Question about Olivetti Lettera 25 Typewriter
Olivetti Lettera 22 - Ribbon Spool doesn't advance.
Ribbon spool does not advance when keys are struck. I have ensured that there is not a snag anywhere in the spools visible from the top. When the bottom panel is removed there is a long rod that runs horizontally across the typewriter, when this is manually moved it does connect to the spool and initiates rotation. When the keys are struck this long thin rod rotates slightly (although inconsistently) but not successively. So I reason that there is something wrong with advancement of this rod. Any ideas or schematics that would enable me to fix this problem are appreciated.
Everything else on this machine work perfectly and it is in mint condition.
Thanks
    Scholar:
  • 183 Answers
These are tricky to repair, I would suggest taking it to a repair shop (check the yellow pages) check repair directory on this site, sorry , no easy answer on this one
Posted on Jan 06, 2009
Ribbon will not advance
Sir/Madam, I'm very sorry; this"fixya.com" assumes I have the knowledge to offer advice on typewriters but I normally need advice myself. Regret I can't help, Sincerely, Edwin Thoma, USN-Ret.
Sep 05, 2014 | Underwood 1957 Leader Turquoise Portable...
Olivetti Underwood Studio 44 ribbon won't advance.
Remove the top cover, remove ribbon spools, press a key and grab it with your finger, note the mechanical motions toward the ribbon advancer movement, usually found near the center of the ribbon holder or could be on the outside edge also, there is a reverser mechanism also that should be fully to one side or the other, it switches the ribbon direction to avoid a 'dead end' while typing. By moving the key toward the platen and away it should drive the ribbon mount spool by a shifting drive lever of some kind. If you cannot resolve this issue, take it to a rare typewriter repair shop, it is too hard to explain in this format, and mechanical skills are involved, hope you have them, ;)
Sep 14, 2013 | Underwood Retro green Olivetti Studio 44...
Just bought a TE475. can't figure out how to replace the line compared to the traditional one-line configuration I am used to
Here is the info from the manual, the replacement line is put in near the center of the spool on the top of it, you simply feed it in. I have included a link to the manual so you can see the pictures. Look at page 10 for these instructions.
http://www.weedeater.com/ddoc/WEEO/WEEO2009_USen/WEEO2009_USen_TE475-952711797_545186833.pdf
LINE REPLACEMENT Pre--wound spools offer the most convenient method for replacing line and ensuring optimum performance. S Replacement spools are color--coded to ensure use of the correct spool with your unit. Be sure to use the same color spool as the existing spool. NOTE: Always clear dirt and debris from cutting head components when performing any type of maintenance. S Hold spool and unscrew cap by turning in the direction shown on top of the cap. S Remove line guide ring and spool. NOTE:When removing and/or installing spool, ensure dust cup remains installed over shaft. Use a pre--wound spool or refill spool with line. If using a pre--wound spool, remove tape strip from line and spool. REFILLING THE SPOOL WITH LINE WARNING: Use only 0.080" (2 mm) diameter round line. Other sizes and shapes of line will not advance properly and will result in improper cutting head function or can cause serious injury. Do not use other materials such as wire, string, rope, etc. Wire can break off during cutting and become a dangerous missile that can cause serious injury. 1. Cut a length of 25 feet of 0.080" (2 mm) diameter round WEED EATER brand line. Feed line in direction shown on spool. Spool 2. Insert one end of line into center cavity of empty spool. Ensure line will feed into spool in the direction shown on the spool (counterclockwise). 3. Continue feeding line into spool, leaving 4 -- 6 inches (10 -- 15 cm) unwound from center of spoo
Aug 25, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I don't know how to restring the weed eater
LINE REPLACEMENT Pre--wound spools offer the most convenient method for replacing line and ensuring optimum performance. S Replacement spools are color--coded to ensure use of the correct spool with your unit. Be sure to use the same color spool as the existing spool. NOTE: Always clear dirt and debris from cutting head components when performing any type of maintenance. S Hold spool and unscrew cap by turning in the direction shown on top of the cap. S Remove line guide ring and spool. NOTE:When removing and/or installing spool, ensure dust cup remains installed over shaft. Use a pre--wound spool or refill spool with line. If using a pre--wound spool, remove tape strip from line and spool. REFILLING THE SPOOL WITH LINE WARNING: Use only 0.080" (2 mm) diameter round line. Other sizes and shapes of line will not advance properly and will result in improper cutting head function or can cause serious injury. Do not use other materials such as wire, string, rope, etc. Wire can break off during cutting and become a dangerous missile that can cause serious injury. 1. Cut a length of 25 feet of 0.080" (2 mm) diameter round WEED EATER brand line. Feed line in direction shown on spool. Spool 2. Insert one end of line into center cavity of empty spool. Ensure line will feed into spool in the direction shown on the spool (counterclockwise). 3. Continue feeding line into spool, leaving 4 -- 6 inches (10 -- 15 cm) unwound from center of spool
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
RIBBON DOES NOT ROLL FLAT ONTO SPOOL
The first thing i would do is to install a new ribbon.
