Question about Vacuums
What's your problem? Oreck XL Power Team Lightweight Vacuum not picking up dirt
Not picking up dirt, may be brushing backwards or blowing
  • jeannette Oct 27, 2012
    This is brand new. New bag. I don't think it is sucking up dirt but also it may be turning backwards but too fast to see.
I have just purchased a oreck xl how do i move the handle so i can hoover
the floor
Posted on Dec 13, 2012
SOURCE: My Oreck XL has quit sucking. The brush turns but
Same problem here with XL9100. Bag would not expand implying no suction. Motor ran and brushes turned. Easy disassembly using common tools found that a plastic bag had been sucked up and caused a blockage prior to the impeller. Cleaned up, reassembled, and everything worked fine after that.
Posted on Nov 06, 2009
ukvacfan
  • 328 Answers
SOURCE: oreck xl
Sounds like the Oreck is clogged. You'll have to undo the bag by the way of the clip in the middle at the back of the main black spindel neck and then at the bottom. Then take apart the main neck by pushing the rubber mounts upwards to release the pip fitting locks and holes. You should find that either the top of the neck or the bottom - where the dust channel feeder is located - is clogged. Either that or there may be a clog in the main dust channel after the roller brush or wedged into the fan unit itself - the Oreck XL is a dirty fan system which means clogged dirt can often get stuck between the dirt and the dirt channel.
Posted on Dec 29, 2007
ukvacfan
  • 328 Answers
SOURCE: vacuum
Yep check the hose at the back as it may well be clogged. Also undo the soleplate/floorhead and have a look up the dirt channel behind the floor brush. Either that take off the main bin and check the dust channel leading down to the hose.
ukvacfan
  • 328 Answers
SOURCE: Oreck won't pick up dirt.
Check the roller brush, dust channel and then the back spine tubes - two parts which also holds the cloth bag - which holds it at the bottom via a spring. Unhook this, and prise up the rubber rings that hide the push in locks. Push the locks in and the spines should separate.You may need to undo the power cord since it comes out the top near the handle at the bottom. Check both spines and remove clogs with a thin round stick. Put everything back together slowly and switch on.
Posted on Jan 23, 2009
ukvacfan
  • 328 Answers
SOURCE: Oreck Commercial XL 21
Check that the beater bar is completely clear of thread, this will bring the brush roll back to normal. Also check the sides of the brush roll doesn't have anything such as thread or thick string at the sides.
Posted on Jun 19, 2009
Hoover cyclean brush stopped revolving
The belt may be broken or worn If your cleaner is not picking up fluff and hair from the carpet or has become heavy to push it is possible that the belt has snapped. This belt makes the sweeping brushes spin round underneath the cleaner and brush dirt into the path of the air suction. The brushes also give that 'groomed' look to your carpet by gently brushing the carpet fibre. If you pick up something sharp or debris gets jammed in the brushes then the belt may snap. Also over time your belt will stretch, so it's a good idea to change your belt once per year to ensure the cleaner picks up dirt effectively.
Dec 14, 2016 | Hoover Vacuums
Vaccuum picks up dirt going forward, but drops dirt when going backwards?
If it is an upright, check for a clog somewhere in the line leading to the canister. Also, the clog may be at the top of the canister.
Dec 24, 2014 | Vacuums
My oreck will not pick up dirt from my carpet I cleaned the roller brushes well but there is a tiny bit of dust blowing out of the unit from the bottom
The nozzle behind the roller brush is probably clogged. Take a screwdriver and stick it in there and work it around and see if it loosens the clog.
Aug 25, 2013 | Oreck XL Ultra Bagged Upright Vacuum
My e series rainbow has stopped picking up and the dust gathers on the top of the nozzle. It will pick up a little when I push it forward, but when I pull it back dirt and debris comes out of the noz
<p>Did you recently remove the brush roll? If you installed the brush roll in backwards, then this can happen. You can <a href="http://www.rainvac.com/rainbow-vacuum-manuals">download the manual </a>on how to replace your belt and install brush roll correctly.<a href="http://www.rainvac.com/rainbow-vacuum-schematics"></a></p>
<p>RainVac </p>
<p><a href="www.rainvac.com">www.rainvac.com</a></p>
<p>800-523-0510</p>
Feb 23, 2013 | Rainbow E series Canister Wet/Dry Vacuum
My Kirby seems to be putting more dirt on the floor than what it is picking up? The brush roller is turning but it leaves dust streaks . It also shoots particles out the side instead of vacuuming it up....
Hi there. It sounds like you belt may be stretched. Simple turn vac upside down, start it up and carefully press your hand on the brush. If the belt is stretched the rollewr will stop turning. If this does not help, you probably have a clog in the power head area. Hope this helps, Chris
Feb 09, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Eureka Maxima 12 amp vaccum cleaner is not picking what can be done to make it pick up?
remove and clean the filter ( tap and brush filter or use a air compressor to blow out filter ) --- also check the vacume hose near the floor attachment for any dirt and debris that may be clogging the line. this should bring your vacume to full operation.
c...
Jan 22, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
My hover isnt picking anything up?????
Your hose (or what ever your machine uses to get the dirt from the floor to the bagless dirt area) is clogged. You may be able to blow the clog out "backwards" using a 'shopvac' type vacuum.
Thanks for your question at FixYa.com
Jan 04, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hoover Tempo Widepath Blows Dirt Out Back on Hard Surfaces
lots of times switching to hard surface floors you need to slow down because the air flow that does the actual picking up of the dirt can't work as fast as the spinning brush so the brush is throwing the dirt out the back before the suction can pick it up. Try slowing down
Jun 11, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Motor runs fine and hose not clogged will not pickup dirt
This may sound silly, but have you checked the belt? A lot of Eureka vacuums use the vac motor to run the brush, and if the brush is not running the vacuum won't pick up. Another thing to check is the condition of the fan blades.. if they get worn they will push air out of the exhaust ports, but not push enough air to pull the dirt into the vacuum bag. Another thing to check is the length of the bristles on the brush... you can change a lot of the bristle strips and save the cost of a whole brush roll.. All of these fixes are under $10.00 (Belt: $1-2, Brush Strip $3-6, Fan $5-10) at most places.
Jan 19, 2009 | Eureka Vacuums
Vacuum
Jul 14, 2007 | Dirt Devil M084600 Dynamite Bagless...
Vacuums Logo
147 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
