Question about ACCPAC Simply Accounting 2004 PRO (2120148) for PC
Code:1.425 "Description: Error occurred when activating ACCPAC Data Source. " how to solve this error, and
  • bayar bayar
    bayar bayar Jan 16, 2009
    thank you basoulus!  i need an architecture of accpac's modules cause i am programmer so this is different to understand Account system for me! but now i am learning a book of account system :-)
    help me all sides
This error occurs when the user doesn't have XML Core Services 4.0 SP2 intstalled on the local workstation. To download the service pack either go to Microsoft's website or go to google.com search engine and enter "Download XML Core Services 4.0 SP2." To intall the service pack, have an administrator login and run the downloaded file.
Posted on Jan 15, 2009
2 Suggested Answers
SOURCE: SAGE ACCPAC ERP Datasource activating problem in C#.NET
Add reference (ACCPAC.Advantage & ACCPAC.Advantage.Types);
using ACCPAC.Advantage;
private ACCPAC.Advantage.Session session;
private DBLink mDBLinkCmpRW;
session = new ACCPAC.Advantage.Session();
session.Init("", "XX", "XX1000", "55A");
session.Open("ADMIN", "ADMIN", "SAMINC", DateTime.Today, 0);
mDBLinkCmpRW = session.OpenDBLink(ACCPAC.Advantage.DBLinkType.Company, ACCPAC.Advantage.DBLinkFlags.ReadWrite);
This is how you can connect to DATABASE OF ACCPAC (55a)
Sheryar Nizar
http://www.sheryar.net
Posted on Oct 13, 2008
What is Error Code:59.A0 for Hp laserjet 400 M401d?
A main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation errorA main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error HP LaserJet Error Codes 50 59 Looks like a motor error check the fuser unit and drum are seated properly.
Mar 09, 2015 | HP Office Equipment & Supplies
5120 code error
Any of these error codes (51.20 51.21 51.22 51.23) points to a failure with one of the laser scanner assemblies on the HP Color LaserJet 4610 an 4650 series. To solve these error codes, replace the corresponding laser scanner. Sometimes when the laser scanner fails you will also hear loud noises (often higher-pitched noises like screeching sounds); the noises can be another sign that the laser scanner needs replacing.
51.XY
PRINTER ERROR
For help press
alternates with
51.XY
PRINTER ERROR
A printer error has occurred.
X Description
1 beam detect error
2 laser error
Y Description
0 no color / black
1 Press to continue.
2 Turn the printer off and then on.
3 Reseat the connectors between the
laser/scanner and DC controller PCA
(J1009 - J1012).
4 Replace the defective laser/scanner
assembly. Calibrate the printer after
replacing the laser/scanner.
Mar 17, 2014 | HP LaserJet 4650n Printer
Microboard error code 306
The 306 Error Code is generated when any corresponding process or operation could not be completed successfully by the application.
error 306 may prevent the user from performing the required action or may the application will close unconditionally.
Technical (Deep) Description of Error Code 306:
This is a full Description of ERROR 306:
ERROR 306: MCIERR_DEVICE_NOT_INSTALLED.This error is due to .The default facility code
ERROR 306: EVENT_APPMGMT_UPGRADE_COMPLETE.This error is due to Application %1 from policy %2 successfully upgraded application %3 from policy %4..The default facility code
ERROR 306: SQL_306_severity_16.This error is due to The text ntext and image data types cannot be compared or sorted except when using IS NULL or LIKE operator..The default facility code
ERROR 306: ERROR_SECURITY_STREAM_IS_INCONSISTENT.This error is due to The security stream for the given volume is in an inconsistent state. Please run CHKDSK on the volume..The default facility code
ERROR 306: CO_E_LOOKUPACCNAMEFAILED.This error is due to The system function LookupAccountName failed .The source of the error code is an RPC subsystem.
ERROR 306: STATUS_LOGON_SERVER_CONFLICT.This error is due to The Netlogon service cannot start because another Netlogon service running in the domain conflicts with the specified role. .The default facility code
Fixing Error 306 manually is a difficult process and it is not recommend unless you are an expert in this field.
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
hope it helps
Jul 13, 2012 | MicroBoards CFD-USB-15 1 Read,15-Port USB...
0xc004e003
An error has occurred
Code:
0xC004E003
Description:
The Software Licensing Service reported that the license evaluation failed
you can check from this link Microsoft Support Link1 and Link2
Sep 22, 2011 | Computers & Internet
Please tell me how to solve this issue:-- I am getting the error while trying to sync the data using Intuit sync Manager. The error message is:-- "An error occured while applying downloaded data...
Here, let me google that for you: https://community.intuit.com/articles/1265964-point-of-sale-error-an-internal-quickbooks-error-occurred-when-adding-customers-to-qb
Nov 02, 2017 | Intuit QuickBooks Pro 2010 Full Version...
Can not open sage accpac
That error means this entry:
HKEY_LOCAL_MACHINE\SOFTWARE\ACCPAC International, Inc.\ACCPAC\Configuration\SharedData
is not pointing to the folder that contains the *.LIC files. Or, you don't have full permissions to that folder.
Oct 13, 2009 | ACCPAC Fax/Voice/Mobileserve for PC
Accpac day end error
Okay what you need to do Is get the Hotfix for this software from the manufacturer of the software and they should send it to you. (You may want to check to see if you have it already). Again the hotfix is what you need in order to solve the problem.
RCF
Jun 18, 2008 | ACCPAC Simply Accounting 2004 PRO...
Error code 22
ERR 22: CF DRIVER
DESCRIPTION: This error occurs when image data cannot be written to the CF card. This error can occur when the CF card is not fully seated in the camera or if the D30 does not detect a card-ready signal within a specified time limit or when the CF card is not usable because it has been corrupted or physically damaged. It can also occur when the camera's battery level is insufficient to completely write the file to the CF card. REMEDIAL MEASURE: Use the DC Coupler or recharge the battery first. If the error continues to occur with sufficient power available to the camera, check that the CF card is properly inserted. If that's not the problem, then try replacing the CF card. If that does not solve the problem, have the EOS D30 and one of the CF cards that is causing the problem examined by a qualified service technician.
Got this from here: Digital Outback Photo
Feb 09, 2008 | Canon EOS 30D Digital Camera with 18-55mm...
ACCPAC Simply Accounting 2004 PRO (2120148) for PC Logo
300 people viewed this question
Top ACCPAC Computers & Internet Experts
Rajendra Singh
Rajendra Singh
BJ Russell
Are you an ACCPAC Computer and Internet Expert? Answer questions, earn points and help others
