Question about Coffee Makers & Espresso Machines
Problem with bean to cup Coffee machine ECAM23.450
All morning I`m trying to set up new cofee Machine. Display keep showing message "Ground Too fine Adjust mill" "Insert Water spout" When water spout is inserted display show: "Hot water?" - I press "ok" Next is - trough the water spout machine deliver cold water, and shows the same message what at the beginning. Tried to adjust the grinding mill as it says on instruction " turn the grinding adjustment knob one click clockwise towards "7". Tried to do this many times. Nothing happens.
2 Suggested Answers
SOURCE: have tried to make coffee, message comes up -
I had this problem and the spout was blocked you can push a small wire through the hole in the midle of the large white spout
Posted on Jan 23, 2010
Empty ground container issue
Once you have the drip tray out and the grounds container out - look inside the unit and clean any grounds that are still in there. Look for a switch that might be sticking (because it's cover with coffee residue) clean everything and check for freedom of movement.
Nov 27, 2014 | DeLonghi ESAM6620 Prima Donna Bean-to-Cup...
Seaco Syntia - Displaying "No Beans" even when the beans are full
First, I'm NOT a Saeco technician, But I have worked on similar machines. (I still have one in my garage along with other 'graveyard' coffee machines.) Check your warranty and call for service as there are no customer serviceable parts in this equipment.
*** the following is for information only ***
* I've taken these machines apart many times and found there are a lot of sensors in this unit. Many are very delicate and fault out easily. If you do locate the right sensor, you will still need to locate a replacement. Ordering parts can be a challenge as it must be the correct model (and serial number series). I found out the hard way that not all PC boards are the same as the change functions even in the same model.
* Okay looking around I came across a vid (link below) that shows in detail how to check all the functions of the model he has. You probably don't need to go through the descaling and other checks. The Bean grinder portion is very detailed and not for the faint of heart. But his instructions are clear and should be able to solve your problem. His "No Bean" error was caused by prolonged use without proper cleaning and someone spilt water into the bean cup long ago. I hope to try out his method soon as I never took apart the grinder section completely like he did. I only vacuumed the beans out.
Good luck (to all of us!)
Aloha, ukeboy57
https://www.bing.com/videos/search?q=Seaco+Syntia+no+beans&&view=detail&mid=7D35DEE54A6DBDC3688B7D35DEE54A6DBDC3688B&&FORM=VRDGAR
Mar 03, 2013 | Saeco Syntia Espresso Machine & Coffee...
How do you remove coffee bean container from Miele CVA615?
There is set-screw that holds the cofee bean container from pulling all the way out. Loosening almost all the way out (or removing) the screw, will allow the cofee bean container to slide all the way out. However, when sliding it out, put a container under the edge of the machine housing to catch any residual beans and keep them from falling all over the floor. Here's how to do it: with the door open, look (or feel with your fingers) directly at the (closed) coffee bean container. Coming up from the bottom, all the way on the right side is the set screw. It's a black phillips screw that you can easily miss if you don't look carefully or use a flashlight as it blends in with the housing. Good luck.
Nov 12, 2010 | Miele CVA615 Espresso Machine
My gaggia platinum is showing an out of service error code [1] and i don't know what to do. Called the service centre all i get is "leave a message".
On my machine remove water tank, remove crip / coffee bin, remove mach and wash. Tip machine on its side (turned off) using a small screw driver go around the coffee grinder and clear it completly, you will need a touch. Re assemble. First run with no beans and wait for the fill bean message, fill with beans off you go. Its only happend twice both with cheap beans
Nov 11, 2010 | Gaggia Platinum Swing 2-Cup Coffee Maker
My expresso machine is grinding the cofee , it makes his cycle and at the end nothing came out. The grinded cofee is returned to the dreg drawer. Some time the machine is working and some time not.... i...
Hi
there are 2 knobs in the bean hopper. Turn the small knob down to the middle and try again. you can get too much coffee in the brew unit and it will dump the grounds instead of making coffee. If the grinds are to big or coarse, it will also dump the ground.
Oct 30, 2010 | Saeco Incanto Classic Espresso Machine
I have a gaggia platiniun bean to cup. i am using ground coffee at the moment but it keeps coming up brewing failed Why?
The grind might be too fine, and so the machine extract the coffee, try making the grind a little coarser.
May 30, 2010 | Gaggia Platinum Swing 2-Cup Coffee Maker
No coffee is coming out of the machine...
in our machine we wanted a stronger coffee so we adjusted the auto grinder (where the coffee beans are housed) to the finest setting thinking the finer the grind the stronger the coffee...after doing this the machine wouldnot make coffee...we sent it away while still under warranty and the tech said that the grind selection was too low so they just turned the grinder back up a notch and it worked fine ....dont know if this will help but it's worth a try!
Mar 26, 2009 | Krups Orchestro Dialog FNF2 Espresso...
Saece Talea - Dispensing failed
Take out the brewing unit and clean it in hot water.
/Mirran
Aug 30, 2008 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco magic comfort coffee machine grinder
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Jul 22, 2008 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
51 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
