Furnace blower fan make a loud humming sound but will not start
Fan spins freely when off, but when it tries to start there is resistance, i tried to give it a push to start, but it wouldn't
  • 1796 Answers
SOURCE: Furnace stopped blowing cold.
Hi!!
Replace motor fan and capacitor, it is a very simple task. Turn breaker OFF. Then all you have to do is remove about four screws from the top grill, about four more that fasten the motor fan assembly, unplugg electrical connectors and label them and install the new one and switch fan blades.
No special knowledge is required to perform this job. Cost: about $140 +-.
On the other hand, you call a HVAC technician, they supply the motor and capacitor, otherwise they won't give you warranty. Cost $300+. Look on the Yellow Pages for one in your neighborhood.
Good Luck!! Rate this post!!
Posted on Aug 13, 2010
pierre1811
  • 144 Answers
SOURCE: Air Handler Blower Unit Humming
More then likely it's the transformer. It may be getting weak. I've seen them hum/vibrate almost new and last for years. It's more an annoyance than anything.
Posted on Jan 18, 2009
  • 13 Answers
SOURCE: Carrier Furnance Fan / Blower Doesn't Start (Model 58GP-125-GA)
With power off, locate fan motor capacitor (generally silver in colour).
Rating on capacitor will be in microfarads at specified voltage ( 5mf @
370 volts). Be careful to discharge before handling and return defective
cap. to source of replacement. They can confirm whether or not truely
defective. Replace and secure. Restore power and check operation.
Purpose of run capacitor is to provide starting torque that you are
presently providing by hand spinning. Hope this helps.
Posted on Aug 05, 2009
SOURCE: my blower motor will not start. it hums and gets
Assuming you are spinning it when the motor is humming, if the motor runs after spinning it it could be the run capacitor (replace) or open/broken start winding in motor(need new motor). Humming should indicate the motor is getting proper voltage. If motor does not try to run by spinning then open run winding in motor (replace motor).
Posted on Aug 30, 2009
heatman101
  • 43501 Answers
SOURCE: blower motor won't start,but spins freely when not powered
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jun 03, 2010
Goodman clt60-1 fan not working loud humm
The hum is a good indication that the fan is getting power. Therefor, the fan is locked up or it has a weak capacitor. Attempt to spin while power is off. It should spin freely. if not, you will need to replace the motor. If it spins freely, I would attempt to spin the fan blade while it is humming. If it starts running fine, it is very likely the capacitor. If not, then replace the motor.
Sep 08, 2014 | Goodman Heating & Cooling
Central a/c fan will not start after flood
replace the fan motor as the bushes are dry and seized up.
Jun 09, 2013 | Heating & Cooling
I installed a new Broan QML30SS range hood and fan makes loud humming sound as it runs
An old elecricians joke says "do you know why it hums? It dosn't know the words" Al kidding aside ,have you checked to see how free the fan blade is? The should spin very freely. It kind of sounds to me like it may be having a hard time comming up to full speed. You may try some graphite lube on the motor. If I recall Broan has a lifetime garrentee on the motor. You might just want to repace it if I am correct.
Mar 02, 2013 | Broan QML30SS Pro-Style Under-Cabinet...
Rheem classic 80 fan motor on furnace hums will not turn on
Have you checked the capacitor? Try spinning the blower wheel by hand, if this gets the motor going you have a bad capacitor. If not, the motor will need to be replaced.
Nov 16, 2012 | Rheem Prestige 14 Series 2.0 ton 14 SEER...
Loud blower on my Coleman Furnace
Usually a noisy blower motor is a bad bearing. The motors now have oil impregnated bearings and you can't oil them, you have to replace them.
Sep 19, 2012 | Coleman Mobile Modular Home Electric...
Blower motor hums but wont start
Check motor capacitor and try spinnig blade or wheel to see if spins freely if doesn't then the bearings are bad in motor and needs replaced
Apr 09, 2009 | Heating & Cooling
Thermostat display has an image of a flame
Sounds like the circulating fan on your furnace is not running. This will cause the furnace to shut down due to overheating, and you can smell the overheating as well. You will probably have to press a reset button on the burner to clear the overheat shutdown. Check the fan belt if there is one. If no belt you have an integral motor. Remove all power from the system and make sure the fan spins freely. If it doesn't, try to work some oil into the bearings. These things always fail on a holiday, but if you can't get the fan spinning you're going to have to call in a HVAC specialist.
Jan 01, 2009 | Honeywell Programmable Thermostat Heater
Kitchen aid dry motor noise
Try taking it apart again and try to turn the motor by hand. It should spin freely. If it does you've probably got a bad motor. If it is stiff or doesn't turn at all, then you might have missed something putting it back together. I wouldn't think you can overtighten the blower, it is probably something else, and with it apart it should be easy to see.
Jul 21, 2008 | KitchenAid Dryers
Goodman GMP125-5 Air Handler
REPLACE BLOWER MOTOR
if its spinning free until motor is energized motor may have bad armature or brushes.
If you energize blower and manually give fan motor a spin will it start if so replace cap.
Jan 23, 2008 | Goodman GDS80904BNA Open Flame Heater
Heating & Cooling Logo
1,464 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
