Question about John Deere Garden
John Deere LA105 no compression suddenly stooped
bargainbin2
  • 123 Answers
SOURCE: I have a John Deere model# LA105 , and it is
If the blades are not bent than the deck could be bent from steping on it or one blade is on upside down, a bearing may be down in one jack shaft. Or maybe a deck hanger is bent if so there are adjustment bolts on the hangers to raise or lower eather side. Also make sure the front of your deck is at lease 1/4 inch higher than the back of the deck.
Posted on Sep 12, 2009
spiegela
  • 3 Answers
SOURCE: john deere 445 tractor v twin 22 hp engine, john
Where did you get it fixed for $300. Dealer wants 6 hours labor and $400 in parts. Total cost will be $1,000.
Posted on Jun 05, 2010
  • 252 Answers
SOURCE: briggs 17hp intek overheadvalve on
hi there
pauly46 here
if engine seems to labour when trying to start as if too much compression ?
try adjusting to in and ex valve clearance to 0.003" inlet and 0.005" ex
inlet valve is the bottom valve, and has a alloy push rod. ex valve is top valve and has steel push rod ( as viewed from the front of the machine with rocker cover off ) )
note rotate engine with plug out to tdc compression stroke , then rotate it down the bore on power stroke by 1/4 inch ( 6.35 mm ) this is the point for setting in / ex valve clearances
manual says 1/4 pst tdc on compression stroke - this eliminates decompressor lift from the setting
cheers hope it hepls
Posted on May 02, 2011
heatman101
  • 43501 Answers
SOURCE: My John Deere 4010j traveling
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Posted on May 19, 2011
GodBlessU
  • 3513 Answers
Hi
Unhook the fuel pump feed to carb line and place it over a gas can with ignition disabled to see if it is pumping any fuel at all. If you are getting fuel past the filter and pump (should be low pressure) your next bet would be to check the carb itself. Many smaller motors that aren't run often can develop deposits or contaminants that clog small ports or jets in the carb and prevent fuel from making its way into the motor. If you have any available you may want to try spraying a little starting fluid into the carbs while cranking to see if it will help it turn over.
However if you are getting gas out of the bowl, then it can't be a plugged fuel filter. It could be bad needle-valve or blocked passage. Take the carb apart and soak it overnight in Lacquer thinner then blow it out with an air compressor. The float should be set slightly higher than level with the carburetor upside down.
Also check this helpful link to troubleshoot your issue:-
http://www.lawnmowerman.tv/Troubleshooting.asp
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jul 19, 2011
How do you adjust a clutch-brake on a John Deere LA105 mower?
Hello CherylPlazza,
Here's the Owner's Manual
John Deere la105 Manual
Read & heed (perhaps even make a copy)?).
Helpful...?
Carnac the Magnificent
Oct 17, 2017 | John Deere Garden
John deere la105 transmission belt
Greetings, I read your question and I think Reliable-Store can help you in this. Here's the site link.
Best Manuals
Mar 29, 2017 | John Deere Garden
John Deere LA105 lost power
Hi Hank:
Did you hit something with the mower, or did it happen gradually?
Probabaly a good idea to start with a basic service:
- Clean air filter
- Clean fuel filter
- Flush carbuerettor
- Fresh gas?
- Change spark plugs
- Change oil and filter
- Underside of mower deck clean and free of all built up grass?
Hope this helps.
May 09, 2015 | John Deere Garden
I need a wiring schematic for the LA105 John Deere lawn tractor
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt?search=model&model=la105
Jun 14, 2014 | John Deere Garden
John deere model LA105, deck engagement cable spring keeps breaking.
are you routing it the right way rubbing or kinked
Apr 03, 2012 | John Deere Garden
Garden Logo
43 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
