Kingavon is there a reset button?
I have been given one of the above by a friend - the heater comes on when the buttons are held down but won't stay on. Is there a reset button?
Hold the button down longer
Posted on Oct 27, 2012
bluegreenash
  • 661 Answers
SOURCE: reddy heater won't stay on
sounds like a Thermal Cut-off this is a small sensor that detects if the heater has ignited properly, sounds like this sensor has failed and the heater shuts off to prevent from gassing anyone
Posted on Nov 02, 2007
tbugger
  • 232 Answers
SOURCE: heater will not run
You don't say, but I am assuming that the motor is running and there is combustion in the combustion chamber and the heater is running fine, then the reset trips. Is this correct? If so, chances are the Safety Control (reset) is defective. Part number HA3003. The photocell could also be at fault. Check for a dirty lense on the photocell.
But---If there is no combustion in the chamber, then the photocell detects a no-flame condition and then it trips the reset.
Troubleshooting tips for a Spark Plug type heater
Posted on Nov 16, 2009
  • 5 Answers
SOURCE: heater will not stay lit after releasing button
check the regulator... pressure may be to high
Posted on Dec 12, 2009
SOURCE: Reddy Heater will not stay lit
Thermocouple it going bad had same problem, you Should replace it.
Posted on Jan 03, 2010
  • 234 Answers
SOURCE: Torpedo Reedy heater 150,000 BTU starts &
There is a flame sensor inside the burner unit. The sensor is like a photo cell that must see the light of the flame or it will tell the burner control to stop the power. You need to see if there is a soot film on the lense of the sensor and make sure the sensor is aimed straight. If the sensor is clean and aimed straight (and the problem persists) then there may be a clogged nozzle that is giving a poor flame and the sensor does not see a good flame therefore shuts down the unit. If the nozzle is at fault, then you for sure need to replace the oil filter. New nozzles are $4-8 and the size & spray angle is stamped on the nozzle. If there is still a problem, then you need to see if the pump is giving approx. 100psi pressure, then finally (the last step) would be to replace the burner control $60. Goodluck< Macgivor
Posted on Jan 16, 2010
How do i reset the mp252 cannon printer ink absorber error?
Dear
Resetting the waste ink absorber on a Canon printer can resolve some error codes that appear when turning it on.
  1. Make sure the printer is turned off.
  2. Press and hold the Resume button (triangle inside a circle).
  3. Whilst it is held down, hold down the Power button. The green led light should come on.
  4. Keep the Power button held down. Release the Resume button and then press it twice. The light should go amber, then green again.
  5. Release the Power button.
  6. Press the Resume button four times and then press the Power button straight after to confirm the selected action (Reset Counter Absorber).
  7. Turn off the printer and then turn it on again
Thanks.
Feb 10, 2015 | Cannon Office Equipment & Supplies
How to reset canon pixma ip2800 series
dear
  8. Thanks.
Feb 02, 2015 | Canon Office Equipment & Supplies
How to repairing for error 5b00 canon mg5370 pixma printer
Hi ..
Try to Reset Printer Ink Obsorber..
Apr 05, 2014 | Office Equipment & Supplies
How to reset error E5 on nashua coprier
theres no e5 on aficio 450must be sc542/546 problem with heater try to reset code press yellow
button then 1 0 7 then press red button keep the red button held down 4 secounds then select
copy 1 turn copier off then switch back on
Nov 11, 2010 | Ricoh Aficio 450 Copier
How does the reset work? I am helping a friend troubleshoot his water heater. One of the wires that connected the pig tail to the power block fried inside the water heater cover. I decided to remove the...
The reset button is set up to open the circuit if excess current is drawn by a failed Element. It works by getting hot and switching off due to current above its rating. The burnt wiring more llikely happened over a period of time because of a resistive joint in the block getting hot due to the high current that water heaters consume. It seems that the element has failed if the reset button does not get the system working.
Sep 17, 2010 | Rheem 81VP15S Point-of-Use Electric Water...
Kingavon electronic safe 28
  1. The original factory code is 1-5-9 A (or B) to open the safe. There is usually an override key for your safe in case you have lost your code.
  2. Once the unit is open, you can reset the combination by pressing the red button, the yellow light will come on. Input a new code 3-8 numbers and then either the A or B button to finish the code.
  3. Test your new code several times before locking.
  4. If you don't have an over ride key, the first three digits of the serial number should be the key code.
Feb 24, 2010 | Safe International Digital Electronic Safe...
My backett hell R7184B furnace is will not reignite when I hold the reset button down. I had run out of oil yesterday and believe I've bled all the air out of the lines. I held the reset button down for 30...
You may still have air in the line. You will need to hold down the button again with a hose on the bleeder screw and open it. Do this until no bubbles come out of hose. Just keep holding the reset down for up to a minute.
Feb 21, 2010 | Honeywell Heating & Cooling
How do i reset my xr-10x lamp life on the projector
Hold down the MENU/HELP, ENTER and down arrow buttons and press the standby/on button. Keep holding down the 3 above butons until the LAMP 0000H appears on the screen. That will indicate that the timer has been reset. Please note that all 3 buttons MUST be held down when the ON button is pressed. I can tell you that it may take a few tries to get it correct. Holding down the 3 buttons at the same time is tricky.
Dan
Jan 08, 2010 | Sharp XR-10X Multimedia Projector
How do you reset the "maintenance required" on a 2006 Lexus LS 430?
1. Push the “ODO/TRIP” button to change the display to
blank.
2. Turn the ignition off.
3. Turn the ignition switch to “ON” with the trip meter
“RESET” button held down.
4. Keep pushing the “RESET” button for longer than 5
seconds after the ignition is turned on.
After the above operation, the master warning light comes
on, a warning tone sounds and the message
appears to inform you that the engine oil maintenance data has been reset.
Sep 14, 2009 | 2006 Lexus Ls 430
ASKO T700
I had the same problem. Turns out the reset button on the back of the dryer needs to be pushed; when you push the reset button you should hear a click. If you do not hear a click the problem was probably not the reset button. The button shuts down the dryer heating elements if they are getting too hot and also keeps the drum from turning unless the start button is held down.
If you push the reset button and the dryer starts to work again, I strongly recommend that you stop the dryer and investigate why the heater elements overheated. In my case there was lint/hair build up on the heater elements themselves. Extensive dryer disassembly is required to properly clean the heating elements but it is worth the prevention of a house fire. While you're at it, clean the rest of the machine and the duct work.
Hope this helps
Jun 20, 2008 | Asko T700 Electric Commercial Dryer
Heating & Cooling Logo
157 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
