Question about Frigidaire 20.3 cu. ft. Upright Freezer GLFU2067F
What is the orange light for at the top of my freezer
  • 14,384 Answers
Your freezer seals on door are bad causing it to ice up and the light is telling you to defrost,these models have a design flaw that causes this,seals around door have to be replaced to fix.Call your local appliance company and see if they can order you some new seals.
Posted on Oct 27, 2012
What is the orange light for on unidentified freezer?
If that orange light is on the front of the freezer, on the top or bottom, it is very likely a light telling you the freezer is not cold enough inside, and the food is in danger of spoiling.
It may also be a "on" light.
If you will find a freezer thermometer and put it inside, you can tell whether it is an "on" light or a warning light.
Usually freezers run temperatures of about 10 degrees Fahrenheit or lower if they are working correctly.
God bless your efforts.
Feb 11, 2016 | Freezers
Orange light is on instead of green light on freezer what does this mean
Most often the old freezer has three indicator lights.
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees - orange light : pressing the so-called S-switch which means that the compressor is running continuously. The S-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping".....
Dado
Jan 14, 2014 | AEG 10.35 cu. ft. / 293 liter Upright...
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
The standby light is still on
Are you sure it is a standby light? Usually the orange light is showing you it is in fast freeze. Try switching the orange button off and monitor the temperature. The freezer should cycle on and off, not run continuously.
Apr 15, 2012 | Whirlpool 10 cu. ft. / 283 liter Chest...
Orange light is on instead of green in the freezer does this mean anything?
no. the orange light is the temperature light and the green light is the mains light.
Apr 06, 2010 | AEG 10.35 cu. ft. / 293 liter Upright...
Red and Orange light staying on on my whirlpool chest freezer
try a total defrost,to clear any internal ice(every 12 months)then switch on and if you have a rapid freeze button leave on for 24 hours to get back to normal operating temp.if you have hard ice around the door seals then you have an air leak which you must sort out(try using a hot cloth to warm seals back into shape.....seals should fit all round, all the time.
Apr 04, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
Philips Freezer
I used to sell freezers.the green light tells you the mains is on and the freezer should work.The red light is to inform you the freezer is not low enough temperature,and the orange light is a fast freeze light to over ride the thermostat for use when introducing fresh food.It should not be used for prolonged periods as it may burn out the compressor although in your case you already have a problem and should seek advice or buy another freezer.If you get a cheap freezer thermometer it should confirm what I am saying.
Jun 24, 2008 | Freezers
Philips whirlpool AFG 027 freezer
The orange button is the "turbo boost" - for reduzing the temperature the fast way. Mostly used when first time use or you put in a lot of unfrozen things at once. When reaching optimal temperture it goes off automatically. The red one is the alert button. Not sure about the green one. Under normal conditions none of the lights is on.
Apr 02, 2008 | Freezers
Defrost light stays on
Try advancing the defrost timer manually.
Jan 16, 2008 | Freezers
Frigidaire 20.3 cu. ft. Upright Freezer GLFU2067F Logo
150 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
