Question about Rowenta Effective DX1700 Iron with Auto Shut-off
How to replace thermostat in Rowenta Iron - Rowenta Effective DX1700 Iron with Auto Shut-off
SOURCE: Rowenta Steam Iron Leak
I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
Posted on Sep 03, 2008
  • 109 Answers
SOURCE: need to know how to clean a rowenta iron plate
As long as it's not a coated surface - plain steel - get 0000 steelwool to rub it with. It will take some elbow grease but it will work to clean and (almost) polish the surface.
Posted on Mar 26, 2009
  • 2976 Answers
SOURCE: Iron spits out rusty water. The iron is a Rowenta
Fill it with a mix of 50% white vinegar and 50% water. Let it set for 30 minutes and steam it out for about 2 minutes. Unplug it and dump it. After it cools colpletely, fill it with water and steam it out. The rust is coming from your water supply, not the iron.
Posted on Oct 06, 2009
heatman101
  • 43501 Answers
SOURCE: Rowenta Iron DZ6700
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
heatman101
  • 43501 Answers
SOURCE: ROWENTA STAM IRON - NO STEAM !!!!
heatman101
My Rowenta pro precision iron steam station gets hot but doesn't steam. How do I get the iron to produce steam?
There are two cause. One the boiler resistance doesn´t turn of because of snap disc or bimetal thermostat fault or because a coil in the working valve (security valve). But if you can heard a click of opening movement of valve when you push the button it is able to be a thermostat.
Apr 12, 2016 | Rowenta Irons
Rowenta steam iron fell down and top part is broken can it be replaced
Rowenta Iron Parts - eReplacementParts.com
www.ereplacementparts.com/rowenta-iron-parts-c-180639_180647.html Fix your Rowenta Iron today with parts, diagrams, accessories and repair advice from eReplacement Parts! Worldwide ... DE0554 Rowenta Steam Iron Parts.
Aug 08, 2015 | Rowenta Irons
My rowenta steam iron fell down and top part has broken any chance it can be replaced
Rowenta Iron doesn't heat up and the Auto-off lamps remains lit. Any clues? Is it the small PC card in the handle? Thanks, Rudy
The problem would be the contact points and setting of the heater! u have to open the iron and check, adjust, and clean the bi-metal thermostat or the heater core!
Jun 14, 2011 | Rowenta Professional DE880 Iron
My rowenta iron which is about 4-5 years old starts blinking the red on-off button after only 2-3 minutes of use. Also the orange button will not stay lit. What is the problem? The red on-off button does...
your iron has a thermostat fault its this thermostat thats cutting in and out that puts the red light on it could be fixed but that wont be a cheap fix best bet is to buy a new iron as that would work out cheaper
Sep 11, 2010 | Rowenta DX6700 Iron
I have a Rowenta DX1700. The iron will only stay
The problem is with the iron's thermostat which controls the temperature of the iron
Feb 07, 2010 | Rowenta Effective DX1700 Iron with Auto...
Iron got really hot, like it overheated, then the light stayed on, but the heat seemed to go off and water came out the bottom of the iron. What do I do now?
Hi.
The thermostat must be replaced.
The iron uses a thermal cut off that will disconnect power to the element when the top temperature is reached.
In your case the thermostat is shorted inside, and will never cut off.
The part can be ordered calling Roventa at the customer support number listed on the owners manual. Alternatively, putting Rowenta Parts in a search engine like Google or Yahoo, you will get a list of Rowenta parts distributor in your area.
Jan 17, 2010 | Rowenta Professional DX8900 Iron
I need to purchase the thermostat/steam generator that is inside the water tank of the rowenta dg050 iron/steamer. where can i find that part? i know it is the problem
I would call a Rowenta service center to find the part and cost. If you are in the US go to the After Sales Service, Service Centers at
http://www.rowentausa.com/rowenta/frame.aspx
If you are outside of the US go to the www.rowenta.com site and select your country.
Aug 09, 2009 | Rowenta Steam Generator DG050 Iron
DM880 Rowenta Professional Luxe Iron
The thermostat is bad...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jul 20, 2008 | Rowenta Professional DE880 Iron
Irons Logo
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
