Does it try to to drain or just sit there during the drain cycle?
Hi Richard
Hi richard, I really appreciate your help, but I've now established that it's an electrical fault, requiring multimeter etc to further diagnose, so I'm getting professional help. Thanks again. Neil
richard, i have a LSQ8500JQ1AND IT TOO JUST STOPS WHEN THE TIMER GOES TO DRAIN ITS10 YRS OLD AND I'M LAID OFF SO THE FUNDS ARE VERY LIMITED??
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Humming noise is due to loose connections on drain pump or due to faulty drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Hi
Hi
Hi
Hi
Hi
