My monitor has a problem. I tired to restart but the screen looks like this every time please help me!
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 32 Answers
Ur windows got corrupt and not working properly make ur system new window
Posted on Oct 27, 2012
  • 4 Answers
You have broken the lcd the best thing you can do is buy a new one as its not worth the repair bill as the same thin g happen to me
Change input timing for monitor when i can't do anything
Hi Austin
it sounds as though you have a problem with your graphics card drivers and your tv will not accept the lower resolution. Do you have another screen that you can connect to prove/disprove my theory? If your tv will not accept the lower resolution input then you need another screen to enable you to sort it out. Hope this is helpful.
Feb 19, 2013 | Computers & Internet
Monitor will not turn on, just blink...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 17, 2010 | Gateway FPD1975W 19" LCD Monitor
My monitor ( with less that 6 months use) has been going off while someone is using it--- says out of signal and i have to restart the comouter... and this is not stopping even with a restart
julezj, You will need to connect your monitor to a KNOWN GOOD pc that DOES NOT have the screen saver set to do a time out when the keyboard is inactive. Whenever you state a problem with a monitor on fixya, please mention the monitor technology you are dealing with. CRT (TUBE) or LCD flat screen!! IT HELPS IF WE KNOW TOO!!! Did it really display a screen message that read "out of signal" or did it read "OUT of RANGE SIGNAL"??? Is this monitor used to display HIGH resolution gaming and other high refresh rate imaging? Will this happen if you only have the WIN-desktop showing on the screen? Get back to me with more CLUES as to what happens on the screen. 12fixlouie Bye for now.
Nov 25, 2009 | Gateway Computers & Internet
Acer AL1716 A Monitor does not start
The problem on your monitor is a bad power supply. Because of heat buildup in LCD monitors parts called capacitors overheat and blow out. You can go to our web site at:
www.ccl-la.com/badcaps.htm and see what to look for. If you open your monitor and see blown capacitors that look like the pictures on our site then replace the bad ones and you should be back going. Email me if you have additional questions or if you need to get the capacitors, we carry them in stock.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Aug 27, 2009 | Computers & Internet
Monitor screen went blank after changing resolution
Try unplugging the monitor and then restart, and then go back to default settings.
Jan 30, 2009 | Samsung 793S 17" CRT Monitor
Monitor goes blank , power light goes off.
Click start, then then control panel and click on the power management icon. When you see the screen, look at the power management "scheme" and pick the appropriate setting. I assume that what you are experiencing is what's known as "Power management" . In order to achieve an "Energy Star" rating, the computer must shut off various components to conserve power. If you don't want to have your monitor shut down, select never from the options in the Power Management screen. Thanks for using Fixya.com
Jan 27, 2009 | Polyview V17E 17" LCD Flat Panel Monitor
A pink vertical line appears suddenly on the screen
Sounds like a hardware problem. You should probably return it as soon as possible.
Dec 19, 2008 | Sony VAIO® VGN-AR370N12 PC Notebook
AL2216W LCD monitor "Power status Green blinking" & No display.
LOOKS LIKE A BURN SOLDER !! , open the monitor , check the PC BOARD around the transformer area , look for burn spot or cold solder , RE solder it , try again , hope this helps please rate solution and thanks AJ
May 06, 2008 | Acer AL2216W LCD Monitor
Screen goes black and have to restart
looks like you have a DRY SOLDER or COLD solder , if your handy with tools , you have to open monitor and check the PC BOARD, specially where some transformer is located look around that area for some burnt spot , re solder it , and try it again , should be working properly , hope this helps AJ
May 02, 2008 | Samsung SyncMaster 940BE 19" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
