Question about Casio Exilim EX-S500 Digital Camera
White lines on screen
Dropped my camera and now when I turn it on the screen is mostly white in horizontal bars. The little you can see of the screen is not in focus. It will still take a picture though. Removing battery & charging on cradle have not helped.
    Genius:
  • 2,985 Answers
Contact the maker to ask about repair- but as you have damaged it, its a slim chance. I joke not when I say - drop it again -it may just jerk it back together- any way you can break it worse,
Posted on May 14, 2007
Get the blue and white lines of my screen
you can go to the service center may be your display is not working properly
Sep 13, 2013 | Fujifilm Finepix Hs30exr black Digital...
Last night I turned my Polaroid TLX 04244B off, and had zero problems. This afternoon, I have a 6" pattern of horizontal lines across the right hemisphere of the screen. They come and go, darker...
You are probably seeing hum bars which may be due to an AC ground loop that is going through the shields of one or more of the cables inteconnecting the TV with one or more of the other video components. You should do the following to try to resolve it...
1. reseat all the interconnecting cables between TV and other units
2. have all AC power supplied by one power bar with a ground plug
Mar 17, 2011 | Polaroid 4241-TLXB 42 in. LCD Television
Hi i dropped my camera and now the screen does not come on and also it has a little white line on the screen..looks like a little crack in the corner
Hello
OK, firstly you will need to determine weather the camera itself is still taking photos. If so, then the problem is most likely a an internally cracked LCD. If the lens extends once you turn on the camera, we know the lens still works. If you can see any power indication, we know that the circuit is still working, hence the only fault can be with the screen.
So, follow the steps above to determine if the other components is still working, if it is, you will be able to replace the LCD screen at your nearest camera repair store for less than $40 labour included.
Please feel free to let me know if you need any further assistance.
Kind regards
Lock123
Feb 07, 2011 | Sony Cyber-shot DSC-T300 Digital Camera
I have a FujiFilm S5000 and since 2 weeks the sensor seems not to be able to adjust when trying to take a picture in sunny condition. The screen shows white and pink colour with horizontal lines. I turn...
Actually it's not the sensor it's the LCD screen. I would say in the last two weeks the camera didn't change but the environment it is being used in has and is causing the camera to overheat.
Diagram
Temperature
Diagram
Keeping the camera within these perimeters should solve your problem.
Jan 18, 2011 | Fuji FinePix S5000 Digital Camera
My tmobile dash lcd screen.
im trying it now i will post again if it works thanks
Jun 23, 2008 | HTC S620 Smartphone
3 INCHES HORIZONTAL LINES ON SCREEN
i have a whie line going horizontal all the way across the sceen. how do i get rid of it?
Apr 29, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Lines across the LCD screen
Two things can cause lines across the LCD either horizontal or vertically. The first (and most likely) is a small crack in the display wafer. LCD stands for Liquid Cristal Display. They are very fragile and can be easily damaged if dropped. I broke one in my pants pocket.
The second would be if a pin on the ribbon cable (to the LDC wafer) was not making good contact. If you disassemble the camera it is possible to clean the contacts using contact cleaner (or alcohol). Only attempt this is you are willing to replace the camera if you don’t put it back together properly.
Mar 11, 2008 | Sony Cyber-Shot DSC-P100 Digital Camera
How to fix horisontal lines on display ( see the picture)? They stronger when system is restarted and then fading but never disappearing. They always stay the same.
horizontal lines can be caused by either a faulty grapchics card or a faulty monitor. try adjusting the screen refresh rate. if you are using a windows xp system goto
start>control panel>display>settings>advanced>monitor
then adjust the screen refresh rate and see if the horizontal lines disappear. if not, then you probably have a faulty graphics card or monitor.
Jan 27, 2008 | XFX GeForce FX 5200, Graphic Card
Casio Exilim EX-S500 Digital Camera Logo
70 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