DickyO
Mar 28, 2010 | Nakajima Office Equipment & Supplies
How do I replace the ribbon on an Underwood typewriter?
Really? An Underwood typewriter?
First, do you have a replacement ribbon that is not dried out? Does the ribbon come on one spool or two?
If the typewriter already has a ribbon installed, it is a simple matter of noting the path the current ribbon follows, and which way the ribbon winds onto the spools. Then install the new ribbon following exactly the same threading path. If there is not already a ribbon installed, then it is a little more complicated, and it will depend on your spatial relationship visualization skills.
1. Type a few letters on the typewriter, and take note of which way the spools turn.
2. Mount the two new spools containing the new ribbon so that the full spool will supply (unwind), and the empty spool will take-up (wind) the ribbon.
3. Thread the ribbon through all of the guides in the threading path - there are probably about 6-8 guides that the ribbon has to go through. The most important guides are the ones that carry the ribbon in front of the typeface elements as they strike the paper. But equally important are the guides that monitor the tension of the ribbon - they will cause the spool advance mechanism to reverse the ribbon take-up direction when the ribbon reaches the end of travel.
Sep 22, 2009 | Office Equipment & Supplies
Old typewriter Brother DELUXE 800 : ribbon reference ?
This is what you are looking for:
Brother Typewriter Ribbon spool black and red SC-20BR-BRO Compatible
The typewriter ribbons for use in Brother manual typewriters are usually all the same. What matters is the size (diameter and hight) of the spools.They differed only in that they were available in different colours (usually black or black and red) and in different materials: some ribbons were made of nylon (cheaper) and other made of silk (more expensive and higher quality) .
Maybe some old and good stationer's (papeterie) still carries them or has some in stock.
Or else you may want to contact the customer support service of Brother, in France, for advice on where to find them in your Country.
Sep 07, 2009 | Brother Office Equipment & Supplies
Smith Corona Classic 12 ribbon won't stay in place
Okay...i had the same problem when I replaced the original ribbon that came with my Classic 12. I think it was the ribbon that came with the typewriter.
Anyway, on the ribbon carrier, there are two sets of metal prongs on top of one another. If you get the ribbon behind both of them, it will pop up and not go back down or won't come up at all.
You have to get the ribbon between the two sets of prongs. There's isn't much room and you have to kind of pull the bottom of the ribbon taught and slide it down from the top.
It isn't easy the first time, but after you get it, you won't forget.
As for your ribbon not feeding...take the spools out and make sure the pegs that go into the holes in the spools are rotating when you type. This is what moves the spools. Then make sure you're getting the pegs in the hols when you put the spools back in.
Also, make sure the ribbon isn't twisted anywhere and that it's threaded correctly. Both spools should look identical with the ribbon coming out of the top toward the carrier.
To ensure you have the correct ribbon, got to the Office Depot online store and do a search for Smith Corona Classic 12 and you will get a pretty generic, double-black ribbon that fits and works perfectly...and is so soaked in ink you can reuse each side three times. I don't recall the brand name, but the box is grey with red lettering.
Apr 16, 2009 | Smith Corona Office Equipment & Supplies
Olivetti Lettera 25 Typewriter Logo
633 people viewed this question
Top Olivetti Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Coss
Are you an Olivetti Office Equipment and Supply Expert? Answer questions, earn points and help others
