Question about Powermate Portable Generator: 3250-Watt Manual Start PM0123250
Powermate generator 3250 runs for hours then chokes out runs rough
I changed oil still does it
    Prodigy:
    An expert who has answered 500 questions.
  • Powermate Expert
  • 573 Answers
If it runs for hours under the same a mount of load then, chokes down, make sure fuel lines are fully clear, it may operate with a full tank of gas then when the weight of the fuel in the tank gets less has a problem. When it chokes out fill the gas back up and see if it works again. Also make sure the choke butterfly is not closing again whilst hot. I don't know how many hours are on it, but a decarb may be in order, especially if it runs for hours no issues
Posted on Nov 16, 2013
Low oil sensor
I would let it cool completely and see if it starts again. There are no specific timers that say after detecting a low oil shutdown don't start for X amount of time. It is more than likely a choke setting as it is hot, and you may now have flooded it.
May 11, 2013 | Powermate Portable Generator: 3250-Watt...
I have a 3250 watt Kingcraft generator that won't
Always troubleshoot with new sparkplug. Remove the oil sending unit connection from the coil. The coil should work without any wires connected. Usually the only connections are oil sending unit that will short to ground when low oil condition and other wire must be kill wire to on/off switch. Use carb cleaner spray directly into the carb with air filter removed and choke off as fuel supply. Just a short spray and another short spray after a couple of pulls. If engine wants to start you will need to keep spraying cleaner for engine to continue to run. If engine wants to run, replace fuel with couple gallons of premium fuel to get it going. Hotter fuel will help if the compression is low. Good luck
Aug 24, 2011 | Generac Power Systems Generac 0057890 3250...
I have a coleman powermate premium plus 6250 generator,put in new plug ,new filter ,changed oil,cleaned the carb,put in new gas. runs ok at half choke but when go full choke it starts backfiring and runs...
if you are running the engine at full CHOKE, then it is flooding the engine, but if you meant off full choke, then the carb is still stopped up. Try soaking in carb cleaner overnight after removing jet & all rubber goods. HOPE THIS HELPS.
Dec 17, 2010 | Coleman Powermate Premium Plus 6250W...
Engine runs rough, can't get it out of choke without it dying
partially blocked main jet. remove the jet bolt and clean out the little hole at the top of the threads.
Aug 10, 2010 | Coleman Powermate Powermate 5000W...
How often should I change oil in my model 6250 powermate. Thanks
For some reason people think that the oil goes bad in 2 weeks because it is a small engine, but if you compare 3,000 miles on your car to hours, you would never change the oil in the generator. I don't think I have changed my lawn tractor oil in 15 years, and it is still clear, never broke down, because in 15 years, I've probably run it, 150 hours? It's about due. I hope this helps.
Apr 29, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman 6250 generator runs rough
Fresh fuel? Does carburetor have adjustable jets? Turn the high speed jet (at bottom of float bowl) about 1/4 to1/2 CCW (looking at bottom of bowl). If no improvement, carburetor should be torn apart and cleaned. This also applies if there are no adjustable jets. Is there a fuel filter anywhere?
Jul 14, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate 5500 runs rough
vent in gas cap.
fuel filter.
dirt or gum in the carb.???
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Powermate Portable Generator: 3250-Watt Manual Start PM0123250 Logo
194 people viewed this question
Top Powermate Electrical Supplies Experts
Steve
Gene Haynes
Are you a Powermate Electrical Supply Expert? Answer questions, earn points and help others
