Washing machine not starting
We have just moved our washer into our new house and connected it up. when i tried to wash i set up the water level etc and when i press start it continually beeps and the icons flash and it wont start! please help! We also tried levelling but that didnt work. thank you
  • 15,935 Answers
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
When I start the washer cycle on any cycle, it does nothing, doesn't fill, doesn't sound like its even moving. Dryer works fine. I checked power and I seen to have power coming out of thermocouple.
when washing machine is started ( after applying the wash settings as to water fill , load size rinse etc) the first action is to turn on the water tap solenoid
from there the water fills to the set level at which time the pressure switch turns of the water solenoid and switches on the motor to start the wash
following that line of procedure , if you do not get water flowing after pressing start, the problem is in the water control solenoid , tap turned off or problem in the program board
Call in a technician after checking the other items first
Feb 02, 2016 | Washing Machines
Xqb90 701clps
check for a clogged pump. follow the drain line connections to locate it. spin and rinse will not happen until after a majority of the soapy water has been removed
Nov 20, 2013 | Washing Machines
Washer will not spin and empty tub
Have a new GE Profile Energy-star top load washer it has to be the worst washer I ever owned the biggest problem is the energy saver water level I can't wash a comforter and if you change the setting on the wash cycle it dumps your water and starts all over ok I can find away to deal with that but the water level I can't ether I need to move the water level up or I'm going to put this thing out along the road on trash day and it's only 4 months old so I would like to move the water level up
Dec 26, 2010 | Washing Machines
Water keep runing into the machine and exceed the required level setting. the machine will not start to washing is it that the water level in to high or does the water level setting control the washing...
put the washer on warm setting,start to fill washer,turn washer off,if it still keeps filling then you have a bad water inlet valve,if it turns off then check the water level hose from the head of the washer to the side of the outer tub,make sure both ends are on-mike
Jan 27, 2010 | Washing Machines
I've just moved house and my machine is not
Hello Friend, I think your machine will work properly if you add a water line splitter. You would connect to the single cold water tap and on the other end you would have two water hoses . Connect one hose to the cold water inlet of your washer and then connect the other hose to the hot water inlet. You can get these at Home Depot. Happy to help, Tim.
Jun 29, 2009 | Whirlpool Washing Machines
OVERFILLED AND FLOODED HOUSE
1 of two problems happened.
1) either the water level sensor went bad. Which tells the water inlet valve when to shut off and the machine to start operating.
2) The water inlet valve has failed. This comes from the water hose and fills the washing machine.
May 25, 2009 | General Electric WCSR2090D Top Load Washer
Washer fills with water then stops
2 things make sure the washer is balanced. and make sure theres nothing was stuff in the bottom of the washer when you were moving
May 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Samsung washer
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Jan 28, 2009 | Samsung WF337AA Front Load Washer
Maytag Washer
not the water hoses that connect to the water fausets of the house to the machine, it is a pressure hose that is inside the washer case, it connects to the switch that you select low medium and high water level, it then connects to the tub of the washer hope this helps
Apr 10, 2008 | Washing Machines
Washing Machines Logo
238 people viewed this question
Top Washing Machines Experts
