and one of these service manuals below may help you.
http://www.microwavedisplay.com/r530es_sm.pdf
http://www.microwavedisplay.com/R530EKF_R530ESF_R530EWF_sm.pdf
http://www.microwavedisplay.com/r530bk_bw_sm.pdf
To order Dacor parts, I recommend you visit http://www.apdepot.com/index.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 22, 2008 | Dacor PCOR30 Convection/Microwave Oven
Dacor DCM24 Convection/Microwave Oven Logo
606 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
