Question about GE Refrigerators
I have a MN - TFX24PRXB - BB GE Side by side refrigerator. The Ice maker does not make ice anymore. I have tested the water valve and it is working. If I turn the gears it will start the process to dispense ice. The heater works and it will dispense the ice that is in the tray. It will not dispense without a push of the gears. What signals or triggers the icemaker to start the ice removal cycle?
    Top Expert:
  • GE Master
  • 12,962 Answers
Check for freezer temp - if it is not 10 degrees or below the ice maker thermostat will not turn the ice maker cycle on by removing the frozen ice in tray and then refilling it for next dump cycle. And if freezer temp is high you may have leaking door gasket, dirty condenser coils, improperly operating self defroster which raises temps, low refrigerant.
Posted on Aug 04, 2017
2 Suggested Answers
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE Fridge water dispenser working but not the ice
Yes you most likely have a defective dual water control valve. Look around the inside of the refrigerator for a model number.
Click here=> For most locationsSide-By-Side
  • Top Freezer
  • Bottom Freezer
    Once you find the model number I will be able to tell you what part number the dual dual water control valve is or if your ice maker assist you in testing ice maker. If ice Maker is empty try filling with tap water to top edges of ice maker, allow water to freeze and if the ice drops into the ice bin but does not refill with water automatically I would say that the dual water control valve will need replaced. If your ice maker has old shrinking ice from a few days ago it will point to an ice maker problem.
    Thanks, Sea Breeze
  • Feb 10, 2012 | GE Refrigerators
    GE GSH25JFTA BB water dispenser not working but ice cube maker working fine
    Ice maker is working. Water dispenser is not working. I did the initial diagnosis and the water line is not frozen. How do I replace the water valve or is that the right next step?
    Jan 05, 2012 | GE GSH25JSTSS Stainless Steel Side by Side...
    GE Profile side by side with water/ice dispenser. The water is working but the water to make ice is not working, hence no ice. I had ice, used it all and then nothing.
    I would try putting water in ice maker if it freezes ice maker is ok if so feplace water valve. careful only 4oz. of water in ice maker
    Oct 16, 2009 | GE Profile PSW26P Stainless Steel Side by...
    GE TFX22ZR side by side. ice maker not making ice
    Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
    The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
    A strainer before the inlet valve can also get stopped up restricting flow.
    Oct 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    GE side by side refrigerator
    Mike, Most times when this happens it's the water control valve for the ice maker side that becomes defective. If using an OHM meter you unplugged the 2 coils and read the OHM's they should be very close to equal. The part number for the water control valve is WR57X10032 and the part number for the ice maker is WR30X10093 Unfortunately the ice maker is electronic and there are no replaceable parts. You can test the ice maker by filling with tap water allow to freeze and if it dumps then the ice maker is good and the water control valve is bad, Thanks, Please Rate Me, Sea Breeze
    Aug 29, 2009 | GE GSS20IEM Side by Side Refrigerator
    GE model GSH25JFTACC ice maker not working
    When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
    First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
    Mar 24, 2009 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
    GSS25WGMA BB
    Check the water inlet tube which runs from the outside of the freezer section into the freezer. Look for a blockage of ice. Water valves which seep water can be a cause of this.
    Jul 28, 2008 | GE GSS22JFMWW Side by Side Refrigerator
    Water dispenser not working but ice maker does
    The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
    Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
    Refrigerators Logo
    89 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    Gene Tuck
