Question about Mtd Genuine 9460897 Snow Blower Auger Clutch Cable
How to change short auger cable on MTD snow thrower
3 Suggested Answers
SOURCE: how to adjust a 9460897 mtd snow blower auger
On the handle end (usually) of the cable is a curved metal connector. Attached to the connector is a threaded rod with a nut. Attach a pair of pliers to the threaded cylinder that the threaded rod goes into. Loosen the nut. Turn the threaded cylinder into the threaded rod to tighten or out to loosen. When you have the correct adjustment, tighten the nut back down onto the cylinder. To be correctly adjusted, pull the cover off the auger belt and push down on the handle. The spring attached to the cable at the pulley end should stretch out when the handle is fully depressed. Spring tension keeps the belt tight. iaff801.jpg
Posted on Feb 15, 2011
  • 144 Answers
SOURCE: My MTD 10hp auger will
Yes there are 2 belts one for the drive and one for the auger. If you remove the cover on top that is located between the engine and the auger housing you can check the belts. The auger belt has come off the pulley or is broken. Hope this helps you out. Best regards and good luck.
Posted on Jan 09, 2011
Auger will not engage
blocked or frozen blower inside of housing, move to warm area or chip out the ice
youre going to need a new belt after burning that one up
Feb 06, 2014 | Mtd 2 Satge Snow Thrower 26"
My yardmachine snow blower 8hp auger won't turn. I replaced the cable and belt but it still won't turn. What else could be wrong?
Check the auger shear pins replace if necessary with correct parts(not regular bolts).
If auger and the impeller are not turning your cable is out of adjustment.
If only the auger doesn't turn, and the shear pins are ok then the brass/bronze gear has shredded which is why proper shear pins must be used. Donyboy73 on youtube show how to replace that gear on an older but similar MTD affiliated blower.
Feb 16, 2013 | Yard Machines 24" 208cc Two Stage Snow...
My MTD 10hp auger will not turn. I adjusted the auger cable by tightening the bolt on the handle. I disconnected the spark plug and checked the shear pins on both sides of the auger. They are both still...
Jan 08, 2011 | Mtd Genuine 9460897 Snow Blower Auger...
Snow thrower is self propelled. was working fine then stalled
check the bearings in the auger sounds like the froze up and now they need to be replaced (the smoking you saw was from the belts slipping on the pullies)..good luck
Feb 26, 2010 | Craftsman 16" High Garden Tractor Snow and...
Mtd Genuine 9460897 Snow Blower Auger Clutch Cable Logo
794 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
