WMA 40 will rotate one revolution and pause during washing but will spin at end of cycle. To explain it better, it fills as normal but rather than rotating continuously it rotates pauses, rotates pauses....any ideas?
SOURCE: Hotpoint WMA42 - Noise!!
appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
SOURCE: Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
SOURCE: Hotpoint FEW 12
hi there i have had this problem before and found out it was due to to much weight in washing machine? or maybe your drumbelt may be loose which is connected to drum at the back on the inside? hope this helps
SOURCE: Hotpoint Aquarius 1100 WM63. fills with water...I
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
