Washingmachine Brand new problem
A new washingmachine, the drum is not starting?? I think it takes water.
  • 4 Answers
If you purchased the washing machine new ! Than all major brands come with at least a one year manufacturer warranty against defects...if you attempt to fix it yourself you will void that warranty. .("all bad") do the smart thing and either contact the customer service department or service department or the manufacturer who will send a warranty service technician to repair it.
Posted on May 17, 2016
  • Washing Mach... Master
  • 673 Answers
If it is brand new, Why could you not take it to the place you bought. You may have warranty replacement.
Posted on Oct 27, 2012
  • aer85
    aer85 Oct 27, 2012
    Yes I could, and im going to do it if i can not find a solution, the store is closed until monday.
3 Suggested Answers
  • 99 Answers
SOURCE: kenmore f l washingmachine 110.46472501 leak from dispenser
This is joyce
is dispenser in properly, remove and put back in. sometimes the peice that is seperating the solid from liquid is in the way and causes water to come out top.
also water pressure has a lot to do with this. has this changed. have you removed filter?
thanks
joyce
Posted on Feb 06, 2009
TheMobilian
  • 8220 Answers
SOURCE: Fisher and Paykel Kelvinator Washingmachine All lights on n
too many clothes in the washer maybe
hows about a F&P manual?Gimme a dollar LOL!
Posted on Sep 13, 2009
Was moving washingmachine in and when I went to install washingmachine two nail looking pins where on the floor please help me find exactly where these two pins are to be placed back to .
if the machine is brand new , never been used before , these items may be pins used for the transportation of the machine
They are put if place to stop the tub moving in transit and damaging the machine
read the user manual closely and it will state to remove these pins before use
Jan 03, 2016 | Tools & Hardware - Others
Makes noise when agitating
quite often coins and other objects get washed lodging between inner and outer drum . Check there
Aug 11, 2015 | Washing Machines
Indsit washingmachine: making scraping noise when spinning. metal drum inside feels loose and is leaning forward making it scrape on whatever is underneath. how do i stop the drum doing this?
If the inner drum is loose the bearing may have failed or the drum shaft spider may have broken. the scrapping will be the drum hitting the heating element.
Dec 30, 2012 | Washing Machines
Drum in washingmachine will not spin
fit new motor brushes should be ok
Sep 29, 2012 | Hotpoint Washing Machines
Does my kenmore washer model #92389200 has a filter? It keeps leaving stains on the clothes like lint or soap residue and I read to clean it with vinegar I have put a gallon of white vinegar with hot...
it is not advisable to put actual bleach inside the washingmachine[or you could use a proprietary washing machine cleaner. Thepurpose of a maintenance wash is to remove any mold, bacteria, old detergentresidue and gunge. If using white vinegar, it is important to allow the washingmachine to fill for about 30 seconds before adding the vinegar, as the firstbit of water goes into the sump.
Apr 14, 2011 | Washing Machines
Kenmore washingmachine motor starts clicking when it starts spinning.what causes the clicking sound?
DOes it hesitate to rotate the drum at full speed?, If not, the dog gears inside the shaft may be worn and not grabbing at full engagement
Jan 25, 2010 | Kenmore Washing Machines
Sep 13, 2009 | Fisher Washing Machines
Too much water entering drum.
I am not sure what the problem is... one passibillity :It can be something blocking the pressostat (pressostat ... is the thing regulating the water... when the water is rising... ear pressure will increase in a small pipe leading up to the pressostat.) What can it be?...
Lime:
if you have lime in your water it can block the intrance to the pressostat after som years. test if this is the problem..
if this is the problem . you chould also clean you machine with acid. Do a wash with asid on 95 degrees (ask for this in a washingmachine shop).. ..
Dirt: take out the small thin pipe(of gum) and clean it.. (the dirt blockin is always nearby drum)
Dec 30, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Whirlpool washingmachine
Karen, start by removing the cold water hose to the inlet valve in back. It will have a screen in the inlet valve. Make sure the screen is clear of sand and debris. Start there and post back. Catriver.
Apr 22, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
