Question about Hotpoint-Ariston FDD914 24 in. Built-in Dishwasher
Hotpoint ultima fdd914 door wont close. wont seem to catch just keeps popping open
Door keeps opening when on
The door is usually held closed with a male and female door catch/latch, the female side will sometimes break internally and wont keep that door closed, or will pop open when the clothes get close to the door.
Jan 31, 2014 | Miele Dryers
Hotpoint ultima sdw80 45cm door will not keep closed when in use still doing the wash cycle
Door catch needs replacing. Can be done yourself. Top 6 or so screws removes the top section of the door and the catch is held in by 2 screws and has two easy to remove / replace.
Oct 31, 2010 | Microwave Ovens
Door handles slack feels like springs dropped so cant open door
You can release the catch from inside just keep trying and thern you need to replace the door catch itself this is a simple job
Jun 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
DOOR WONT CLOSED WD71 HOTPOINT AQUARIUS ULTIMA WASHER 1200
you can try unplugging the unit for a few minutes and see if that resets, otherwise its a faulty sensor that needs to be replaced.
Nov 06, 2009 | Washing Machines
Machine doesn't recognize door is closed
Open the door, and look closely at any little plastic latches to see if a small part hasn't busted off.
They usually have plastic prongs that tell a small switch inside the hole it goes into, that the door is shut. It's a toughie.
I'd google around for it. Use the talking marks " ". Like google something like "Ultima 1000" space "door won't close" or 'dryer' 'door won't close'.
That will bring up dozens of other people who've asked questions to OTHER sites.
Tried holding it shut? DOes it work when you stand there? You could tape it with gaffer tape.
Methinks, its a latch problem, something's busted off.
Feb 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint ultima plus washing machine door wont open after wash
Hi,I have a 2nd hand Hotpoint Ultima digital washing machine & cant seem to use it as when i turn it on on display screen the childlock icon flashes & beeps,even when door is open/closed,when i select a programme the icon still flashes & beeps therefore i cannot use machine.hope you can help me with my question Thanks.GILLI37
Apr 14, 2008 | Washing Machines
Hotpoint Ultima extra WD72
There are 3 possibilities 1 altough the water as drianed the pressure switch as not released due to blocake in the filter, or the interlock has jammed on the closed position which means it will have to forced open or the last fault could be the power board has gone.
Feb 28, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint-Ariston FDD914 24 in. Built-in Dishwasher Logo
66 people viewed this question
Top Hotpoint-Ariston Dishwashers Experts
Are you a Hotpoint-Ariston Dishwasher Expert? Answer questions, earn points and help others
