Question about Polk Audio PSW-550 Subwoofer
My psw-550 quit working, how do i troubleshoot the problem ?
Is a new amp available or can it be repaired ?
Which amplifier plate can use for Polk Audio PSW 1000
call parts express tell them your problem and they do have a plate amplifier that will work actually it's a better amp with more power.
Jun 14, 2012 | Polk Audio PSW1000 Subwoofer
Recently acquired a PSW-D112 Sub in good shape and also still have a PSW-D110 sub that has not really ever been used. I have been reading all the posts about these models amplifiers crapping out because of...
Or you could prepare for the worst but live in the moment and wait til it dies. You have time on your side. Plus, you could always use it as a passive sub if you have a separate amplifier. I did that with a Klipsch KSW-12 when my second copy blew its amp.
Apr 10, 2011 | JBL PSW-D112 Speaker
Have a PSW-D112 sub woofer that needs a new amp. Repair facility says original amp took a catastrophic power surge and it's toasted. JBL says repair parts not available. Please advise on source for...
Go to Parts Express and buy the Bash 300w digital subwoofer amp.It fits almost exact except it is one inch shorter.Just use mdf to fill the space and this amp will outperform the original.I have done this and it's not really difficult,pretty straight forward.
They usually sell for around $149,but they have sales often around $99.Good luck.
Oct 28, 2010 | JBL PSW-D110 Speaker
I have a Kef PSW 2500 that emits a loud buzz when on. I pulled the amp, but I'm not sure if its the speaker or amp. What should I be looking for the speaker outputs from the AMP? How can I tell if its a...
Have just repaired a similar problem with a KEF 2500 - relay was chattering at 50 Hz rate, buzz in speaker output.
Problem was caused by overheated / dried out Electrolytic filter cap (C52 - 47uF 63V) on the relay coil supply feed.
The overheating is caused by adjacent power supply dropping resistors which run very hot due poor design of power supply.
A service manual for a similar model is available at following link, refer to power supply section:-
http://www.eserviceinfo.com/downloadsm/35375/kef_psw2000.html
To replace,
1) remove chassis from speaker cabinet (8 screws), disconnect red/black speaker wires from main PCB spade connectors.
2) Remove 4 screws attaching main pcb heatsink assembly from face panel - lift assembly from faceplate (a bit messy , much heartsink compound between mounting faces)
3) unplug the AC 3 pin connections adjacent to the large capacitors and the 3pin connector on end of pcb (near C52), then roll assembly over the top of the audio sub-board to access underside of pcb.
4) solder connections to C52 is accessible at edge of board without further dis-assembly.
Take extreme care replacing C52, as the circuit board is of poor quality, (usual domestic electronics quality) being single sided copper without plated through holes.
The board is already heat damaged by heat buildup from power supply resistors, so the track will most likely lift and crack when disturbed- to counter this problem link the +ve capacitor pigtail to an adjacent solder pad on the same track.
Assembly is reverse of above, take care to preserve/ensure minimum disturbance of heatsink compound.
Nov 29, 2009 | KEF Audio PSW 2500 Subwoofer
I have a KEF KHT 2005.2 Subwoofer that does not produce sound any more, it makes a slight pop sound when i switch it on and thats it, no further sound. The system is about 5 years old but has not had a lot...
The KEF-Subwoofer range (from the PSW1000 up to PSW 3000?) have some built-in flaws in the electronic design.
I just fixed my PSW2000 working along the repairing instructions from:
http://lug.demon.co.uk/kefrepair/
Works! Costs have been about 35,- Euro for spare parts and some (too many) hours of work. If you are used to electronics and soldering you may make it in 2 hours.
Nov 07, 2009 | KEF Audio KHT 2005.2 System
Wishing to purchase a copy of 'PSW Options'
Hi, I am a SINGER dealer in South Africa, and we have still have 3 copy's of PSW options available.
The cost is app. $700.00 US Dollars, depending on the exchange rate. If you are interested to buy one from me, please contact me by e mail: dupina@mweb.co.za .
Regards
Jan 11, 2009 | Singer Quantum XL-6000 Computerized Sewing...
JBL PSW-D112 Speaker fuse blow immediately after replaced
The fuse is designed to protect the circuit and prevent fire. When a fuse blows it is because it is getting to much current through it.
In some cases it could be because you replaced the fuse with one that did not meet the specs of the required fuse, there are different types of fuses and you should always replace with exactly the same type of fuse.
Do not replace with a higher Amp fuse, you could end up frying the amp at least. It's not a safe thing to do since there is an off chance of fire from using the wrong fuse.
If you have the right type of fuse installed and it is still blowing, then refer the unit to a qualified service center for repair, or look for a new replacement Amp.
john
Jun 27, 2008 | JBL PSW-D112 Speaker
JBL PSW D112 Distorted Sound
SYLVAN.
THE FILTERS /FILTRES ON YOUR SPEAKERS ARE TORN OR DAMAGED. IF YOU STILL HAVE WARRENTY ON THEY FROM JBL YOU CAN RETURN THEM FOR NEW ONES, PROVIDING THAT IS COVERED. IF NOT. I PERSONALLY RECOMMEND YOU BUY YOU SOME NEW ONES. REPAIRING WOULD BE OK, BUT IT WILL HAPPEN AGAIN VERY QUICKLY.
Thank you. Let me know what your decissions are
Nov 22, 2007 | JBL PSW-D112 Speaker
Polk Audio PSW-550 Subwoofer Logo
53 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
kdigby
kdigby
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
