Question about Kenwood KDC-X811
No power, does not open
I have owned it since new and it's been working great until it just stopped working. I checked all the wiring and all is good, fuse is good. It started out that the face would sorta get slower on opening or stop 1\2 way and try to restart and now it just doesn't open even if you try to manually open it. I get not sound, no movement anymore. Anybody have an idea what it may be? I rather keep this head unit instead of buying a new one if this would be an easy fix.
The wires from the face to the deck 10.00$ part
Posted on Sep 07, 2007
2007 rendezvous window won't work unless doors are open.
Check the ground wires to the door. It appears to be using the courtesy lights wiring to back feed to ground completing the circuit.
Mar 09, 2015 | 2007 Buick Rendezvous CXL SUV
Just bought magnum 3016 coil cable lock. How do I open it and set own combination?
Thanks that worked for me to. To change the code open.....enter current code.......turn the metal wheel (saying set ->) clockwise until it stops.........set the new code........... turn the metal wheel anti clockwise until it stops.......the new code is set.
Apr 14, 2011 | Magnum Cycling
I own a 97 caviler. its been a great car so far untill now. For the past week my low collent light kept comeing on and off threw out the day and when that happens my check gagues light comes on and my tack...
If you have located what sounds like the problem, only you can determine how bad it is-I have opened harnesses that had damage done to them, and spliced, one-by-one new wiring to repair damaged sections, you just have to take your time. If you like the car and it's in good condition the cost of doing this is more a matter of investing time than money since it is a matter of providing labor to fix it. You sound like you are pretty handy, most people probably don't know enough about their cars to trace and find a wiring problem, so that's half the battle. The other half is to make up your mind to fix it, be it by repairing the damaged area of going a step further and replacing a harness section.
Mar 03, 2011 | 1997 Chevrolet Cavalier
Ok here is the problem. The garage door opener is a craftsman and is around 10 years old. It has worked great until today. If seems like the down stop has broken as the door is being pushed way to far...
You need to remove the cover from the motor unit and check the limit switch assembly. You could have a broken or loose wire. Watch the operation and you should be able to tell what is wrong.
Feb 08, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Liftmaster Model 2500 opener. It is about seven years old, and worked great until recently. It has stopped working, including no lights at the Multi-function door control. If I unplug the...
THIS IS PROBABLY CAUSED BY A SHORTED WIRE.
OR A BAD WALL CONTROL.
DISCONNECT WALL CONTROL & TEST.
IF STILL NO RESULT DISCONNECT WALL CONTROL WIRES AT THE POWERHEAD & TEST AGAIN.
REPLACE WIRE OR WALL CONTROL.
HOPE THIS HELPS
Nov 15, 2010 | liftmaster Chamberlain Garage Door Opener...
I have an old Craftsman type I corded electric drill that I love. It's from the early 1970's (probably 1973). Until two weeks ago it worked great but stopped when it fell from a workbench. Is it worth...
First, be safe if you are planning on opening the drill. Make sure the cord is unplugged. Check the motor to see if any of the wires look severed or a brush is loose. Most newer drills are more powerful, even for the inexpensive ones, than the older drills. They also tend to use much less power. So the recommendation is, if it is not for sentimental purposes, a new drill might be in order.
Sep 27, 2010 | Garden
Im needing to know about how to fix my 1995 toyota camry windows just stopped working how to fix it either with a relay or a fuse and what relay or fuse do i need,
I had no power to my driver's door pwr window switches. I went on line and somebody said for me to wiggle the wiring harness to the door (after opening it) and sure enough it was a bad wire. I guess after 15 years of opening and closing the door, the bendig motion was breaking wires. My bother-in-law found the bad wire and snaked a new one in, and it has worked great ever since. Good luck
Aug 27, 2010 | 1995 Toyota Camry
Electric windows will not work
sounds like the wiring between the door and the body or the {door-jamb} a rubber boot help protect and hide all the wiring this is common as common can be ....1st check to ensure all your fuses are properly seated into the fuse box sometimes they become loose then test them with a test light if all is good then check for power at the switch if no power is present then proceed to the rubber boot it should simply be squeezed and will pull out at each end check for power between the two points you will need to penetrate the wire until you find a good power follow it up until no power is found on the same wire this will be your break in the wire ..repair with a wire connector or a new length of wire ..
Sep 09, 2009 | 2000 Jeep Grand Cherokee
2004 Chevy silverado 2500HD the left stop light not working
use a testlight turn on the LS light ground the test light touch the pin inside the lamp socket if it lights look for a bad ground if it does not check your fuses or, run a new power wire under your truck secured with zip ties from the switch
Apr 20, 2009 | 2004 Chevrolet Silverado 2500 Crew Cab
About 6 months ago i had installed the mtx thunder 6500d amp to run my 2 rockford fosgate power T1 12inch subs and every thing was great untill recently it stop puting out sound it still powers up and...
good morning and welcome to fixya. not a bad setup you have here at all, you ned to start by checking the speaker wires inside the box to the connector inside and then the wires from connector to amp on outside. if everything looks fine there, then you need to check the amp for power out of the rca plugs to make sure the channel is not dead. if you are looking for a new amp you can try several different ones from fosgates new line up to soundstream's. im running 4 polk momo 12's on the tarantula amp and love it. they are great amps. hifonics also has a new line up pretty cool stuff, heard really good things about there stuff to. good luck and let me know so i can help you out.
Mar 08, 2009 | MTX Thunder 6500D Car Audio Amplifier
Kenwood KDC-X811 Logo
87 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
