Question about Acer Aspire 5610-4648 Notebook
Acer d2d problem
Hi there..please help me with my proble....i tired to acces the d2d recovery but when hit the alt/f10 keys -it comes up ,black screen,and from top to bottom it reads like this---
EDIT BOOT OPTIONS
Edit Windows boot options for:Microsoft Windows Vista
Partition:2
Hard Disk: 2ad434db
[ /NOEXECUTE=OPTIN
...and then boot to vista..nothing happens..
what seems to be the problem....please help
Thank you in advance and more power....
    Problem Solver:
  • 5 Answers
This is a quick fix. you need to find two files one called MBRwrWin.exe and the other file called RTMBR2.bin
copy MBRwrWin.exe to the root C:\
copy RTMBR2.bin to the root C:\
then from and command prompt just type in the following..... MBRwrWin.exe install RTMBR2.bin
press enter and your done... this will fix all d2d erorr but one.... this will not fix the type mismatch error... then power down machine and at start up use the keys... alt + f10 to enter recovery...
thats it... if this helped ya... let me know...
cyberburn666@yahoo.com
good luck and some kick back would be nice...
Posted on Mar 10, 2009
    Problem Solver:
  • 11 Answers
If you think that you cant able to fix your problem yourself and need remote support by experts at cheap rates so contact us—
frankmartin90@gmail.com
Note:
1) Its a remote support so, the experts come in to your computer and fix your problem.
2) We solve only computer problems by remote support.
3) The other problem is not remotely supported but answered by experts so; feel free to ask any question on any problem.
4) Did not need to pay in advance pay when you get solution.
  SO WHY YOU ARE WAITING ASK YOUR QUESTION TODAY
Posted on Jan 03, 2009
Acer Aspire One D250-08K Need to restore to factory settings and i have no disc. Screen is black. On start up pressed ALT F10 then nothing happens
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
You can also create a set to Recovery disk from the recovery partition, to do so
Start Menu> All Programs> Acer erecovery management> Click Create Factory Default Disk, if you receive any error code or unable to burn the disk, please contact Acer Technical support at 1 800 816 2237 and order for an Recovery Disk.
Thanks and regards,
Jitha
Aug 29, 2011 | Acer Aspire One PC Notebook
How do i reboot my recovery partition from a aspire 3690
Hi
If you have the option to save anything like files and photo's stored on your hard drive you should do this before you attempt a recovery because you will loose all files it will format your hard drive
back to when you bought it
Normally when you hit the power key you also tap the ALT+ F10 key a few times until it gets you
into the acer recovery manager and when asked for a password try 000000 thats is ( 6 zero's ) and follow the on screen instructions
if the F10 option dont work
then restar laptop and tap the F2 key to get you into bios and go over to about the 3rd of 4th option
and make sure that the D2D is enabled if it is not then click on it and change to enable
then click F10 to save and exit
then go back and try the ALT+F10 keys again
Mar 22, 2011 | Acer Aspire 3690-2196 Notebook
Factory reset for Aspire one without disk and alt + F10 doesnt work
The disk-to-disk recovery may be disabled preventing the Alt + F10 key sequence running eRecovery. To enable disk-to-disk recovery, you must do the following... (do not have an external monitor attached)
1. activate the BIOS utility by pressing F2 during Power On System Test (while Acer logo displayed)
2. select Main from the categories listed at the top of the screen
3. find D2D Recovery at the bottom of the screen and use F5 and F6 keys to set this value to Enabled
4. exit the BIOS utility and save changes.
The system will reboot.
5. while the Acer logo is showing, press the Alt key and the F10 key at the same time repeatedly
6. wait as Acer eRecovery starts up then follow onscreen instructions to perform system recovery.
Alternatively to the above, if Windows can be accessed, the recovery can be done by launching Acer eRecovery Management by running the program from the Acer Empowering Technology program group in the Start menu.
Mar 22, 2011 | Acer Aspire One PC Notebook
Hi, I want to do a factory restore on my acer 3690 aspire. where can I get the cd to do it ?
The below procedure will only work if you still have your original hard drive in the PC and have not reformatted or reinstalled windows from another media source.
On bootup you will see a message on the Acer splash screen to get into "SETUP".
This will take to your Acer BIOS and it is accomplished by either hitting the F2 or DEL F2 key.
Once inside the BIOS navigate to the menus and make sure that D2D option recovery is enabled. If you do not see this D2D option then you can exit and should not have to do anything else.
Restart the PC again, hold down the ALT and the F10 key altogether, which allows to start the recovery partition and load your system to factory default.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Jan 23, 2011 | Acer Aspire 3690-2196 Notebook
I need a acer aspire one happy recovery disk
The Acer Aspire One Netbook has a hidden partition on its hard disk drive which allows recovery of
1. operating system to original factory image (with no recovery disk required)
2. applications (selectable)
3. drivers (selectable)
If the netbook came with pre-installed Windows XP, use Acer eRecovery Management by
1. pressing start button at bottom left corner of Taskbar
2. hover cursor over All Programs then Acer Empowering Technology
3. then click on Acer eRecovery Management and follow subsequent recovery instructions
Alternatively, on powering up, press Alt and F10 together while Acer logo is showing.
If this doesn't work, there is the possibility that the D2D recovery is not enabled for startup.
To enable D2D recovery,
1. press F2 on powering up to get into the startup utility
2. cursor over to the Main tab
3. cursor down to D2D and enable it.
4. save changes when exiting - system will reboot
5. again, press Alt and F10 together while Acer logo is showing.
Jan 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
Hi my d2d recovery combination doesn't work
try alt+f12 maibe will work if not the cd going be your next opcion
Oct 11, 2009 | Computers & Internet
D2d recovery
Hi there
You want to restore your computer to its original settings without
recovery CDs?
This recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook. Follow the steps below to rebuild your C: drive. (Your C: drive will be reformatted and all data will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1 To activate the BIOS utility, press <F2> during boot up.
2 Check to see if Acer disk-to-disk recovery is enabled or not.
3 Make sure the D2D Recovery setting in Main is Enabled.
4 Exit the BIOS utility and save changes. The system will reboot.
To start the recovery process:
1 Restart the system.
2 While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3 Refer to the onscreen instructions to perform system recovery.
Good luck and Merry Christams
Dec 24, 2008 | Acer Aspire 5630 Notebook
Hello, I have Acer Aspire 5710 Notebook Comes with witndows Vista, i installled Windows XP on it now i need to Restore it on factory default settings. but when i press ALT + F10 on system stratup it does...
Press Alt and tap F10 only when the acer screen appears.
If this does not work and open the recovery program then is it possible that you formated over the driver and partition when you loaded XP?
If not the make sure that D2D recovery is enabled in the bios settings. You can check this by pressing F2 on boot and going into bios.
Nov 30, 2008 | Computers & Internet
D2d recovery
Is the d2d erecovery function enabled in the bios?
To check, activate the BIOS utility, press <F2> during the POST; while the notebook PC logo is being displayed.
To enable D2D recovery ard disk recovery), select Main from the categories listed at the top of the screen.
Find D2D Recovery at the bottom of the screen and use the <F5> and <F6> keys to set this value to Enabled.
That should allow you to use the F10 function key to activate D2D.
* Note: D2D e-recovery is not in Acer Empowering Management.
AEM is a power management utility that supports ACPI (advanced configuration and power interface) which allows for maximum power conservation and maximum performance. (Managed by the windows OS)
Jan 04, 2008 | Computers & Internet
Acer Aspire 5610-4648 Notebook Logo
1,051 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
