Question about Atari Magic: The Gathering - Battlegrounds for Windows
Installs fine on windows 7 but does not run - Atari Magic: The Gathering - Battlegrounds for Windows
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 50 Answers
Have you tried right clicking the game icon and setting compatibility to windows xp service pack 3 and putting a tick in run as administrator
Posted on Dec 27, 2013
Epson Perfection 2450 Photo scanner won't run on Win 7 Ultimate.
is windows 7 32 bit version or 64 bit version . Suggest downloading drivers that match the windows 7 operating system and installing them.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14558&infoType=Downloads
Mar 22, 2015 | Epson Perfection 2450 Photo Flatbed...
Tip
How to Install Windows 7 from USB Flash Drive
what if you don’t have DVD-ROM and you are running Windows XP, you might have guessed in this case we can’t install windows 7. Since Windows 7 ISO size is around 2.24 GB so its obvious that you will need to burn windows 7 iso on DVD and another issue is you can’t start windows 7 installation by mounting ISO file on windows XP as Windows XP upgrade to windows 7 is not allowed. In such situation installing windows 7 from USB pen drive is feasible solution.
Here is small guide on how to install windows 7 from USB flash drive or USB pen Drive for Windows XP users.
How to Install Windows 7 from USB Flash Drive Requirement:
USB Pen Drive (Min 4 GB)
Windows 7 ISO (32 bit or 64 bit)
MBRwiz Download and Extract it on your hard drive (Diskpart utility for Windows XP doesn’t detect USB drive as Disk hence we need to use this free utility to make bootable USB drive).
1. Connect your USB Flash Drive to your computer Format USB drive
2. To Format USB Flash Drive Go to My Computer -> Right click on USB drive and select Format from context menu.
3. Now go to Start Menu->run->cmd (Open Command Prompt) and Type following command
convert i: /fs:ntfs (Where “I” is your USB drive latter)
4. Mount Windows 7 iso as drive (You can use Freeware MagicDisc download from here).
5. Type Start->run->cmd
Now dir to directory where you have extracted MBRWiz and run following commands
mbrwiz /list (note down disk number of your USB Pen drive)
mbrwiz /disk=X /active=X (X is Disk Number of your USB Drive)
exit
6. Now open another command window and type following command
J: (Drive letter of Windows 7 iso mounted with demon tool)
CD boot
bootsect /nt60 Y: (Y is drive latter of your USB drive )
7. Now copy all files from drive where you have mount Windows 7 iso
8. Now reboot your computer and press F9 to get your BIOS screen and select USB drive as your boot drive.
9. If every thing goes fine, Your Windows 7 Installation should start from your USB drive.
on Jan 10, 2010 | Computers & Internet
Windows 7 running slow after memory upgrade
If it's Windows 7 32bit it has limits on the amount of ram it can use.
Google it and see.
Jan 31, 2012 | Dell Precision Workstation 670 PC Desktop
I have Windows 7 and it my daughters hello kitty photo booth (digital camera kit) said that it would only support up to VISTA which I had until I upgraded.....how can I get this to work on my Windows 7?
Have you tried installing it on Win 7? Most software made for vista will run fine on Win 7. Otherwise you can try running the program in "XP Compatability Mode". You can do this by right clicking the installation file (or if installed already, the shortcut you use to open the program) and click properties. Then click the Compatability tab and check "run this program in compatability mode for:" and choose Windows XP (Service Pack 2)
Good Luck
Jan 21, 2011 | Cameras
I bought keyboardworks v1.1 it worked fine for my old xp computer. Now I switched to windows 7 and it does not work. Any fixes?
Since this software was designed to work with Windows XP or earlier. It may not run in windows 7 normally, but you can run this application in Compatibility mode.
Windows 7 comes with Program Compatibility troubleshooter, using which you can run older programs in compatibility mode.
To run the Program Compatibility troubleshooter
1. Open the Program Compatibility troubleshooter by clicking the Start button and then clicking Control Panel.
2. In the search box, type troubleshooter, and then click Troubleshooting.
3. Under Programs, click Run programs made for previous versions of Windows.
4. This would scan the computer for incompatible applications and list them, keyboardworks .
5. Click next. this will try running in Windows XP mode.
6. If sucessful save the setting and u should be good to go, else try installing this application in Compatibility mode.
7. right-click choose properties on setup.exe
8. click on compatibility tab. put a check on run this program compatibility mode for and choose windows XP
9. put a check on run this program has administrator. cluick apply and ok and install this application.
10. run the application, if it does not work repeat the steps 1-6.
May 18, 2010 | Computers & Internet
HPs20 and Windows 7 - is there hope?
You can try using the software provided for Windows XP and run it in compatibility mode under Windows 7. Download it here
Before installing the software, right click the setup program > Properties >
Compatibility > check mark Run this program in compatibility mode and then choose the OS you have downloaded the software driver for.
It should install and run fine.
Dec 30, 2009 | HP Photosmart s20 Film Scanner
Drakan order of the flame engine crashes when i start a new game. i have windows 7 but im running as admin and in compatability mode for win xp sp2. what else can i try?
You could try installing the DirectX version the game uses. (probably on disk)
You can also try to download this Windows Virtual PC.
Windows Virtual PC emulates Windows XP on your Windows 7 PC, so that you can run older applications that won't run on Windows 7 otherwise.
You will however need a processor capable of virtualisation.
Virtualisation check and download here: http://www.microsoft.com/windows/virtual-pc/download.aspx
After installing Windows XP Mode you will need to install the game again in this XP emulator, but after that it should run fine.
I hope this helps,
Yannick.
Dec 08, 2009 | Activision Drakan: Order of the Flame for...
Just installed windows 7 have pentium 4 graphics only display in 640 by 480 when i was vista graphics was fine driver in windows 7 says got the most up to date driver ..fix probs now in windows 7 says i...
Then you need a graphics driver that will support Windows 7. If your motherboard onboard VGA is up to Windows Xp only and below then probably you will not able to use it to that kind of operating system like windows vista, and 7. My suggestion is that you buy a graphics card that will run and support windows vista and windows 7.
Nov 01, 2009 | Intel Desktop Board D815EFV (BOXD815EFVLU)...
Hi, HP Scanjet 2200c (Scanner) does it work for windows 7?
Hi dorine...
HP Scanjet 2200c drivers (xp/vista/win7/win8/mac) can be found at driverupdate us It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Oct 07, 2009 | HP ScanJet 2200C Flatbed Scanner
Atari Magic: The Gathering - Battlegrounds for Windows Logo
106 people viewed this question
Top Atari Video Game Consoles & Games Experts
Hanzu
Reggie brown
Nikki  Mclean
Nikki Mclean
Are you an Atari Video Game Console and Game Expert? Answer questions, earn points and help others
