Question about Canon PowerShot A470 Digital Camera
The installation disk is not working
When I insert the disk a screen comes up that says The screen resolution to execute digital camera disk is not sufficient...what do i do?
  • David Donnelly
    David Donnelly May 11, 2010
    What type of Operating System are you running? I may be able to walk you through this.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
You don't need to install anything.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Sep 20, 2012
MrsJGreen
  • 130 Answers
SOURCE: Screen resolution to execute digital camera solution disk is not sufficient
Go to start/control panel/display/settings/adjust your screen resolution to high and then install.
Once installed, change your screen resolution back as low or high as you wish.
Posted on May 30, 2008
  • 333 Answers
SOURCE: I just bought a new
Check that the screen resolution on your pc is high .
You can find this in Control panel, display, settings. What do you see there?
Posted on Jun 04, 2008
old marine
  • 2097 Answers
SOURCE: Inserted the disk for my
You have to set the resolution on your computer's monitor to the minimum required to run the software. To do this, go to your desktop (no programs showing) and right click in an empty area on the desktop. Go down to "Properties" on the menu that appears and click on it. Look along the top of the window that opens for a tab named "Settings" and click on it. You should see an option (usually on the left) to change your screen resolution. Change your resolution to the minimum required for the program. Depending on your computer, you may be asked to confirm the new settings, or you may have to restart your computer (the computer will tell you). Once you have the new screen resolution set, things will appear to be smaller on the monitor, but you will be able to see more of whatever you are looking at.
Posted on Oct 06, 2008
jyackle5
  • 8197 Answers
SOURCE: Problem installing Cannon SD 1100 software on my Personal Computr
Go here to try to download the software.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=323&modelid=16347
Good luck and please rate
Posted on Apr 05, 2009
SOURCE: I'm not able to download the solutions disk (version 31.1)
Sorry this is a late response - I just had the issue with the T1i solutions disc ver. 20.0. on Windows XP
Right click your desktop and select Properties
Go to the Settings Tab
Under "Display" you should see it is selected to your default monitor or Plug and Play monitor.
Under that, you will see Screen Resolution on the left hand side. If the slide bar will not allow you to change this any higher, then at the bottom of the window you will see an option for Advanced
Write down your current screen resolution so you can change it back after installation is complete.
Click on Advanced - You will see tabs at the top - click on the tab marked "Monitor"
This will show you Monitor Type - under thatyou will see Screen Refresh Rate (ex. 60 hertz)
Under that is a check box marked "Hide modes that this monitor cannot display"
Uncheck this box and click "OK"
This will take you back to the screen resolution and you can change it from there. Change it to 1024x780 - this is the minimum display resolution for the installation disk.
When you have installed the software, you will want to change it back to your normal resolution
Note - if you want to use the EOS utility to download and edit your pictures, you will need to change it back to 1024x780. I just use the Windows Camera/Scanner wizard to download, and then use Adobe to edit the photos.
Hope this helps!
Posted on Jun 28, 2009
Intalling camera software.
Greetings Shayy,
Generally screen resolution refers to your computers resolution which is controlled via the control panel of your computer. I would try fiddling with other screen resolutions to see if this helps. This will cause items on your computer to either be larger or smaller than you are used to, but you might find you like it better.
You would go to control panel>display>settings, to adjust this.
I hope this helps.
Dorothy
Go Ahead. Use Us.
Jun 04, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Apr 20, 2008 | Canon PowerShot S5 IS Digital Camera
Can't install the solution disk
Click on "Start" lower left corner of your screen, and select "Control Panel". Then double click the "Display" icon. Then click on the "Settings" tab.
Slide the screen resolution slider bar 1 click to the right to select 1024 x 768 resolution. Then click OK. You should be able to install it now.
Apr 12, 2008 | Canon PowerShot A450 Digital Camera
Canon powershot sd850 is digital elph
Hi
No, it means the screen resolution for your computer. These days most computers should have their resolution to 1024x768. If you don't know how to change it ask somebody who knows a little about computers to help, its not a problem with your camera.
Thomas
Mar 01, 2008 | Canon PowerShot SD850 IS Digital Camera
Change your compuetr's display resolution to a better performance. Click with the right mouse button on your computer screen. - The Display properties window will open - Click with the left button on the Setting tab. - Change screen resultion as required - Press "apply" Check whether the new setting solve your problem. Good luck!
Sep 13, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot A470 Digital Camera Logo
79 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
