Question about AEG Ovens
Dead micromat combi aeg 663e
Hi, I'm trying to repair a AEG Micromat Combi 663E Oven. The buttons PCB was detached and probably caused a shortcut somewhere. The fuse was blown. I did exchange it but when powered on nothing happens, no display no power, nothing. Can anyone help or does anyone know where i can find a service manual? Thx!
  • Milan D Oct 31, 2012
    Let me make this a little easier for you guys. As a repairman how would you tackle this? What i've already did: Opened it and checked and replaced the blown fuse. Power is coming in. What can I measure further and where could the problem be located?
  • 619 Answers
SOURCE: AEG Microwave oven MC2660E - no power.
Hi , open open the microwave oven check the fuse , if open replace with the new fuse .
Posted on Feb 17, 2008
  • 10 Answers
SOURCE: AEG Oven
try setting the clock, it may be automatic
Posted on Mar 22, 2008
  • 139 Answers
SOURCE: AEG double oven- fan assisted not heating up
you oven element has failed.
it is located at the back of most electric ovens sometimes at the top,,
the insulation of the element has failed and when you come to remove it you will see visually see the damage... its easy to replace as there are only wires attached to it and only a few screws to undue to get to it..
hope this helps cheers
the washdoctor
Posted on Aug 24, 2008
SOURCE: Wiring Diagram for AEG Build-in Electric Oven B2.6L
can i use 13amp socket for a electric oven
Posted on Oct 25, 2008
SOURCE: does a rational combi oven have a cut off switch ?
they have a high limit for both boiler and hot air, and over current(motor)!! it sounds like you may have blown a control fuse!
Posted on Dec 21, 2010
My AEG oven needs a PC board, but I cannot find where I can buy one. Can anyone help pleases?
PCB for D5701-4-M is obsolete. I certainly could not find one. Alternative is repair. I used QER Ltd via ebay. Involves removing and identifying part number of board and ordering repair via ebay listing. The trick is to find the correct listing for your board number as it will not be listed under AEG D5701-4-M. For instance, my D5701-4-M, part no. 944171390 (found on plate in bottom right hand corner of main oven) uses board NPPUGN104. It was listed in ebay under Repair pcb / module Zanussi Z0B1060X. Took two attempts to fix, but so far so good.
Nov 19, 2012 | AEG D5701-4 Electric Double Oven
STEAMER NOT WORKING SHOWING E8 FAULT
Hi, error 8 is showing you there is something wrong with temperature control pot. This is soldered to the pcb so you need to get someone to replace this or check the connections, otherwise the pcb needs replacing
Nov 28, 2011 | Combi Steamer electric built in steam...
MY AEG OVEN IS IN SAFE MODE HOW DO I GET OUT OF THIS MODE
Just found out that the 'safe' mode on my oven is for child protection. I had to press 'p' en 'minus' (-) at the same time for a few seconds. Problem was solved immediately. My oven is an AEG-Electrolux Micromat-Combi.
Apr 23, 2010 | AEG B8139-4-M Electric Single Oven
Moved into our new home. AEG Oven with no manual
Hi I am Vortash the manual for this Oven is available free at http://www.safemanuals.com Regards Vortash
May 18, 2009 | AEG B3101-4 Electric Single Oven
Aeg competence b2190-1m oven not heating
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
please rate my solution.
Thanks
Jan 27, 2009 | AEG B2100-4 Electric Single Oven
AEG U7101-4 Top Oven tripping the fuse after a few minutes
It is more than likely the oven element, as it gets
hotter the insulation in the element is breaking down and causing the trip to operate..
Remove the panel at the rear of the oven and you will see the element there, undo the screws and pull the element towards you, carefully, detach the 2 wires and remove the element.
Be careful not to lose the 2 wires behind the oven rear.
Replace with new element.
Cannot give you a part number, you will have to go to aeg web site.
Dec 12, 2008 | AEG U7101-4 Electric Double Oven
AEG Oven
Mar 22, 2008 | AEG B2100-4 Electric Single Oven
B3101 AEG oven cuts out after approx. 15 minutes - why?
this is probably the thermal cut-out causing the problem. not sure where it is located but possibly on the roof of the oven or in the rear casing near the fan. however, the cause may be lack of ventilation to the unit as a whole
Nov 21, 2006 | AEG B3101-4 Electric Single Oven
Ovens Logo
294 people viewed this question
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Samyfam
Samyfam
Are you an AEG Oven Expert? Answer questions, earn points and help others
