Question about Micrografx Graphics Suite 2 Upgrade for PC, Unix, Mac, Linux
Micrografx Designer for 64 bit - Micrografx Graphics Suite 2 Upgrade for PC, Unix, Mac, Linux
4 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: I have been using Micrografx Designer 3.1 in
The present Graphics DLLs are compatible with Designer 3.1 with
OLE (dated May 28, 1992). If you are running an older version of
Designer on the OWS and the drawing uses Designer fonts, displaying
the drawing would give a protect violation from DCP by
MGXLIB.DLL because the MGXFNT.DLL are not compatible.
You can replace the older version of the MGXFNT.DLL with a new
one. To do this, copy MGXFNT.JCI from the C:\FMS\BIN
directory to designer libraries directory (MGXLIBS) and change the
file extension to DLL (i.e., MGXFNT.DLL). By default, the MGXLIBS
directory is located under C:\WINDOWS; however, you should copy
the file in the same directory that is pointed to by the Libraries
parameter in the Micrografx section of the WIN.INI
(e.g., Libraries=C:\WINDOWS\MGXLIBS
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 25, 2011
muntejaya
  • 10421 Answers
SOURCE: how i can import picks.. when i try,i got only
Please re install the software then.
Regards, jay
Posted on Feb 26, 2011
  • 12 Answers
SOURCE: ou je peut me procurer
Essayez e-bay. On ne peut pas le trouver chez amazon.
Posted on Aug 03, 2011
Need micrografx Graphic Suite upgrade for Windows 7
Micrografx was sold to Corel in 2009, who then released the program as Corel Designer 9. You can upgrade to X5, the latest version, here.
Oct 23, 2012 | Micrografx Abc Graphics Suite
I have been using Micrografx Designer 3.1 in Windows XP for several years now. Recently, however, I have discovered that I cannot add text to a drawing. When I attempt to do so, I get the following error...
I had the identical problem on a netbook whose OS was WinXP Lite. The solution that worked for me was to reinstall the OS, this time using the full WinXP. Thereafter no problem.
Micrografx Designer 3.1 remains an excellent drawing program that was designed for Win 3.1 but works fine under Win XP, but not Win 7.
Feb 23, 2011 | Micrografx Designer Power Pack 3.1 Full...
Unable to use Micrografx Picture Publisher 10.0 with Win 7
Make sure that Micrografx Picture Publisher 10 pro installs into the X66 Program files folder.By default it will always install into the 64 bit program file if you have a 64bit installed.
If you have the 32 bit Windows 7 installed then right click with your mouse on the program before opening it up and select compatibility mode.Select XP SP3 compatibility mode.This works fine on my Windows 7 32bit. Use the first paragraph method if you have the 64bit Windows 7.
Regards Brian
Feb 14, 2011 | Micrografx Picture Publisher 10
I really love this program. I have recently upgraded my computer to Window 7 64 bit and this program runs 16 bit is there any way I can make windows 64 bit compatible with this program.
There is a way of having micrografx draw install and run properly on windows 7 64-bit and also 32bit
The discovery is that most of these programs are not really 16 bit
If you want check out the website at
http://micrografxdraw64bit.site40.net/
If you want more evidence of this let me know
Feb 03, 2011 | Micrografx Small Business Graphics and...
I am getting an error stating "Designer has encountered a disk I/O error trying to access the file", while trying to open a dsf file. I am using micrografx for more than 2 years now and lately i...
Close Designer 9.
Open the folder containing the 'DSF' file.
Try to copy the file into a different folder, or onto a USB memory-stick.
Do you still get the same error-message?
If so, then the problem is that your disk-drive has a problem;
your problem is _not_ a problem with the Designer 9 software.
Your disk-drive could be "dying". Backup all your important files.
Consider replacing the disk-drive, before it COMPLETELY fails.
Jan 27, 2011 | Micrografx Designer 9 Full Version for PC
Can you convert micrografix draw files to another file format
Each Micrografx Designer 3.1 *.drw file should hold one page of drawings, and that one page should be at page 1 in the Micrgrafx layout.
Corel Designer Technical Suite X5 has a free 30-day trial period. This program will import a Micrografx Designer *.drw file and let you SAVE AS or EXPORT AS an *.svg file.
Many current drawing programs, e.g., Visio, can import this *.svg file and let you save as a *.vsd file.
But if your *.drw file contained many pages of drawings, your converted file will have many pages of drawings but often in a single large page that you cannot edit. So safer to start out with *.drw files that each contain one page, and that one page should be drawn at page 1 within Micrografx Designer.
I have used the above method to convert very old Micrografx Designer 3.1 *.drw files to Visio *.vsd files. One problem was the Greek letters that were italics in the *.drw file are not italics in the *.vsd file.
Dec 15, 2010 | Micrografx Windows Draw Graphics & Print...
Micrografx Picture Publisher 8 not working with my Vista
I solved it!
The software installs OK.
After installation, reboot.
When you need to open the program, right-click on the Micrografx icon and select Run as Administrator. A yellow window pops up saying "An unidentified program want access to your computer," with pp80.exe as "Unidentified program" - that is actually Micrografx Pictures. Click "Allow." The program runs normally. The only caviat is that you will have to perform this routine every time you have to run Micrografx Pictures. But again, it takes 5 seconds to do it, and I love the program, having used it for over 10 years. Photoshop is far more advanced but it takes time to master it, and I do with Micrografx the same quality work as many with Photoshop.
Of course, Janet, you and I have to come to grips with the fact that Micrografx is pretty much dead, and Photoshop is alive and blooming. Maybe this Vista incident is a sign for us to learn Photoshop?
Apr 18, 2009 | Micrografx Webtricity 2.0 Full Version for...
Micrografx Graphics Suite 2 Upgrade for PC, Unix, Mac, Linux  Logo
197 people viewed this question
Top Micrografx Computers & Internet Experts
Tom Chichester
Free Robux
Free Robux
Are you a Micrografx Computer and Internet Expert? Answer questions, earn points and help others
