Ruud silhouette II furnace blower fan makes a loud humming sound
SOURCE: Clunk noise Ruud Furnace
I had the same problem, the motor shaft and bearings were going bad. There was about 3/16" travel on the shaft that the blower attaches to. I replaced the motor myself and it runs nice and quiet. I have had that noise that you describe for over 8 years, but it got real noisy about a week ago. I talked to the maintance department about it where I work and they said the motor bearings were probably going bad. They were right, I took the motor out of the furnace and they took it to a parts store and got me a new one $270.00 for it. It is a special motor due to the fact that the frame mounts bolt directly onto the motor housing. Make sure if you do this job yourself that you take the motor to the parts store so that they can match it up. The guy at the store told our maintance man if it didn't require the bolt holes in the motor housing it would have been $100.00 cheaper.
Posted on Dec 24, 2008
hotuna
  • 288 Answers
SOURCE: ruud silhouette II furnace
Yes. On the board mounted inside the furnace box. There will be a series of posts that have numbers printed below each post. The heat motor uses low speed so it should be a sort of fat (larger than most of the other wires) red wire attached to one of the posts. If the wire is on 60, for example, then move it to the next lower post, like 30. unplug the cord on the furnace first. The wire SHOULD be red but may be blue, don't let the color guide you, look for the place where the wires go. If you find the place I'm talking about and the wire is black, then let me know, because its wired to high speed, which is wrong. I will help you.
Posted on Mar 13, 2008
  • 25 Answers
SOURCE: ruud achiever 90 plus blower not working
does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
Posted on Nov 22, 2008
  • 24 Answers
SOURCE: I HAVE A RUUD SILHOUETTE II GAS FURNACE. THE UNIT
Your furnace probably has electronic ignition. Remove the panel that you have access to the burners, valve, electronic module. There should be a main power switch installed on the furnace. Turn it off. Set your t-stat on high. Turn on the power switch. After the unit purges (about 30 seconds) you should see an orange glow at the burner orifice. If not, Turn off the power & remove the heater and inspect it for cracks. (Or use an ohm meter) If open, replace it. Very common problem. If the igniter is of the sparking variety, you need to change the circuit board. Most of the furnaces, there is d diagnostic code chart and an LED on the board. Follow the chart.
Posted on Mar 15, 2009
  • 288 Answers
SOURCE: How do I clean the flame sensor rod for a Ruud
disconnect the power. the flame rod is located at the end of the last burner. Gently remove it from its cradle and use a pencil eraser or a piece of scotch brite pad. If it doesnt allow the gas valve to stay opened after that, you should replace it
Posted on Dec 06, 2009
My Ruud Silhouette gas furnace ugdg 07 model blower stays on. The heat and air both work but it is pricing my energy bill higher. Whats the cause and can I just turn off the power to the unit (what about...
Problem could be the thermostat setting in "fan on" mode. Thermostat could be shorted between Y,R and G. Fan relay points soldered together or main board shorted.
Nov 03, 2013 | Ruud Gas Furnace - Excellent Condition -...
Rudd silhouette ii blower
Send direct power to the blower by bypassing relay . See if motor runs
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 19, 2017 | Ruud UBHC Air Conditioner
My ruud silhouette II gas furnace starts up and runs for 15 mins. or so and shuts off. just replace thermosta and filter. ??
are all the vents in the house full open?
is the flue vent pipes clean and un obstructed?
be sure none of your ductwork on the air return side is collapsing restricting airflow when the blower tries to run.
Is the draft inducer fan coming on?
could be a bad high limit switch.
Jan 05, 2011 | Heating & Cooling
I HAVE A RUUD SILHOUETTE II GAS FURNACE. The glow rod glows bright, the fan whirrs for 30 seconds there is a click and nothing happens...the fan stops. No flame...nothing.??
this can be a few things. tonight, i fixed one with the same symptoms and it ended up being the gas valve was bad and the gas pressure on the outlet side was only 1 in water column on an LP furnace. That is one thing and would have to be checked with a manometer. The other is the board may not be sending 24volts to the gas valve telling it to open. hope this helps
Jan 05, 2010 | Ruud UBHC Air Conditioner
How do you change the air filter on a Ruud silhouette II furnace? Where is it located?
If it is a down flow, it will usually be found in the return air plenum just above the blower. You need to remove the front panels and look inside above the blower. You may need to remove a second door to access the blower section. If it is an upflow, remove the bottom door and look alongside the blower where the return air comes in.
Oct 04, 2009 | Heating & Cooling
Ruud Silhouette II Fails to Ignite
sounds like you have bad flame sensor or the sensor is in a bad postition. To get eliminate the lockout turn the power off to the unit and back on again. Look at the circuit board light and see what the troubleshooting code is.
Jan 13, 2009 | Heating & Cooling
Ruud a.c. unite
Push in on the door safety switch,and use a screwdriver to help start the fan motor, while it calling for fan-on, if it takeoff and run , youll probably need to changeout the fan motor & capicator!
Sep 01, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
1,305 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
