Question about Samsung Galaxy Note - 16gb - Black unlocked Smartphone
Screen flicker and network loss
The battery can start out at 50% when this happens. Sometimes the screen starts to flicker, shortly followed by complete network loss. Then network comes back and then more flickering and so on. This repeats around three time and then the phone dies from low battery. If I re-start the phone it will say it is low on battery and die again. But as soon as I start charging it, it starts charging from 50%. This is REALLY annoying.
Bajanguru
  • 7752 Answers
SOURCE: screen isnt working
luckychuckie - have the flexcble and lcd replaced...
phorxygirl - you need to have the firmware reflash on the phone, take it to a mobile service center and have it do there for a small fee
Posted on Jan 23, 2008
  • 38 Answers
SOURCE: My phone's battery died completly
yes ur battery must be dead
Posted on May 28, 2008
  • 20 Answers
SOURCE: Line across Screen and will not boot up.
take it apart and unplug the screen and plug it back in then restet all settings when the phone is apart try and clean it !BE VERY CAREFULL THAT YOU DONT BREAK ANYTHING ELSE ! dont do this if you dont have 1 single clue what you doing take it to the shops and get it fixed for £10-£15-£20
Posted on Dec 31, 2008
SOURCE: Phone won't hold charge at all
it's because of water damage, there should be a little square && it should be WHITE, most likely if your having this problem its because the little square is RED.
buy a new phone.
Posted on Apr 30, 2009
  • 3 Answers
SOURCE: My cell phone battery died. When I went to
This is not a regular thing. Maybe if you buy a new battery that might work.
Posted on May 09, 2009
My screen flickers and wont stay on
Usually that happens if a screen is shorting out or the power source (Battery) is going bad.
Jan 04, 2015 | Exercise & Fitness
Blowing 50 amp fuse under hood in 2002 crown vic
To blow a fifty amp fuse would take a major short circuit, referred to as a 'dead short' this means that a wire with 12 volts positive (+) is in direct contact with an Earth (-). If you follow the path of the power you will find where this is happening. sometimes you may need to temporarily disconnect some contacts
Jan 31, 2014 | Ford Crown Victoria Cars & Trucks
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 23, 2013 | Televison & Video
When turning the key it would start sometimes but die right out. Other times you had to hold the key in the on position for 10 seconds or so and it would start. Headlights would sometimes flash and car...
I have seen similar "crazyness" caused by communications problems in the computer network. If you scn your entire computer network you will most likely find several "U - codes" (U1000, U1006, etc.) which indicate that modules are losing communication with other modules within the network.
These type of problems are usually caused by a faulty charging system (sulfated, shorted battery, bad alternator diodes, Loose/corroded battery cable connections, etc.) or loose or corroded connectors at one or more of the computer modules.
Scanning your computer network would be the place to start. The modules like to tell on one-another. For example: if the communication loss is in the body computer, the engine control module and/or the instrument panel module, and/or the antilock brake module will have codes saying that the body control module was/is not communicating. In this example, I would take a hard look at the connectors at the body control module.
If several of the modules are all reporting loss of battery voltage at the module, then I would suspect a battery cable, bad ground circuit, etc. Please note that the engine control module will usually NOT report this type of code because it does not use capacitors to keep it "alive" with the battery disconnected like some of the modules such as the body control module and the passive restraint module.
Oct 15, 2011 | 1994 Pontiac Grand Prix
My Packard Bell (bought May 2010 new) laptop has a screen flicker problem. For the past week, every now and then the left half of the screen, or sometimes the bottom half of the screen, gets distorted with...
<font size="3"><i><span style="FONT-FAMILY: Arial; COLOR: #cb0101" lang="EN-US">4400mAh, 11.10V</span></i><span style="FONT-FAMILY: Arial; COLOR: #333333" lang="EN-US"> Dell Vostro 1710 Battery Replacement<span style="mso-spacerun: yes"> </span></span></font><span class="redfont1"><b><span style="FONT-FAMILY: Verdana; FONT-SIZE: 16.5pt; mso-bidi-font-family: Arial" lang="EN-US"><font color="#cb0101">$ 72.58</font></span></b></span><br /> <span style="FONT-FAMILY: Arial; COLOR: #333333" lang="EN-US"><font size="3">Dell Vostro 1710 Battery</font></span><br /> <span class="htmlval1"><span style="FONT-FAMILY: 'Courier New'" lang="EN-US"><font size="3"><font color="#0000ff">Discount Dell Vostro 1710 Battery 11.1V 4400mAh,fit for Dell Vostro 1710, Dell Vostro 1720 Laptops.Full 1-year warranty and 30-day money back!</font></font></span></span><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">ShippingArea:</span></b><b><span style="FONT-FAMILY: Verdana; COLOR: #cc0000; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">We ship all over the world!</span></b><b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US"></span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Brand :Dell Vostro 1710</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Type :Li-ion</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Voltage :11.10V</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Capacity : 4400mAh</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Ltem(Cell):6-cell</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Color :Black</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Dimension :270.90 x 50.00 x <st1:chmetcnv w:st="on" tcsc="0" numbertype="1" negative="False" hasspace="False" sourcevalue="20.2" unitname="mm">20.2mm</st1:chmetcnv></span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Weight :<st1:chmetcnv w:st="on" tcsc="0" numbertype="1" negative="False" hasspace="False" sourcevalue="665" unitname="g">665g</st1:chmetcnv></span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery SKU :DE017K</span></b><br /> <span lang="EN-US"><a href="http://www.battery-sale.net/dell-vostro-1710-battery.html">http://www.battery-sale.net/dell-vostro-1710-battery.html</a><span style="mso-spacerun: yes"> </span></span>
Aug 27, 2010 | Computers & Internet
When I start the laptop or when the screen is
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN ... Power LED and battery charge LED start flickering when you wiggle the power .... HP Pavilion dv7-4080us 17.3-inch Desktop Replacement Laptop PC ... High-Capacity Battery For Hp Pavilion Zd8000 Series Laptops ...
www.articlesbase.com › ComputersLaptops
Jul 19, 2010 | HP Pavilion zd8000 Notebook
2003 Nissan Pathfinder Bat, AT Oil Temp, Brake Lights All Lit
GET YOUR BATTERY LOAD TESTED ALONG WITH YOUR ALTERNATOR TESTED FOR OHMS VALUES AT THE REGULATOR. ALSO MEASURE THE VOLTAGE WITH ALL LIGHTS, AC, RADIO ON. SHOULD BE THE SAME AS BATTERY OUTPUT.
Jun 16, 2009 | 2002 Nissan Pathfinder
Periodic power loss to ignition on 2000 Tundra.
Check the connections on the battery,It sounds like one or both may be loose.
Jun 02, 2009 | 2000 Toyota Tundra
60,000 miles, car won't turn over. usually starts after jumping it from another car for 15-20 minutes but the battery doesn't seem to be the problem, all inside lights and controls still work. this...
Your alternator is most likely on its way out. The electrical problems happen either when there is a short in the electrical system or there are not enough amps to run everything that's on currently.. Get your alternator tested at a parts store such as advanced auto parts.
Jan 18, 2009 | 2005 Honda Accord
I noy surethis lap top is running the correct bios, and battery gets hot
does this only start to happen after the laptop has ben on for a while.
While more information is need, from initial thoughts the laptop could be overheating.
Jun 20, 2008 | HP Pavilion dv1000 Notebook
Samsung Galaxy Note - 16gb - Black unlocked Smartphone Logo
108 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
