Question about Schwinn Cycling
Schwinn 5 speed rear hub with drum brake manual
1973 schwinn tandem deluxe twinn
  • 1138 Answers
SOURCE: REAR BRAKE
If I remember correctly there should be holes in the hub with set screws to tighten the hub to the axle. The ones I built had square headed bolts. The reason is that the hub can be moved from side to side to better adjust how the chain lines up for shifting. If there are no bolts or set screws but the holes are there you can take the hub to a fastener place to obtain some. Hope this helps.
Posted on May 09, 2009
  • 84 Answers
SOURCE: I have a Schwinn 7
You have conflicting info. If there are multiple gears then there is a derailer. You should take to a bike shop where they can look at it. It is probably a very small easy adjustment.
Posted on Jul 25, 2011
grumpytoolgu
  • 69 Answers
SOURCE: Schwinn Serial # HJ002218 - what would it be worth?
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=Schwinn+Lemon+Peeler&_sacat=See-All-Categories
The prices on ebay range from $1,000.00 up. Have a look.
Posted on Dec 15, 2011
Testimonial: "Thank you, Greg - my lemon peeler needs a lot of TLC (cleaning up, etc.) but since it is all original, I think it would be a real treasure for someone interested in bringing it back to life. Can you tell me what information the serial # offers? I think it is a 1973, but what do the other numbers mean? My father gave me this bike when I was approx. 10 years old (38 years ago), and I almost lost it to a yard sale my mother had back in the early 80's. Luckily I stopped her from selling it before it was too late! I've kept this bike with me throughout my life and would like it to go to a good home. Can you recommend the best place to post her for sale? I would prefer not to utilize E-Bay."
  • 20 Answers
SOURCE: removal of rear wheel with internal geared 3-speed and coaster brake hub
Find the joiner link on the chain, remove the retainer clip followed by the link. Remove the chain. Remove the bolt holding the brake arm to the frame. Loosen the axle bolts on the wheel enough to be able to slide the rear wheel out of its slots on the frame.
Posted on Feb 24, 2012
davidwbird
  • 14 Answers
SOURCE: where can I find an owner's manaul and parts list for a 1973 schwinn suburban
http://www.ebay.com/itm/1972-Schwinn-Owners-Manual-Continental-Suburban-Collegiate-Varsity-Sport-/160832409973
The moving parts on that vintage Schwinn are essentially the same for all of the listed bikes. I expect just about all are currently replaceable with new parts on an item by item basis if that is your need.
Posted on Aug 12, 2012
How do I correct the clanking noise in the rear of my Schwinn 24" Meridain Tricycle?
It could be that the chain needs tensioned, or if it is a coaster brake, the hub may need serviced. The noise could be coming from anywhere and your best bet is to have a qualified mechanic look at it.
Oct 31, 2014 | Schwinn S4025 Meridian 24" Single Speed...
2001 Cavalier passenger rear brake locks up at slow speeds, shakes at higher speeds, mechanics changed drums 3 times, keeps coming back
I think it is time to find an accredited brake specialist . At the best with a hub it may be bad wheel bearings but I consider it a problem with the mechanics and their lack of commitment to fixing your problem
Mar 25, 2014 | 2001 Chevrolet Cavalier
Removal of rear wheel with internal geared 3-speed and coaster brake hub
Feb 24, 2012 | Cycling
Dec 15, 2011 | Cycling
I have a Schwinn 7 speed deluxe cruiser. When I pedal, it feels like the chain is skipping a tooth on a sprocket. Is it worn, broken or an adjustment needed? There is no derailur on this old classic,...
Jul 25, 2011 | Schwinn Cycling
How do I get the rear drums off a 2000 Ford focus. I removed the spindle nut,
2000 Ford Focus Drum Removal ProcedureIf removing the drum to service the rear brakes: (note, do not remove hub retaining nut for this procedure)
1. Raise and support vehicle
2. Release the parking brake
3. Remove wheel and tire
4. Disconnect wheel speed sensor wiring harness from wheel knuckle and floor panel.
5. Remove 4 wheel spindle attaching bolts, then the wheel hub and drum assembly from vehicle.
6. Reverse procedure to install noting the following:
a. Torque wheel spindle retaining nut to 49 ft. lbs.
b. Torque wheel/tire assembly to 94 ft. lbs.
2000 Ford Focus Drum Replacement ProcedureIf replacing the drum and wheel bearing assembly:
4. Remove center dust cap.
5. Remove hub retaining nut.
6. Remove drum and hub assembly. Ensure wheel speed sensor ring is not damaged when removing drum/hub (if equipped).
7. Reverse procedure to install noting the following:
a. Inspect and clean wheel speed sensor ring if equipped.
b. When tightening hub retaining nut, rotate the hub assembly in counterclockwise direction.
c. Torque hub retaining nut to 173 ft. lbs.
d. Torque wheel/tire assembly to 94 ft. lbs.
e. Adjust parking brakes as necessary.
Jul 05, 2011 | 2000 Ford Focus
Where the hell can I get a FREE PDF download for my Ford fusion 2 for the removal and replacement of the rear wheel bearings as well as the torque settings for the final nut after replacement.All the so...
Rear Suspension - Rear Wheel Bearing Fusion 2002.75 (06/2002-)
-Removal and Installation
Special Tool(s)
Installer, Differential Bearing
205-062
Installer, Input Shaft Seal
307-210 (17-041)
General Equipment
Soft faced hammerWooden block
Removal
CAUTION: The brake drum and hub assembly removal in this procedure is for installing a new wheel bearing, not for access to brake system components.
-All vehicles
Remove the dust cap.
Remove the wheel and tire.
For additional information, refer to: Wheel and Tire (204-04 Wheels and Tires, Removal and Installation).
