Samsung hd103si usb device external not showing on disk management
5 Suggested Answers
SOURCE: I/O Magic external drive not showing up in computer
Had the same problem with the 120GM IOMagic. I removed the drive from the case, detached the circuit board leaving just the Hard drive and hooked it up to a cable I bought that allows you to read any hard drive through the USB post. Was able to retrieve all the data on the disk. The problem was the iomagic interface board.
Posted on Feb 08, 2009
JulesPCaut
  • 702 Answers
SOURCE: external hdd not detected in my computer but is in device manager
You probably still need to partition it, before you can even format it.
Try the disk manager in Windows.
In the start menu, right-click "My Computer" and in the popup menu, select "Manage".
One computer management comes up, select disk management and there you should see the disk. You can then create a partition and format it.
Jules
Posted on Mar 16, 2009
SOURCE: External USB Disk is installed but not visible under Mu Computer
Go to manage, refresh, and then asign a letter to it.
--- tuljo
Posted on Apr 27, 2009
SOURCE: Zippy USB external hard disk case (2.5
I know this is an old thread, however if it helps any one try this:
Zippys power supply failed for me also. The problem here is your case support USB 2.0 ("A high speed USB device") and your port is only USB 1.1 ("plugged into a non-HI-SPEED usb hub"). This will not give adequate power to the drive. So use a y-cable (http://www.toshibadirect.com/images/ui3/accessories/toshiba-usb-y-cable-ba82010-300.gif) and connect one end to your casing and the two pins at the other end should be connected to two USB ports. (get it at http://www.toshibadirect.com/td/b2c/adet.to?poid=438342).
Another costlier way is to upgrade to USB 2.0 by a card like this http://www.belkin.com/support/download/download.asp?category=1&lang=1&mode=
or even better a USB 3.0 card : http://www.asus.com/product.aspx?P_ID=lGYmelQ8mJvPtYTv
Posted on May 24, 2010
External 3.5 inch IDE hdd encloser connected via USB is showing "device is not ready" when try to initialise it in the disk manager
Check the jumper settings of the IDE hard drive you have in the enclosure for compatibility in your setup. (Choices are Master, Slave and Cable Select).
Feb 06, 2014 | Computers & Internet
I bought a new Sumsung G3 station 1.5tb external drive, it wont show up in my computer nor disk management. am using windows 7 64bit
Try Using the Samsung 64 bit driver update tool
http://driverwhiz.com/drivers-en?brand=Samsung%2064%20Bit&logo=Samsung&subid=1001-us-en-10000202160&gclid=COzGnv-mi6sCFSE95Qodyh2bvw
Jul 26, 2011 | Samsung G3 Station 1.5TB USB 2.0 External...
All External storage devices "USB Device Not Recognized"
Dear Sir,madam
You have to do some steps about fixing this problem :
1: Go to Device manager by right click on my computer then manage and then device manager.
2: Go to universal serial bus controller and export it.
3: in each USB root hub right click and then properties.
4: In properties screen select power management tab and unmark on " allow the computer to turn off this device to save power ".
5: After finishing this steps in each USB root hun restart your computer and then done
Jul 24, 2010 | Microsoft Windows XP Home Edition
External HD is not detected by laptop Windows XP
A common issue...I'm sure your hard drive is working fine, Windows is just not giving it an unused drive letter.
1. Insert the device (camera or usb drive)
2. Right-click "My Computer" and select "Manage".
3. Click on "Disk Management"
4. Right-click the item in the list that looks like your camera or usb drive, and then click "Change Drive Letter and Paths."
5. Click "Change".
6. Give it a drive letter that is not being used.
7. Click OK.
The device should work instantly after that.
Feb 09, 2010 | Western Digital Scorpio WD1600BEVS 160 GB...
Asrock K7VT4A will not recognise Samsung HD103SI 1gb sata drive, any advice would be appreciated.
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the external drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your external Drive to be detected automatically.
Hope this helps you out.
Nov 21, 2009 | Computers & Internet
My verbatim usb external hard drive quit working on only one of my computers. I tried using computer management but it doesn't recognize it there. it does show up as Toshiba in the device manager but...
The brand of your HD is Verbatim, so it should not show up as Toshiba in the Device Manager. Your computer is detecting another device.
Please do not rely on the Device Manager, you have to check the Disk Management instead. If the HD did not show up in the Disk Management, try connecting the HD into another USB ports of the problem computer. It could only be the USB ports of the problem computer is bad.
How many computers do you have? If you have 3 PCs and only one computer is having a problem, then you might need to update the USB driver of the problem computer.
Have a great day!
Sep 04, 2009 | Verbatim 160GB USB FireLite: The "drive...
No Hard Drive or USB Device in Disk Management
If you are running WIN98 the USB drivers must be added for they don't come with the operating system as in later windows. (from Win Me on up)
And too, some times if you connect your devices in the front they are 1.1 instead of 2.0.
try using the ports in the rear where (if) that is where they are working for the external drives and see if the pen drive is reconised
so it will install the drivers.
Hope this does it for you, good luck, please leave a rating, thank you kindly
Apr 26, 2009 | Computers & Internet
Seagate 250GB USB external harddrive was working now it is not. Cannot see it in Disk Management. In Device Manager, USB controllers the harddrive shows up as Unknown Device when I plug it in. In...
unplug seagae usb external h/d
Device manager>Under usb= ,uninstall the device.
run: RESTORE, choose the last check point, reboot,then plug in the h/d in your usb.
May 06, 2008 | Computers & Internet
Metal gear enclosure 3.5 box 2
Sounds like you haven't formatted the external Hard-Drive.
You need to allocate a file-system to the free space on your hard drive. You can do that in Disk Management and use the format option. You can select from two file system formats: FAT32 and NTFS. I would recommend NTFS because it is a journalling file system (recovers quickly in case of a crash).
Oct 20, 2007 | Galaxy External Enclosure - Metal Gear Box...
Computers & Internet Logo
412 people viewed this question
David Payne
David Payne
