Question about Epson Office Equipment & Supplies
Epson L110 resetter
My Epson L110 printer says i need to reset the ink pad, i bought the printer last week and i need a resetter
SOURCE: Epson R230 ink & Paper Lamp Blinking
my epson stylus photo R230 Printer problems always
two red light blinking
please help me
thank you
Posted on Feb 16, 2009
SOURCE: Need To Replace The Waste Ink Pad on my Epson Stylus C66
I modified a little what Worldvet had done. I opened the door as if to change the ink cartridges. I first used a pair of needle nosed pliers and carefully took out the sponge type pad which is along bottom of the printhead travel lane. One will see the two center plactic guides within this lane. The sponge is very delicate, so be very gentle in removing it. It has ink residue in it so use gloves if necessary and upon removal place the sponge on a paper towel folded in triplicate so the ink does not bleed through the towel. Remember to what position it was before removal, so there is no problem when you try to replace the sponge after cleaning.
The second sponge I removed as follows: With the power on, I pressed the ink cartridge removal light (red) (far left) once. This moved the print head to the "far left", before the position to change cartridges. With the power still on and the printhead to the far left, I was able to very gently (with the same needlenose Pliers) remove the sponge under where the printhead was parked. It too is very delicate and be careful not to rip it. It too, one will find, has two plastic slots on the botton which the sponge will have to be returned into. I then turned the printer off, which caused the printer head to return to the parked position.
I took both sponges, and with Alcohol (Pharmacy type), I placed the sponges in a disposable plastic bowl and filled it with the alcohol. I gently used the needle nosed pliers (Closed) as a device to gently press on the sponges which were submerged into the alcohol. I continued to alternate up and down the sponge pads, causing the alcohol to dilute and clean the pads. When the alcohol became saturated with the ink from the pads, I took the pads out of the alcohol bowl and placed the pads on a triple folded paper towel so the remaining ink would not bleed through anything.
I then took the bowl of alcohol/ink and while I flushed the toilet and the water was going down, I emptied the alcohol down the middle of the water spout as the toilet water was completing its flush. This keeps any ink from touching any porcelion.
I then refilled the plastic bowl again with fresh alcohol and resubmersed the pads, just incase there was any ink still left in them. Upon pressing on the pads and the alcohol remained clear (indicating all the ink was removed) I again used another set of paper towels, trippled, and placed the pads onto the paper towels, and squezzed them dry. I disposed of the alcohol the same as before.
I then, first replaced the large pad onto the printhead travel lane, back into the same position, being careful that the holes and slots fits back into its proper position and the edges are tucked under the proper hooks (little plastic hooks attached to the side of the travel lane).
Upon reinstallation I pressed gently on the pad to make sure it was secure.
Replacing the second pad, I again turned on the printer and pressed the ink replacement light (red), same as before, causing the printhead to travel to the far left as before. I then very carefully replaced the second pad into the slot from which it came from.
After I made sure the second pad was secure in its proper position, I pressed the ink replacement light twice, causing the printhead to return back to the parking position. I had already reset the counter, so that was not neccessary. I returned to the computer and printed a test page to make sure the printer was working properly, at which time it was, so I therefore returned to what I was doing and the Service Warning was cleared. My fingers got a little ink; but what the heck, soap will take care of that! Good for another 20,000 pages. Hope this helps, not as bad a it sounds.
Posted on Mar 26, 2009
SOURCE: epson pm210 printer waste ink pad resetter
we want service requaired for pm210 printer
Posted on Sep 01, 2009
tigertail
  • 163 Answers
SOURCE: waste ink pad saturated. EPSON STYLUS PHOTO R360
Replacing the pads is costly, messy and requires the printer to be taken completely apart. If you have little or no experience of stripping down printers it is best left to a proffessional. Contact Epson to find your nearest service centre, but remember to get a quote as it may be more economical to replace the printer. Sometimes the counter can "jump" to the end of life number, this especially happens where 3rd party or refilled inks have been used. If you believe this to be the case and there is no sign of ink leakage and the pads look fairly clean then you can just reset the counter using special software called the SSC utility. See these sites:
http://www.ssclg.com/epsone.shtml
http://inkjetprinterhelp.us/epsonSSC.html
More information about this issue and the "official" Epson resetter is available from the Epson web site, please read this link:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Please take a moment to rate this solution. Thanks.
Posted on Apr 14, 2009
websnail
  • 419 Answers
SOURCE: reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
Posted on May 12, 2009
End of service for epson wf 7610
If your Epson WorkForce WF-7610 printer shows error message "The Printer's Ink Pads at the end of Their service life" and Epson WorkForce WF-7610 printer has a red light blinking problem: You should be download and reset Epson WorkForce WF-7610 printer Waste Ink Pads Counter with Epson WorkForce WF-7610 Resetter.
Go to this link, you should be able to download the resetter and follow the procedures step by step.
Reset Epson WorkForce WF 7610 End of Service Life Error message Wic Reset...
Jul 22, 2017 | Epson Office Equipment & Supplies
I need resetter for Epson L110 ink pad need to
hi my printer epson px660 displays a message that the printers ink pads are at the end of their service life what should i do
Aug 02, 2013 | Office Equipment & Supplies
Ink pad resetter for epson L110.. please help me..
The L110 needs the WICReset utility to reset the waste ink counter and a key to do that too.
I believe the WICReset tool will also reset the ink levels without needing a key so if you can source the necessary bulk ink locally you should be able to get printing again.
Aug 02, 2013 | Epson L100 Original Ink Tank System...
Communication error 21000068 when resetting my epson t60
i want to resetter my epson stylus printer t60 ink pad counters
Mar 30, 2013 | Epson STYLUS PHOTO T60 INKJET PRINTER
Epson l110 waste ink pad
hi
I want a free software to download to reset my printer and I tried in SSC Service Utility v4.30 but software don't have epson L110 model so, please help me to find right software to reset my printer. Thank you
mr.mehdihassani@yahoo.com
Nov 01, 2012 | Office Equipment & Supplies
EPSON STYLUS T13 printer's ink pads are at the end of their service life HOW TO RESET FREE
Apr 26, 2011 | Epson Printer
My epson 700w has a message that ink pads are needing replaced and to contact epson. The printer has not been used a lot and I don't know who to contact to sort out the issue
you need to reset yung printer but first you need to replace the waste ink pad inside the printer. or put a wastebin outside the printer.
here's the instruction and the resetter to reset your printer
http://pcmediks.blogspot.com/2010/09/epson-photo-tx700w-resetter.html
Dec 18, 2010 | Epson Stylus Multifunction Inkjet Printer/...
5,156 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
