Question about John Deere Garden
John Deere LA105 no compression suddenly stopped, compression coming out of air filter
libaredneck
  • 119 Answers
SOURCE: my john deere 345 shuts down while running.
check the tank for debris blocking fuel outlet. also change fuel cap as it could be pulling a vacuum on the tank.
Posted on May 05, 2009
  • 394 Answers
SOURCE: Our new to us john deere 345 tractor won't keep running
You may try blowing backwards from behind the fuel filter into the gas line. Not to much air pressure though. Make sure the gas cap is off.
Posted on Mar 13, 2010
SOURCE: John Deere will not start.
If you have gas running down to the carberator ( take the fuel line off and make sure there is gas running to it or there may be a screen or filter plugged by the tank or on the way to the carb) if there is gas there the problem lies in the carb itself. If you have some mechanical ability you should be all right as it is not rocket science. If you are comfortable with taking the carb apart the first thing i would check is the needle vavle. With the carb apart you will see a big brass looking thing this is the float, right above that is the neddle valve, that is the first place they seem to stick on me. Move the float up and down if the neddle above it doesn't move or sticks there is your problem. Spray it with carb cleaner and see if it moves freely. You may have to dismantle the carb to get it to work freely. If it won't buy a carb kit and install all the new gaskets needle valves and jets ( this is a very good ideal any how) Also make sure any little ports in the carb are open ( in the bottom of the carb there may be tiny little holes that are plugged) find a very small wire to clean them with and also make sure when you are done you can spray carb cleaner thru them. This is why they have a small straw on the can with it ( watch your eyes and wear safety glasses as you never know where it will spray out from) That stuff will dry your skin out fast so don't get it in your eyes and you may want to wear rubber gloves. Also be very careful when putting back together as there are little pieces that like to slide around and fall out or may get bent even worse you don't want them in your motor. Also try to count every screw you turn as these are jets and you will want to put them back to the place they were set at cause it's a pain to get them set right by adjusting them later. Do not force anything putting it back as you may bend the jets or float and you will have to take it apart again and replace them as well. Take your time and be patient and you will be just fine
Posted on May 08, 2010
Testimonial: "thanks...you gave me encouragement to give it a try. I took off the shroud, air cleaner box and couldn't take off the carb as there are no heads on the four bolts that hold it on. Looks like it was designed not to be removed? I took off an inspection plate on top of the carb and cleaned all of the channels and ports within with carb cleaner and compressed air...still no gas flowing thru carb...unless I force with compressed air. Any other thoughts? It is a twin cylinder OHV B/S. Thank you. "
spiegela
  • 3 Answers
SOURCE: john deere 445 tractor v twin 22 hp engine, john
Where did you get it fixed for $300. Dealer wants 6 hours labor and $400 in parts. Total cost will be $1,000.
Posted on Jun 05, 2010
SOURCE: John Deere ZTRAK 737 zero turn - runs rough - one plug
My idea would be to replace the coil to that plug
Jim Kite paris, il
Posted on Apr 15, 2011
John deere la105 transmission belt
Greetings, I read your question and I think Reliable-Store can help you in this. Here's the site link.
Best Manuals
Mar 29, 2017 | John Deere Garden
John Deere LA105 lost power
Hi Hank:
Did you hit something with the mower, or did it happen gradually?
Probabaly a good idea to start with a basic service:
- Clean air filter
- Clean fuel filter
- Flush carbuerettor
- Fresh gas?
- Change spark plugs
- Change oil and filter
- Underside of mower deck clean and free of all built up grass?
Hope this helps.
May 09, 2015 | John Deere Garden
I need a wiring schematic for the LA105 John Deere lawn tractor
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt?search=model&model=la105
Jun 14, 2014 | John Deere Garden
I need to clean an air filter for a john deere 55ev chainsaw
just wash filter in petrol and blow of with compressed air , I would also remove spark arrester from exhaust and clean that by burning carbon of then blowing with compressed air , if you chainsaw still runs bad it needs carby serviced and retuned .
Mar 28, 2014 | John Deere Garden
John Deere starting problems
check to see if you loose spark when this happens the coil could be failing
May 10, 2012 | John Deere Garden
Just changed the fuel filter on a John deere 1020, is there a way to prime the injector pump?
If the fuel filter is full when replaced it shouldn't be necessary. But if you have access to compressed air, put air to the fuel tank and that will do it. Hope that helps ya.
Dec 21, 2010 | John Deere Fuel Pump Fits 1020 Thru 4230
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
