Question about A D S 1 Bay USBX-835-EGFS USB 2.0 Drive Case
USB X-835 (USB 2.0 HARD DRIVE KIT BY ADS TECHNOLOGIES) DOES NOT W
RE: USB X-835 (USB 2.0 HARD DRIVE KIT BY ADS TECHNOLOGIES) DOES NOT Work)
I connected the device, but my computer does not read it at all. My machine is Dell Dimension 4300S, running XP pro. I tried all USB connections, disconnecting all other USB devices, and still it did not work.
  • Anonymous Jan 12, 2009
    I 2 have an ads x835 that my latitude 830 xp won't find...
  • Anonymous Feb 09, 2009
    I believe I need a driver for the X-835 but am unable to find it. Please help.
Western Digital Hard Drive Help Needed
Hi, The drive you are connecting to this USB enclosure can be set up as an auto select, master, or slave drive by changing the jumpers. Suggest to check your USB enclosure manual to see what is required for this device as to the configuration of the drive jumpers. Regards, Rongg
Mar 29, 2014 | Western Digital Computers & Internet
COMPUTER IS NOT READING MY HARDRIVE OR REQUEST TO BE FORMATED
You might need to add bit more information
IE: type of hard drive external ,usb pen drive ,internal SATA ,IDE>???
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
There is a connection problem such as a bad cable
for internal hard drives
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
Test all power and data leads that attach to your hard drive IDE,SATA
The leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
Make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
for usb drives
Click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
If you computer came with a motherboard disk the drivers could be on it.
Nov 10, 2013 | Computers & Internet
My computer won't discover my brand new 250 gb Seagate hard drive. It's connected by a USB port in a HP compaq computer running windows xp version 2002. It didn`t come with any software and says it`s plug...
It is possible the usb port is not giving enough power for the device, theres a cable the allows you to connect the device to 2 usb ports to get more juice, maybe that could help.
Mar 21, 2011 | Seagate 320 GB USB 2.0 Portable External...
Hard disk not detected
Try plugging the enclosure's usb to another USB slot. If the computer still will not read it, then the enclosure itself might be defective and not the actual harddisk that is inside.
To verify this, try to mount the harddisk to another enclosure and test. If the enclosure is still under warranty, you can return it back to save repair costs.
Aug 17, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
External hard drive is not detected
Check Following Instructions:
1. Check your USB cable properly connected to the computer.
2. Go to My computer - right click on property - Hardware - Devices Manager - in below - USB Mass storage device - right click on this - and Uninstall - then again right click - click on Scan - it should be reload your USB drivers
your External Hard Drive will be detected
Apr 25, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
Bytecc BT-300 USB 2.0 drive mate problem : I am a PC user with WinXP O/S. My BT-300 worked fine when used along with 2.5 in laptop hard disk (power cable connected to drive mate). On the other hand, I am...
First is the "Drive" formatted? It will not work, if it is a new drive, until it is formatted. And/Or "Initialized"? If it has data on it already then it may be faulty? the only way to check that is to try it on another machine... also are you 100% sure you have it connected right way around, I have made exactly that mistake, before, I learnt whats what. Also try another USB port, this sometimes works. Try the setup on another PC to check it is actually OK.
Feb 22, 2010 | BYTECC USB2.0 to IDE Adapter Kit...
When I try to access the USBX-835-EGFS USB 2.0 Drive come back the message: E:\ does not exist. Error at page operation. What can I do to solve this problem?
You need to scan the drive with a very good ant-virus software such as Avira anti-virus, then you scan thoroughly. This should work but if it does not, you can try formatting it
Nov 06, 2009 | A D S 1 Bay USBX-835-EGFS USB 2.0 Drive...
Drive Recognized but not visible on my computer
Right-click My Computer, go to Manage, Disk Management under Storage
Find your drive there and assign a drive letter.
The drive may still need to be formatted.
Sep 01, 2009 | Sabrent EC-UEIS7 USB, eSATA Internal Drive...
Not mounting
TRY GOING TO COMPUTER MANAGEMENT IN CONTROL PANEL AND FORMATTING THE DRIVE FIRST THEN IT SHOULD MOUNT
Jul 06, 2009 | Acomdata Samba USB Enclosure Kit Black:...
Difference between ata and sata hard disks
ATA, or (PATA) hard drives use the older "seatbelt" 40 or 80 pin ribbon interface cable, whereas SATA is fairly new using the small, thin interface cable found in most computers manafactured in the last 12-18 months, hope it helps
Feb 18, 2008 | Highpoint Technologies 1 Bay e.SATA...
A D S 1 Bay USBX-835-EGFS USB 2.0 Drive Case Logo
585 people viewed this question
Top A D S Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you an A D S Computer and Internet Expert? Answer questions, earn points and help others