-Vehicles with rear drum brakes
Release the parking brake.
Remove the brake drum and hub assembly.
Remove and discard the wheel hub retaining nut.
-Vehicles with rear disc brakes
Remove the brake disc.
For additional information, refer to in this section.
Remove the wheel hub.
-All vehicles
Remove and discard the wheel speed sensor ring (brake disc shown).
Remove the circlip (brake disc shown).
Using the special tool, remove and discard the wheel bearing (brake disc shown).
-Installation
-All vehicles
CAUTION: Support the wheel hub assembly on the wheel mounting face and not on the wheel nut studs.
Using the special tool, install the new wheel bearing (brake disc shown).
Install the circlip (brake disc shown).
CAUTIONS:
Make sure the wheel speed sensor ring is not knocked, damaged and kept free from metal fragments.
Protect the face of the wheel speed sensor ring with a non-ferrous flat block to prevent damage.
Make sure the wheel hub or brake drum is adequately supported and do not allow it to rest on the wheel studs..
Make sure the wheel speed sensor ring is pressed on slowly and squarely until fully seated.
Do not exceed a maximum load of 10 kN.
Using the special tool, install a new wheel speed sensor ring (brake disc shown).
CAUTIONS:
Avoid impact on the wheel speed sensor ring.
Make sure the wheel speed sensor ring is clean.
Avoid any contact between the wheel speed sensor ring and a magnetic surface.
Rotate the wheel hub assembly 10 times counter-clockwise when tightening the wheel hub retaining nut to prevent damage to the wheel bearing.
NOTE: Install a new wheel hub retaining nut.
Install the brake drum and hub assembly.
Apply the parking brake.
CAUTIONS:
Install the wheel hub retaining nut.
Install the brake disc.
-All vehicles
Install the wheel and tire.
NOTE: If the dust cap is damaged a new dust cap must be installed.
Using a soft faced hammer and a wooden block, install the dust cap.
There is no real torque settings for the rear wheels, except to say, do not over tighten or you will stretch the lugs and the will loosen over time.
May 28, 2011 | Ford Fusion Cars & Trucks
How to replace rear wheel bearings
don't have topaz. maybe escort will help guide you.
Section 04-02: Suspension and Wheel Hubs, Rear 1996 Escort, Tracer Workshop Manual
REMOVAL AND INSTALLATION Wheel Bearing and Hub Assembly NOTE: Wheel bearings are not serviceable and should therefore be replaced as an assembly with the wheel hub (1104).
Removal
  1. Raise and support the vehicle.
  1. Remove the wheel and tire assembly.
  1. Remove the hub grease cap (1131) from the wheel hub.
  1. If equipped with disc brakes, remove the rear disc brake caliper (2552) and rear disc brake rotor (2C026). Refer to Section 06-04 for the removal procedure.
  1. If equipped with drum brakes, remove the two brake drum screws and the brake drum (1126).
  1. Unstake the rear axle wheel hub retainer (4B477) securing the wheel hub to the rear wheel spindle (4A013). Remove and discard the rear axle wheel hub retainer.
  2. Remove the wheel hub from the rear wheel spindle.
Feb 06, 2010 | 1990 Mercury Topaz
How do you remove the backing plate from an '05 Chev Venture rear hub so the hub can be replaced?
The 4 Bolts that Hold the HUB in Also Hold the Backing Plate
Hub Replacement - Rear (Front Wheel Drive/Drum)
Removal Procedure
  2. Remove the tire and wheel.
  3. Remove the brake drum.
    1. Remove and DISCARD the wheel bearing/hub bolts.
    2. Remove the wheel bearing/hub.
    3. Disconnect the wheel speed sensor electrical connector (2).Installation Procedure
    4. Connect the wheel speed sensor electrical connector (2).
      1. Install the wheel bearing/hub. Caution: These fasteners MUST be replaced with new fasteners anytime they become loose or are removed. Failure to replace these fasteners after they become loose or are removed may cause loss of vehicle control and personal injury. Notice: Refer to Fastener Notice in Service Precautions.
      2. Install the NEW wheel bearing/hub bolts.
      1. Install the brake drum.
      2. Install the tire and wheel.
      3. Lower the vehicle.
Nov 07, 2009 | 2005 Chevrolet Venture
Loose rear wheel, believe it is the bearing. How do I repair it?
drum brakes you remove rear wheel- speed sensor-grease cap-flange nut-outer bearing-brake drum-inner grease seal-inner bearing-drive the bearing races out of the drum hub.to install -install the inner and outer bearing races.apply grease to the bearings and hub cavity.then you install the inner bearing -inner grease seal-brake drum-outer bearing-flange nut torque it to 159 to 192 ft lbs. THE REAR DISC BRAKE WHEEL BEARINGS-you have to remove rear wheel -wheel speed sensor-brake caliper and rotor-rear axle hub bolts-tone the wheel with tool 09445-21000-carrier assembly-nut after unstaking it-press out the rear axle hub-remove the bearing inner race with tool 09445-21000-remove the bushings from the carrier with tools 09453-33000b and 09545-21100.to install -press in the bushings to the carrier with tools 09453-33000b and 09545-21100- press in the bearings to the hub with tool 09221-21000.tighten the flange nut to meet the concave portion of the spindle-press in the tone wheel with tool 09221-21000-torque the nut to 191 ft lbs -install the hub and bearing assembly to the backing plate and torque the bolts to 88 ft lbs-install the brake caliper and rotor.install the wheel speed sensor if equipped.install the rear wheel.TO BUY THE TOOLS TO DO THE JOB.LOOK UP KENT MOORE TOOLS ON INTERNET.
May 30, 2009 | 1999 Hyundai Sonata
Cycling Logo
66 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
