Gap in door beosound ouverture
The doors work, but the right hand side is just a bit out leaving a 5mm gap, how can I fix this? The door is fixed with no obvious wobble
  • debra33
    debra33 Oct 27, 2012
    can anyone help with this?
  • debra33
    debra33 Oct 29, 2012
    also, is it a common problem with the equipment being of this age?
3 Suggested Answers
SOURCE: My glass doors only open
Hi, I am having the same problem.I am thinking of bringing it to a B&O repair centre but if you found a solution, I am very interested to hear it.
Posted on Jan 25, 2011
  • 6771 Answers
SOURCE: beosound ouverture speaker malfunction
The audio output ic in the stereo has malfunctioned, the solution! replace the semiconductor.
Posted on Mar 11, 2012
Bang and olufsen beosound 3000 does not read cd and loading stops. Can you help? Thanks
I never had like that. But "normally" there may be two reasons: CD fault or control board fault. Sometime main control keeps memorized wrong data and (in my Ouverture) CD unit simply is not responding and not loading - standing still. No way to move on except plugging off the power, press CD start on remote with no power, plug in power and try again. It clears bad data. I suspect it happened few times when I stopped CD player by remote or local main switch off.
Aug 19, 2014 | Bang and Olufsen Beosound 2000 Shelf...
How to fix door leak in ASKO D3231 dishwasher
Almost sounds like the machine was dropped and is out of square. Can you take it out of the install location and check the squareness of it on the drum and the rails? Also if you take it all the way out of the cabinet, you can see the other hinge locations and check them.
Jun 11, 2014 | Asko Dishwashers
Beosound ouverture speaker malfunction
Mar 11, 2012 | Bang and Olufsen Beosound 2000 Shelf...
Replaced Window Regulator, Works but when going up least a gap and doesnt close right
you have to make sure the alignment is correct when fitting new regulator, they leave around 5mm adjustment on the securing bolts to adjust the window, check these and refit always check before fitting door card etc. also on so models there is and adjuster on the arm that will need setting as well as this is angle alignment.
Nov 28, 2017 | 1998 Toyota Camry
I have a beosound century and whenever the glass door opens, it makes a ticking sound. I think it is something to do with the cassette dock. Please help.
This mechanism has overload coupling inside. When mechanical overload occurs the coupling may klick. Else doors are jamming so coupling is set too low. Check doors and if they are easy look at coupling - it has spring and screw adlustment at center of linkage drive whell.. I don't know Your model but in Ouverture it is easy to reach. But don't try if you are not experienced (You didn't damage minimum 10 sets in life :).
Jun 13, 2010 | Bang and Olufsen Beosound 2000 Shelf...
Ilve oven door adjar with a gap at the top
Yes but try removing the door usually a small lever on the hinge or just lower the door a bit and lift it off. Then put it back on and make sure it sits back down into the hinges. We had one that did the same thing and the door was just a bit out of the hinge.
Apr 09, 2010 | Kitchen Ranges
Bang Olufsen doors won't open automatically
unplug from mains,close doors by hand,reconnect mains,does the doors open or can you hear something trying to happen,if so the guide rails for doors may need cleaning/lubricating otherwise the cable drive may be detached(a workshop job).
May 27, 2009 | Bang and Olufsen Beosound 4000 Shelf...
Connecting ouverture to penta 3 active loud speakers
what are the speaker connections for left and right out put on the Beosound ouverture tape cd player.   there are 2 x 8 pin din sockets on the back what are the pin numbers?
mick55kennedy@gmail.com
Apr 08, 2009 | Bang and Olufsen Beosound 2000 Shelf...
27 people viewed this question
 Grubhead
Grubhead
