Question about Nikon Coolpix 990 Digital Camera
Broken latch on battery compartment
Excellent camera, but battery compartment door does not latch closed; ie. tiny piece of case has broken off. Possible solution(s)?
  • sy25 Jan 16, 2009
    Need permanent solution to repair of broken latch on battery compartment of 990 Nikon camera. Tiny piece of catch has broken off. Had one suggestion for using tape, but this does not hold well due to the pressure on the latch after batteries inserted.
  • sy25 Jan 16, 2009
    The broken off piece is not available. sy25
    Sergeant:
  • 367 Answers
Take it to a camera shop and see what it would cost to replace. you don't want to be messing with scotch tape.
You will be sitting there going to snap a great shot and poof your battery drops out. It shouldn't be too much to repair at your local Ritz or camera shop in your area
Posted on Jan 16, 2009
  • 716 Answers
Buy A Replacement Part I Will Give You A Link.
Click Here
Unless Of Course You Wanna Super Glue The Piece Back On.
    Brigadier General:
  • 5,158 Answers
Do you still have the piece that broke off ?
Robert
    Genius:
  • 1,847 Answers
Best solution is to tape (transparent) it.
  • 535 Answers
There is one solution but u need scrip camera u have to do this take one bed same model of camera take that camera tiny case & fit in your camara or take a sample of that part & go to electronic consumer store if u get same the u can replce it
  • sandip panchal
    sandip panchal Jan 16, 2009
    or u can stik it on by tape
SONY DSC-W800- Memory card door flops open very easily. Is there a replacement spring, door, or part combo that I can buy to remedy this?
Carefully inspect the door latch mechanism (you may need a magnifying lens) for dirt, wear, or broken tabs. If you're lucky, all you would have to do is pick out dirt or lint with a pin or cotton swab (I recommend removing the battery before cleaning operations).
If the latch is worn out or a retainer tab is broken, your options are limited to salvaging parts from a similar camera (lots of taking apart and reassembly work), fabricating and gluing on a replacement piece, or using a strip of tape to hold the door closed. The tape could be Velcro loop with a strip of adhesive-backed hook material on each side of the compartment door..
Aug 05, 2017 | Cameras
Battery door won't stay closed on Sony Cyber-Shot DSC-S90 Digital Camera
The battery door latch is most likely damaged/broken. Try using a piece of duct tape to keep it closed. I've done this on several cameras with battery door latch issues & the doors stayed shut just fine.
May 20, 2014 | Sony Cyber-Shot DSC-S90 Digital Camera
Nikon f60 door broken
Two, one on top and one on bottom
Apr 21, 2014 | Nikon Photography
Fuji S5000 camera problem....The battery door will not latch because the cheap plastic retaining nipples inside the battery box have worn down/or broken. Tape will not even hold door closed! The retainers...
You could use a piece of velcro as a strap but I would start looking at ebay or other places for the parts to fix it. Sooner or later someone will sell it.
Mar 23, 2010 | Fuji FinePix S5000 Digital Camera
I have a CANON camera A610 - since i changed the batteries it is not powering. The batteries are new. Please advise the possible problem
Double check that the new batteries are actually good. Note that so-called "heavy duty" batteries are terrible for use in digital cameras.
Next thing to check is the battery door slide switch. This is a tiny black micro-switch in the the battery compartment. It's activated by a tiny plastic piece on the battery door slide mechanism that may have broken off.
Dec 17, 2009 | Canon Cameras
The battery door hook which is situated on the body is broken. It seems the hook (latch) is molded on the battery compartment (body) How can I fix this. I am fond of this camera and I have the full...
If you have all of the pieces, you can use crazy glue to make the repair, otherwise take your camera to any camera shop where they will have access to whatever broken components need to be replaced. Regards, Joe
Nov 13, 2009 | Olympus Camedia C-5050 Zoom Digital Camera
Camera door thats holds battery small grey latch is broken
Try partstore.com they might be able to solve your problem. Also look at the latch and determine if it is attached to the front of the camera case or the back of the camers casing I am assuming it is attached to the back then you might consider caling HP back and ordering the Back or Front cover Assembly. Small pieces like this usually don't come by themselves you have to order an assembly, so when when u call for parts ask for Back cover assembly or front cover assembly, which ever it is attached to or apart of. Asking for a perticular piece they will not usually know what you need. You have to talk to them in technical terms.. Hope this helps you out...
Sep 21, 2009 | HP R967 Digital Camera
Sony Cyber-Shot Battery Compartment Door Broken
I'm having the same problem with my DSC-W1 camera. I dropped my camera and the battery door latches broke.
I found a replacement door on Ebay for $9.95
I followed the instructions in the description and easily removed the broken door from my camera. Now i'm just waiting on the new door to arrive so I could slide the new door in.
I hope this was helpful.
Here's the seller I bought the door from. Hopefully the seller has more doors. =) :
http://cgi.ebay.com/Sony-DSC-W1-battery-door-silver-battery-cover-lid_W0QQitemZ110250995036QQihZ001QQcategoryZ107892QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
In addtion, I found the last two posts on this forum very helpful:
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscw1_question.html?qid=2382
Good Luck! =)
Mar 18, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
Nikon Coolpix 990 Digital Camera Logo
237 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
