Question about Oreck XL Ultra Bagged Upright Vacuum
My Oreck upright is picking up fine, but is very noisy on bare floors. What could be causing this?
I have checked for clogs in the main pole. Could there be a clog under the roller?
  • 14,406 Answers
FLIP UP SIDE DOWN AND REMOVE COVER AND CLEAN BRUSH,SOMETHING MAY BE WEDGED IN THERE,I HAVE ON TOO.IF YOU NSTILL HAVE YOUR WARRANTHY,THEY WILL TUNE FOR FREE,I KEEP EXTRA BELTS,THEY STRETCH IN TIME.ALSO CHECK TO SEE IF ANYTHING IS BENT,RUBBING ON SOMETHING.
Posted on Oct 27, 2012
reddevil6
  • 1673 Answers
SOURCE: Oreck XL9100 Brush clogged with hair
The pulley will turn off, then the end will pull off. Some of the replacement brush rolls, the pulley may be pressed on and may or may not come off with out ruining the end.
Posted on Apr 24, 2008
#1 Taper
  • 1041 Answers
SOURCE: My Oreck XL was working fine, then when I vacuumed a shag rug is started smoking and smelled like something is burning. (I changed the bag, checked for clogs--none found, and roller brush is turning.
Even though the brush is spinning, the belt is probably worn out and stretched. when you vacuum the shag carpet, it puts more drag on the brush. try running it on a shorter carpet or hard floor for a few minutes. if it doesn't smoke, then you know it's your belt. if it does smoke, then it's probably the motor burning up.
Jim
Posted on Jun 03, 2009
  • 206 Answers
SOURCE: My Oreck XL is very dirty inside on fan and the
These units are called dirty air units because the dirt literraly runs thru the fan attached to the motor and is blown into the bag. Most newer vacuums are called clean air because the filter bag is in the path, and the dirt is sucked into the bag, never reaches the fan or motor.
I'd say if it is that dirty, may be a fire hazard, and you may have worn out the seals on the part down at base that pivots to a point that replacement is necessary.
(I'd blow out the dust and keep using if it was me, and then check again in a few weeks, before I replaced. But I like living dangerous.)
Posted on Jul 30, 2009
garing
  • 998 Answers
SOURCE: My oreck is very hard to push. what could be the
clean and oil wheels
Posted on Aug 11, 2009
  • 85 Answers
SOURCE: Oreck XL intellashield smells hot and smoky when
If it smells like burning rubber with white smoke its the belt make sure the brush spins freely. If its a electrical burning it will smell real bad you WILL be able to tell which then its a motor issue you can remove the bottom plate 5 phillips head screws opposite the motor youll see 1 screw remove it pry the duct out and look to see if there's anything stuck in the fan if not its the motor its self
Posted on Dec 17, 2009
Doesn't pick up
This could be a few reasons. Check and make sure your bag is not full of dirt, a full bag will make your vacuum's suction worse. Next check for clogs of dirt and debris. Check the nozzle and brushroll too. If you find no clogs and the brushroll and belt look good, it may be your vacuum fan is damaged and needs to be replaced.
Genuine Oreck Mataxalloy Fan Impeller R0008
GoodVac.com
800-775-6586
May 09, 2012 | Oreck XL21 Bagged Upright Vacuum
Vacuum smells and is not picking up well. Took the pole apart and I don't know hao to open the bottom.
To get into to the bottom of the vacuum, flip it to where you can see the bottom of the baseplate. Only unscrew the recessed screws...4 to 5 screws. Once you have removed those, the basepalte will pop off. It is probably just clogged at the bottom.
Sep 05, 2011 | Oreck XL Ultra Bagged Upright Vacuum
Is there a height adjustment for bare floor to thick carpeting?
The XL21 has a 2 speed switch use the lower speed on bare floors.The XL21 does not have an adjustment mechanism.
Jan 28, 2011 | Oreck XL21 Bagged Upright Vacuum
Oreck won't pick up dirt.
Check the roller brush, dust channel and then the back spine tubes - two parts which also holds the cloth bag - which holds it at the bottom via a spring. Unhook this, and prise up the rubber rings that hide the push in locks. Push the locks in and the spines should separate.You may need to undo the power cord since it comes out the top near the handle at the bottom. Check both spines and remove clogs with a thin round stick. Put everything back together slowly and switch on.
Jan 12, 2009 | Oreck XL Ultra Bagged Upright Vacuum
I NEED TO CLEAN UPRIGHT HANDLE TUBE IT IS CLOGGED
Its a simple operation but it will take some time.  On the back of the Oreck just up from the motor you'll come to the first rubber ring which hides the push/pin locks of the main spine. There are two or three on the Oreck depending on the XL model - slide them down to reveal the pin locks and push them in wards to unlock the main spindle pipe. At the same time ensure that the bag clip at the bottom has been unclipped and the cord is also free, taken off the hooks at the back. The main pipe/spine at the back is the main dust channel so this is the first place to check for a clog and then upwards towards the handle/dust channel feeder - there is usually a small screw on the square part at the bottom which loosens the main handle from the body of the spine.
Dec 27, 2008 | Oreck XL2200 Bagged Upright Vacuum
Not picking up dirt.
There is a Clog in the machine...
Somewhere between the motor and the bag.
When you use the machine, the dirt picked up by the roller has no place to go but backwards.
You will need to disassemble it and look for the clog.
Nov 22, 2008 | Oreck XL2200 Bagged Upright Vacuum
Vacuum billows dust
Its clogged. It needs to have a thorough clean out and this can be done by removing the sole plate / floor head where the beater bar is and checking to see that all the air ways or the dust channel that flows through t he main spine neck at the back is clear, checking the main spine at the back is clear and finally to check that there is no clogging at the top of the back spine as well. Oreck XL can become clogged quite quickly due to its relatively small suction tube openings and small motor.
Nov 13, 2008 | Oreck XL2200 Bagged Upright Vacuum
Reassemble of handle on upright
place handle half with the posts that hold the screws facing up.
silver pole with hole that goes completely throuigh goes over lower screw post (Long side)
static wire - L shaped end goes in small hole on opposite side of handle just below
vacuum switch hole, curve of wire should follow curve of handle and fits into top of
silver pole and pushes againt it providing push to hold siver pole.
hope this helps
Apr 02, 2008 | Oreck XL2200 Bagged Upright Vacuum
Oreck xl
Sounds like the Oreck is clogged. You'll have to undo the bag by the way of the clip in the middle at the back of the main black spindel neck and then at the bottom. Then take apart the main neck by pushing the rubber mounts upwards to release the pip fitting locks and holes. You should find that either the top of the neck or the bottom - where the dust channel feeder is located - is clogged. Either that or there may be a clog in the main dust channel after the roller brush or wedged into the fan unit itself - the Oreck XL is a dirty fan system which means clogged dirt can often get stuck between the dirt and the dirt channel.
Dec 28, 2007 | Oreck XL2200 Bagged Upright Vacuum
Oreck Vacuum Cleaner problem (upright)
The best solution to any Oreck vacuum problem is to replace it with another brand. You are going to continue having problems with the Oreck..Not that other brands don't have problems. But, at least with
other brands the problems don't occur as often. Belt burning up. clogs, roller brush bristle wearing down prematurely, cord breaking internally, etc.
P.S. Oreck is good at one thing. Marketing!
Aug 30, 2007 | Oreck XL2200 Bagged Upright Vacuum
Oreck XL Ultra Bagged Upright Vacuum Logo
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
