Question about GE Refrigerators
I have a MN - TFX24PRXB - BB GE Side by side refrigerator. The Ice maker does not make ice anymore. I have tested the water valve and it is working. If I turn the gears it will start the process to dispense ice. The heater works and it will dispense the ice that is in the tray. It will not dispense without a push of the gears. What signals or triggers the icemaker to start the ice removal cycle?
  • Dave Shelton
    Dave Shelton Oct 28, 2012
    Thanks, but that is not my problem, it works. Ice maker will not go into the dispense cycle and dump the ice into the catcher bin.
    Top Expert:
  • GE Master
  • 9,472 Answers
You will need to replace the dispenser switch. Here it the part you need.
Posted on Oct 28, 2012
  • 330 Answers
SOURCE: GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
Posted on Jul 21, 2008
itls
  • 17 Answers
SOURCE: GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Posted on Mar 16, 2009
SOURCE: water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Posted on May 22, 2009
  • 19 Answers
SOURCE: Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Posted on Apr 05, 2010
iwillfixforu
  • 619 Answers
SOURCE: I have GE LSS25XSW side by side refrigerator which
The ice solenoid located behind the control for the water and ice has gone bad. Inexpensive to replace. Thanks.
Posted on May 16, 2010
I have a MN - TFX24PRXB - BB GE Side by side refrigerator. The Ice maker does not make ice anymore. I have tested the water valve and it is working. If I turn the gears it will start the process to...
Check for freezer temp - if it is not 10 degrees or below the ice maker thermostat will not turn the ice maker cycle on by removing the frozen ice in tray and then refilling it for next dump cycle. And if freezer temp is high you may have leaking door gasket, dirty condenser coils, improperly operating self defroster which raises temps, low refrigerant.
Aug 04, 2017 | GE Refrigerators
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE Fridge water dispenser working but not the ice
Yes you most likely have a defective dual water control valve. Look around the inside of the refrigerator for a model number.
Click here=> For most locationsSide-By-Side
  • Top Freezer
  • Bottom Freezer
    Once you find the model number I will be able to tell you what part number the dual dual water control valve is or if your ice maker assist you in testing ice maker. If ice Maker is empty try filling with tap water to top edges of ice maker, allow water to freeze and if the ice drops into the ice bin but does not refill with water automatically I would say that the dual water control valve will need replaced. If your ice maker has old shrinking ice from a few days ago it will point to an ice maker problem.
    Thanks, Sea Breeze
  • Feb 10, 2012 | GE Refrigerators
    GE GSH25JFTA BB water dispenser not working but ice cube maker working fine
    Ice maker is working. Water dispenser is not working. I did the initial diagnosis and the water line is not frozen. How do I replace the water valve or is that the right next step?
    Jan 05, 2012 | GE GSH25JSTSS Stainless Steel Side by Side...
    GE Profile side by side with water/ice dispenser. The water is working but the water to make ice is not working, hence no ice. I had ice, used it all and then nothing.
    I would try putting water in ice maker if it freezes ice maker is ok if so feplace water valve. careful only 4oz. of water in ice maker
    Oct 16, 2009 | GE Profile PSW26P Stainless Steel Side by...
    GE TFX22ZR side by side. ice maker not making ice
    Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
    The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
    A strainer before the inlet valve can also get stopped up restricting flow.
    Oct 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Mike, Most times when this happens it's the water control valve for the ice maker side that becomes defective. If using an OHM meter you unplugged the 2 coils and read the OHM's they should be very close to equal. The part number for the water control valve is WR57X10032 and the part number for the ice maker is WR30X10093 Unfortunately the ice maker is electronic and there are no replaceable parts. You can test the ice maker by filling with tap water allow to freeze and if it dumps then the ice maker is good and the water control valve is bad, Thanks, Please Rate Me, Sea Breeze
    Aug 29, 2009 | GE GSS20IEM Side by Side Refrigerator
    GE model GSH25JFTACC ice maker not working
    When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
    First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
    Mar 24, 2009 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
    GSS25WGMA BB
    Check the water inlet tube which runs from the outside of the freezer section into the freezer. Look for a blockage of ice. Water valves which seep water can be a cause of this.
    Jul 28, 2008 | GE GSS22JFMWW Side by Side Refrigerator
    Water dispenser not working but ice maker does
    Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
    Refrigerators Logo
    148 people viewed this question
    Top Refrigerators Experts
    Sal DeAngelo
    dweatherby
