Question about Sony NV-U53G GPS Receiver
Nv-u53 service message - Sony NV-U53G GPS Receiver
Need to know how to reset the oki c5400n to factory defaults
Procedure:
  1. Power ON printer while holding both the "+" and "-" buttons until “OKIUSER” message apear in LCD.
  2. Press ""+ or "–" button until “ENGINE DIAG MODE” is displayed
  3. Press "ENTER", will be displayed "DIAGNOSTIC MODE XX.XX.XX S-MODE"
  4. Press "+" or "–" button until “NV-RAM INITIAL” is displayed
  5. Press "ENTER" again
  6. Appear "TABLE 1" message
  7. Press "ENTER" until "EXECUTING RESET" message appears. "NV-RAM INITIAL" message will BLINK... IT resets TONER, DRUM, FUSER and BELT...
  8. Power OFF printer, wait 10 sec, and power ON again
To access Service Mode in C9300:
  • Power ON printer with 0, 1, 6, 7 at same time...
Nov 09, 2009 | OKI C5400 Laser Printer
Problem with Panasonic NV-DS38 Mini DV Digital
I´ve had same trouble, nothing help me to get tape on, then I tried to recharge the battery (new spare battery, only had 2 earlier charge) and voilá, it work´s again. So there was somekind of trouble with the new battery I got, that is not original part I don´t know if that matters,
Nov 06, 2009 | Panasonic NV-DS38 Mini DV Digital...
Require new Li-Ion battery for Sony NV-U53G sat nav but don't know the part number
Refer:
http://www.avcellshop.com/950mah-li-ion-gps-battery-for-sony-nv-u53.html?currency=usd
Oct 02, 2009 | Sony NV-U53G GPS Receiver
Broken glass sony nv-u53
an expensive repair, might be cheaper to buy a new one
Jul 04, 2009 | GPS
NAV U53 GPS - MESSAGE 'SERVICE' ON A BLUE SCREEN AND A SPANNER
This is a return to Base requirement as there is no owner solution to this problem. This is the tricky garmin group doing a "Microsoft" to get more $$ from their users.
Perhaps consider an Altina,next time they have no sneaky money grabbing tricks to make money out of you at every turn. Garmin were good once but they have joined the throw away mantality group.
You can check out an altina at Marbella australia the main service centre and distributor
Jun 30, 2009 | Garmin nuvi 260W GPS Receiver
My touch screen has just stopped working on my nav-u53
This happened on my nav-u 44 when i got into the car today. I pressed the reset button and it's thankfully working again.
Mar 15, 2009 | Sony nav-u NV-U70 GPS Receiver
Replacement screen required for sony nv-u53 sat nav
you can get the replacement screen for sony nv-u53 sat nav here,
http://www.play.com/Electronics/Electronics/4-/3593392/Sony-NVU53-Sat-Nav-System/Product.html
Aug 04, 2008 | GPS
Brand new Sony NV-U83
http://peb.pl/nawigacje-i-mapy/271104-update-aktualizacja-oprogramowania-sony-nv-u53.html
May 24, 2008 | Sony NV-U83 GPS Receiver
Monitor resolution re-set with a Samsung MW225 and Windows Vista
yes if your comfortable with editing your registry.
remove the following: (backup your registry first)
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\nv\Device0]
"DefaultSettings.XResolution"=-
"DefaultSettings.YResolution"=-
"DefaultSettings.BitsPerPel"=-
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\nv\Device1]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\nv\Device2]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\nv\Device3]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\nv\Device0]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\nv\Device1]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\nv\Device2]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\nv\Device3]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0000\Settings]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\nv\Device0]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\nv\Device1]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\nv\Device2]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\nv\Device3]
Feb 23, 2008 | Compaq Evo D510 Minitower (Open Box)...
Sony NV-U53G GPS Receiver Logo
35 people viewed this question
Top Sony GPS Experts
Will Halftowaite
Naveen Sistla
Naveen Sistla
Level 1 Expert
Steve
Are you a Sony GPS Expert? Answer questions, earn points and help others
