Question about Tecnik 24 in. TKD795/3 Built-in Dishwasher
Global 300 Dishlex draining problem
I have a Global Dishlex 300 that continues to run the pump even though the internal sump is empty and the pump is pumping air. It can still be turned on and off via the front panel and the programme can be changed. It is not the float switch that detects leakage at the base of the unit as the detection float area is dry and the switch is electricaly operational in both states.
  • 332 Answers
Is the float switch clear of debris so it can go down to its lowest point to shut off the pump,, a peice of food could be stuck in it, keeping it up just enough to keep it running
Posted on Jun 29, 2009
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
The eco light is flashing constantly on my Dishlex Global 300 dishwasher, it is making a noise like a pump is running continously, but the unit will not operate. Can you give me some possible faults and...
The symptoms on a Dishlex Global 300 dishwasher:
  • eco light is flashing constantly;
  • noise on pump running continuously;
  • but the unit will not operate.
Possible corrective actions include:
  • water level - pls check incoming water pressure, filter, water level sensor, water valve;
  • base/bottom overflow sensor - there is a float switch in the base of the machine inside a small plastic dish. Behind the kick panel, access through a metal lid/panel/cover secured by 2 small screws. Dry completely the area;
  • Air/dry/ventilate the unit/system for a couple of days;
  • reduce incoming water pressure.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 26, 2008 | Dishwashers
How do we progress with resolving a substantial leak from bottom of dishlex dx301. Pumps out water will nil issue when emptying. Also noticed spray arms do not turn and water only dribbles from them
Fill hose, or float assembly has a problem with its gasket, which will cause it to do that. The float assembly itself could be the problem, if the unit is draining fine I would say that the sump and drain lines are fine.
Fill line or water inlet valve itself as well could be the issue.
May 02, 2014 | Dishwashers
The drain pump runs continuously when the Dishlex Global 300 dishwasher is turned on. When pushed, the buttons on the control panel would not change any of the cycles.
This could be that the anti flood device "polystireen float and micro switch at the base has detected water at the bottom due to a leak (pipe or pipe clamp). This device puts the washer in pump out mode and will not continue. Firstly you need to determine what causes the water leak and rectify it before it will continue.
Mar 20, 2010 | Dishwashers
Dishlex Global 300. Eco light flashing and nothing happens.
could be the water inlet valve or solenoid
Jan 25, 2010 | Dishwashers
Pump motor runs continuously, ''Eco'' flashes continuously
Hi
soyunds like it flooded the base
You need to dry out the base of the machine thoroughly and it should re set
Feb 14, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Dishlex dishwasher global 300. Dishwasher continues to drain with ECO light flashing. Service manual says it is due to an incorrect fill level or fill line.
Some diswashers have a sump in the bottom with a float switch. If the water level overflows the float will activate the switch which will kill the machine and run the drain pump continuously.
Jul 01, 2008 | Dishwashers
Tecnik 24 in. TKD795/3 Built-in Dishwasher Logo
585 people viewed this question
Top Tecnik Dishwashers Experts
Renee Knafel-Bullock
 Mikey
Mikey
Are you a Tecnik Dishwasher Expert? Answer questions, earn points and help others
