Question about Cameras
Bmw e36 7 series does not warm straight away - Cameras
  • 14,384 Answers
Your thermostat may be open,causing your coolant not to heat up and have no heater with hot air blowing.To check,when engine is cold,remove radiator cap and have someone crank up vehicle and see if coolant is circulating or just staying still.
Posted on Oct 27, 2012
Bmw 3 series electrical faults
Hi sounds like the same problem I had crankshaft sensor my battery light came on and the engine would cut out sometimes would start straight away other times took 5mins to start again.
But would get a garage to check fault codes costs about 40pound but could save you 100's as it may be a faulty alternator/battery.
Jun 16, 2014 | 2007 BMW 3 Series 328i
Automatic choke problems
I would guess a sensor. Do you have any bad codes?
Mar 21, 2014 | 2002 BMW 318
MY 2000 BMW 318I SE IS NOT ACCELERATING PROPERLY WHEN STARTING FROM COLD I PUT MY FOOT DOWN BUT THE CAR JUST JUDDERS ALONG IF I STOP AND REV THE ENGINE PAST 5000 IT THEN SEEMS OK AFTER ALSO THE EMISSION...
There isn't a car out there that likes to be put in drive as soon as it is started. Mine especialy. I give it at least 30 seconds to warm while I am adjusting evrything and away I go. Runs like a champ. Let it warm up for a couple of minutes from a cold start.
Jun 01, 2011 | 1998 BMW 7 Series
How do you change spark plugs on a 2004 bmw 545
You need to remove the top cover 1st. Then remove the gray trim covers on the left and right banks by pulling straight up.You will find individual coils in each cylinder. Disconnect the connector of the coil and pull the coil straight up.The plugs are under each coil.
May 11, 2010 | 2004 BMW 5 Series
Need to replace outer door handle on 1997 BMW 528i so need to know how to get inner door panel removed
remove the mirror switch, theres a hex screw in there,remove inner door lever, useing a panel pullers or flat screwdriver prise bottom of door card straight out, theres about 10 clips holding door card on.plus unscrew door button then lift away
Nov 07, 2009 | 1995 BMW 5 Series
I have BMW 328i when cold empty coolant lign comes on. After driving for while when the engine is warm, the light goes away.
YOU HAVE air IN YOUR COOLANT SYSTEM AND YOU HAVE A SMALL BLACK PLASTIC +SCREW ON THE top of the RADIATOR . TOP UP THE RADIATOR WITH COOLANT put Cap on radiator undo the Black + screw and let out air,,tighten up with scewdriver just do not over tighten. and start and run
Let me know how you get on Ron
Oct 13, 2009 | 2000 BMW 3 Series
Bmw misfiring
I would check your tps(Throttle positioning sensor) to see if its bad. That's what it sounds like.
Sep 22, 2009 | 2009 BMW 3 Series
How do I remove the gear knob from a BMW E60? Want to replace it with a new one
From the research that I've done, it appears that the shift knob will pull straight off. (I would keep my face away from the knob as you're pulling it off...;) Just to be sure, look around the shift knob to make sure there isn't an allen set screw holding it on.
I hope this helps! :)
Sep 09, 2009 | 2002 BMW 5 Series
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
