Hotpoint wdl540 wash light flashing wont start
Fills with water, then just empties, then orange wash light just flashes. A spin works ok so dont think it is motor !
  • 10 Answers
SOURCE: wf340 hotpoint washer
it will be to do with the pressure switch it may be faulty, but more often than not there is a blockage in the pressure chamber which is located at the bottom of the outer drum, check the chamber and the tube that goes up to the pressure switch to see if they are blocked if they are clear of obstruction then test the pressure switch,to do this unclip the pressure switch from the side of the machine but dont take the wires off once off pull the tube off that goes down to the pressure chamber once off blow in to the nossle on the pressure switch, you should hear it click and then when you release it should click again, if it doet click twice then that is your problem, hope that helps.
Posted on Feb 22, 2008
SOURCE: indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Posted on Feb 27, 2008
SOURCE: ariston margherita washing machine
I have an old Margherita washing machine year 2000, my problem I don't have user's manual. Can you please provide me or teach me how to operate the machine?
Thanks & regards
ray salac
Posted on Sep 03, 2008
SOURCE: the water wont drain or spin wf210 hotpoint
Hi I think your problem is that the filter is blocked, filter is located between drum and pump at the rear, clean that out and that should solve the problem.
Posted on Mar 28, 2009
plumber_man
SOURCE: Hotpoint WF340 wont drain
I have the HOTPOINT WF540 with the same problem ....So remove the front panel at the front of the machine and you will see the filter plug unscrew anti clockwise, you may find it difficult to unscrew as the filter may be blocked solid with coins ans long objects but once you have started it off wiggle it back and forth with some force till the objects dislodge you may be scared of breacking it but the worst you can do is snap of the plunger which is attached to the filter plug, behind the filter plug its self which will do no real harm and you can put it back in unattached to the filter plug with no worries when your done
you can also drain of the water out of the drum drum from this point but you will need a very slim try to fit under the front of the washer below the filter plug DO NOT totaly remove the plug if the is washing machine is full of water, just release the plug till water slowly trickles out and drain it a bit at a time or you will flood your floor
Posted on Jun 01, 2009
How do I find what the problem is with my hotpoint aquarius wdl540
DOES IT AGITATE? CHECK THE DOOR SWITCH, THE MOTOR COUPLER, THE BELT, THE CLUTCH WHICH EVER IS APPLICABLE? DIRECT OR BELT DRIVEN?
Aug 31, 2014 | Hotpoint Washing Machines
Hotpoint Aquarius wdl540 wont pump out water
!. Check for water drips/leaks onto the wiring after removing the rear&or the side covers.This may sometimes not be visible to the naked eye -- a torch.
2.Check for loose connections to the pump.If all o k then remove the & test by connecting to the Mains.If it runs switch it off -- do not run it dry for more than a few seconds.If o k then it can only be the main board or timer.
Jan 26, 2014 | Washing Machines
Machine does not seem to be filling properly, then does nothing else.
Sounds like you're fill valves are junk which sadly happens allot. This video is very generic but should give you an idea
Jul 06, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint WML540 gets to spin then stops wont empty and all lights start flashing
hi sharon, i had simular problem, if your waste outlet from your machine to kitchen sink is pushed on to sink waste sometimes held with jubilee clip, disconnect it and check weather its clear cos it can get build up of ****** and stop water from draining, hope this helps.
Jul 08, 2012 | Hotpoint Washing Machines
My Hotpoint Aquarius WF440 fills up fine but will not move on to rinse and spin. Engineer been out and says its the heating element. He has asked me to wash on no heat until part arrives. Since then every...
I am fairly confident that the problem is entirely due to the fact that the heater is not working.
You are going to have to wait until the new heater is fitted beore being able to tell if there is another fault.
Hope this helps.
Dec 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WDL540 Washer/Dryer The fabric conditioner remains in the drawer after the wash cycle. The machine was installed on Monday, the first wash on cycle 3 seemd to go ok. The next two washes appear...
Hotpoint WDL540 This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 08, 2008 | Washing Machines
Dishwasher error codes please help
I too had this problen today. Printed off a manual from the Hotpoint website. Very helpful troubleshoot section. Anyway, flashing eco and fast lights and beeping sound indicates 'water feed pipe blocked' You need to check the water inlet connections on your tap.However, when we pulled it out we noticed the blue water inlet pipe was slightly kinked. Straightened this out and hey presto! It works fine again. How this happens when its worked ok for 18 months will never know but still. Try it! hope this was helpful...shewoo
Apr 26, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
